Öncelikle merhaba.Konuyu doğru yere mi açtım diye tereddüt ettim ama bir sorun varsa özür dilerim şimdiden.Ben "Kim Korkar Linux'tan?" isimli kitabı şu sıralar okuyorum ve bizzat kitapta kullanılan linux dağıtımını kullanarak ordaki uygulamaları takip etmek istedim.İnternetten Mandriva Linux 2006 sürümünü eski linux arşivlerinden buldum ve indirdim.Kurulum yapmaya çalışırken ekran kartı konfigürasyonumu bir türlü yapamıyorum.
Birkaç ekran görüntüsü ve donanım bilgilerim aşağıdaki gibi.
lspci -v
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
Subsystem: ASUSTeK Computer Inc. Device 178d
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: f6000000-f70fffff
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 35
Memory at f7400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: i915
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
Subsystem: Intel Corporation Device 2010
Flags: bus master, fast devsel, latency 0, IRQ 37
Memory at f7a14000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05) (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Device 201f
Flags: bus master, medium devsel, latency 0, IRQ 30
Memory at f7a00000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 34
Memory at f7a1c000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
Flags: bus master, fast devsel, latency 0, IRQ 36
Memory at f7a10000 (64-bit, non-prefetchable) [size=16K]
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: f7900000-f79fffff
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: f7800000-f78fffff
00:1f.0 ISA bridge: Intel Corporation HM86 Express LPC Controller (rev 05)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 32
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at f7a1a000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
Flags: medium devsel, IRQ 3
Memory at f7a19000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 850M] (rev ff) (prog-if ff)
!!! Unknown header type 7f
03:00.0 Network controller: Broadcom Corporation BCM43142 802.11b/g/n (rev 01)
Subsystem: Lite-On Communications Inc Device 6605
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at f7900000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: wl
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device 5287 (rev 01)
Subsystem: ASUSTeK Computer Inc. Device 202f
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at f7815000 (32-bit, non-prefetchable) [size=4K]
Expansion ROM at f7800000 [disabled] [size=64K]
Kernel driver in use: rtsx_pci
04:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
Subsystem: ASUSTeK Computer Inc. Device 200f
Flags: bus master, fast devsel, latency 0, IRQ 33
I/O ports at d000 [size=256]
Memory at f7814000 (64-bit, non-prefetchable) [size=4K]
Memory at f7810000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
