([ code]fatih[member=2237]fatih[/member]-X ~ $ uname -rm
3.16.0-38-generic x86_64
fatih[member=2237]fatih[/member]-X ~ $ inxi -gx
/usr/bin/inxi: illegal option -- g
Error 7: One of the options you entered in your script parameters: -gx
is not supported.The option may require extra arguments to work.
For supported options (and their arguments), check the help menu: inxi -h
fatih[member=2237]fatih[/member]-X ~ $ glxinfo | grep render
fatih[member=2237]fatih[/member]-X ~ $ lspci | egrep 'VGA|3D|Display'
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 850M] (rev a2)
fatih[member=2237]fatih[/member]-X ~ $ xrandr
eDP1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 345mm x 194mm
1366x768 60.0*+
1360x768 59.8 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
fatih[member=2237]fatih[/member]-X ~ $ cat /etc/X11/xorg.conf
Sadece uygulama esnasında değil. Masaüstündeykende oluyor.
