Gönderen Konu: [Çözüldü] Ubuntu Unreal Engine Kurulum Sorunu  (Okunma sayısı 5553 defa)
Çevrimdışı ssri
  • İleti: 49
  • Dağıtım: Ubuntu 14.04 LTS 64-bit
  • Masaüstü Ortamı: Unity
« : 31 Ağustos 2015, 13:58:15 »
https://forum.ubuntu-tr.net/index.php?topic=46814.0 Burada anlatıldığı gibi devam ediyorum. Son olarak
./UE4Editor
komutunu verdiğimde aşağıdaki çıktıyı alıyorum.
Using binned.
Increasing per-process limit of core file size to infinity.
Signal 11 caught.
EngineCrashHandler: Signal=11
Starting ../../../engine/binaries/linux/crashreportclient
İptal edildi (çekirdek döküldü)
Bu sorunu nasıl aşabilirim?
Eğer yardımcı olursa programın "../../../engine/binaries/linux/crashreportclient" yolundaki hata kaydı şu şekilde:
Generating report for minidump
Application version 4.8.3.0
 ... built from changelist 0
OS version Linux 4.0.9-040009-generic (network name: asus-X550JK)
Running 2 x86_64 processors (4 logical cores)
Exception was "SIGSEGV: invalid attempt to access memory at address 0x00000000"
<SOURCE START>
<SOURCE END>
<CALLSTACK START>
Unknown!ReportCrash(FLinuxCrashContext const&) + some bytes
UE4Editor!EngineCrashHandler(FGenericCrashContext const&) + some bytes [/home/rtalldota/.unrealengine/Engine/Source/Runtime/Launch/Private/Linux/LaunchLinux.cpp:31]
Unknown!PlatformCrashHandler(int, siginfo_t*, void*) + some bytes
Unknown!/lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f5890ab3340] + some bytes
Unknown!ScalabilityCVarsSinkCallback() + some bytes
Unknown!InitializeRenderingCVarsCaching() + some bytes
UE4Editor!FEngineLoop::PreInit(wchar_t const*) + some bytes [/home/rtalldota/.unrealengine/Engine/Source/Runtime/Launch/Private/LaunchEngineLoop.cpp:983]
UE4Editor!GuardedMain(wchar_t const*) + some bytes [/home/rtalldota/.unrealengine/Engine/Source/Runtime/Launch/Private/Launch.cpp:31]
UE4Editor!./UE4Editor(main+0x87f) [0x42e5ef] + some bytes [/home/rtalldota/.unrealengine/Engine/Source/Runtime/Launch/Private/Linux/LaunchLinux.cpp:193]
Unknown!/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f588531aec5] + some bytes
Unknown!./UE4Editor() [0x411008] + some bytes
<CALLSTACK END>
0 loaded modules
Report end!
« Son Düzenleme: 31 Ağustos 2015, 17:21:14 Gönderen: ssri »
Ynt: Ubuntu Unreal Engine Kurulum Sorunu
« Yanıtla #1 : 31 Ağustos 2015, 15:10:14 »
Komutu şu şekilde verince bir değişiklik oluyor mu?
LC_ALL=C ./UE4Editor
Çevrimdışı ssri
  • İleti: 49
« Yanıtla #2 : 31 Ağustos 2015, 16:29:55 »
Şu an program çalıştı fakat uçbirimde bazı hata bilgileri var hala ve verdiğiniz komut kullanmadığım zamanlar hala açılmıyor.
http://www.pastebin.ca/3144603 Böyle bir çıktı alıyorum şu an.
« Yanıtla #3 : 31 Ağustos 2015, 17:16:39 »
Çıktıda ben bir hata göremedim. Yazılımı yukarıdaki komutla çalıştırabilirsiniz.
Çevrimdışı ssri
  • İleti: 49
« Yanıtla #4 : 31 Ağustos 2015, 17:20:53 »
Teşekkür ederim o zaman :)) İyi çalışmalar...
