Gönderen Konu: Firefox ve Chromium donma ve kasma  (Okunma sayısı 16233 defa)
Çevrimdışı khronoss
  • İleti: 10
  • Dağıtım: Linux Mint 17.2
  • Grafik Kartı: AMD
  • İşlemci: i5-4460
« : 07 Eylül 2015, 20:15:24 »
Arkadaşlar Merhaba yeni linux kullanıcısıyım.Pc brz eski oldugu için Linux Mint 17.2 XFCE kurdum.Firefox veya Chromium da dizi film izlerken donma takılma kasma gibi sorunlar yaşıyorum yardımcı olabilir misiniz ?
[/code]
tt@tt ~ $ inxi -Fxz
System:    Host: tt Kernel: 3.16.0-38-generic i686 (32 bit, gcc: 4.8.2)
           Desktop: Xfce 4.12.2 (Gtk 2.24.23) Distro: Linux Mint 17.2 Rafaela
Machine:   Mobo: ATI model: BONEFISH version: 02 Bios: Phoenix version: Q3B71 date: 06/06/2007
CPU:       Dual core Intel CPU T2130 (-MCP-) cache: 1024 KB flags: (nx pae sse sse2 sse3) bmips: 7466.32
           Clock Speeds: 1: 800.00 MHz 2: 800.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RC410M [Mobility Radeon Xpress 200M] bus-ID: 01:05.0
           X.Org: 1.15.1 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1280x800@59.9hz
           GLX Renderer: Gallium 0.4 on ATI RC410 GLX Version: 2.1 Mesa 10.1.3 Direct Rendering: Yes
Audio:     Card: Advanced Micro Devices [AMD/ATI] IXP SB4x0 High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 00:14.2
Network:   Card-1: Ralink RT2561/RT61 rev B 802.11g driver: rt61pci ver: 2.3.0 bus-ID: 09:04.0
           Card-2: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
           driver: 8139too ver: 0.9.28 port: a000 bus-ID: 09:02.0
Drives:    HDD Total Size: 120.0GB (4.2% used) 1: id: /dev/sda model: TOSHIBA_MK1246GS size: 120.0GB
Partition: ID: / size: 109G used: 4.7G (5%) fs: ext4 ID: swap-1 size: 2.01GB used: 0.03GB (1%) fs: swap
Sensors:   System Temperatures: cpu: 63.0C mobo: N/A
Info:      Processes: 175 Uptime: 1:04 Memory: 897.8/1890.1MB Runlevel: 2 Gcc sys: 4.8.4
Çevrimdışı MrtAltg
  • İleti: 68
  • Dağıtım: Linux mint 18 Sarah
  • Grafik Kartı: intel hd graphics 4600
  • İşlemci: intel core i7-4770 cpu@ 3.40Ghz x4
Ynt: Firefox ve Chromium donma ve kasma
« Yanıtla #1 : 07 Eylül 2015, 21:32:00 »
firefox ve chrome un son versiyonları eski makineleri zorlamaya başladı anlaşılan bir işletim sistemi bile bunlar kadar sistem gücü tüketmiyor o yüzden birde midori yi denermisiniz hem hafif hemde bazı işe yarar eklenti desteği ile beraber geliyor isterseniz yazılım yöneticisinden yüklersiniz istersenizde
sudo apt-get install midori komutu ile terminalden den kurabilirsiniz
Çevrimdışı khronoss
  • İleti: 10
  • Grafik Kartı: AMD
  • İşlemci: i5-4460
« Yanıtla #2 : 07 Eylül 2015, 21:37:09 »
PC eski oldugu için belki sistem kaldırmıyo olabilir düşüncesi ile sistemi Linux Mint 17.1 Rebecca xfce 32 bit olarak değiştirdim.Su anda guncellemeleri yapıyo.sizin önermiş oldugunuz programı kurup denicem guncelleme bittiği gibi
« Yanıtla #3 : 07 Eylül 2015, 21:52:05 »
Bu sorun Flash içerikli sayfalarda mı yaşanıyor?
Çevrimdışı khronoss
  • İleti: 10
  • Grafik Kartı: AMD
  • İşlemci: i5-4460
« Yanıtla #4 : 07 Eylül 2015, 22:01:04 »
mozilla ve Chromium da dizi ve film izlerken yaşıyorum evet..
Mesajlar Birleştirildi: 07 Eylül 2015, 22:10:34
Malesef aynı sorunu Midori ile de yaşıyorum.Sistem cok eski oldugu ıcın baska bir sistem mi kurmalıyım acaba ? Linux Mint 17.2 Mate 32 bit ve Xfce 32 ile 17.1 Xfce 32 bit versiyonları denedim.Sonuc hep aynı
« Son Düzenleme: 07 Eylül 2015, 22:10:34 Gönderen: khronoss »
« Yanıtla #5 : 07 Eylül 2015, 22:13:47 »
Ynt: Google Chrome - Flash Player Sorunu
burada ki öneriyi deneyebilirsiniz.
Ynt: Sayfalarda Donma
ek olarak buradaki işlemi de deneyebilirsiniz.
« Son Düzenleme: 07 Eylül 2015, 22:15:52 Gönderen: Danny »
Çevrimdışı khronoss
  • İleti: 10
  • Grafik Kartı: AMD
  • İşlemci: i5-4460
« Yanıtla #6 : 07 Eylül 2015, 22:22:21 »
Hocam buradaki önerinde çıkan tüm eklentiler devredışı bıraktım adobe de dahil donma sorunu halloldu enteresan bir şekilde. Anlam veremedim fakat görüntü arada kayıyor ? Sürücü ile ilgili olabilir mi ?
Düzenleme: Yazım. Lütfen yazım kurallarına dikkat ediniz. Türkçe sözcükler kullanmaya özen gösteriniz. plugin==>eklenti, driver==>sürücü
karakartala
« Son Düzenleme: 07 Eylül 2015, 22:31:19 Gönderen: karakartala »
« Yanıtla #7 : 07 Eylül 2015, 22:25:39 »
Forum düzeni için aynı başlık altında yalnızca bir soru/sorun hakkında konuşuyoruz. İlgili kategoride(ATI) yeni bir konu açınız.
Açtığınız konuda Ekran Kartı ile İlgili Sorularda Verilmesi Gereken Çıktıları paylaşınız. Sürücüyle ilgili herhangi bir işlem yapıp yapmadığınız konusunda bilgi veriniz. Konu Açarken Dikkat Edilmesi Gerekenler
Başlığı etiketlerseniz konuyu kilitleyebiliriz. Çözülen Başlıkların Etiketlenmesi
Çevrimdışı khronoss
  • İleti: 10
  • Grafik Kartı: AMD
  • İşlemci: i5-4460
« Yanıtla #8 : 07 Eylül 2015, 22:27:36 »
Firefox ile ilgili sorun devam eidyor.Chromium ile ilgli donma sorunu biraz daha iyi halde su anda ama hala kasılmalar yaşıyorum
« Yanıtla #9 : 07 Eylül 2015, 22:29:16 »
Firefox'da da eklentileri devre dışı bırakmayı ve Ynt: Sayfalarda Donma buradaki işlemi uygulamayı deneyebilirsiniz.
« Yanıtla #10 : 07 Eylül 2015, 22:34:00 »
ATI'nin sitesinden sürücü mü indirip kurdunuz? Kartınızın desteği uzun zaman önce kesilmiş. http://wiki.cchtml.com/index.php/Hardware
Çevrimdışı khronoss
  • İleti: 10
  • Grafik Kartı: AMD
  • İşlemci: i5-4460
« Yanıtla #11 : 07 Eylül 2015, 22:35:34 »
hayır herhangi bir sürücü indirip kurmadım
Mesajlar Birleştirildi: [time]07 Eylül 2015, 22:36:42[/time]
Malesef donma sorunu devam ediyor.Windows Xp kurucam sanırım tekrar
Mesajlar Birleştirildi: 07 Eylül 2015, 23:24:21
Chromium ile donma ve kasma sorunu baya azaldı fakat dalgalanmalar oluşuo arada .Bunun herhangi bir çözümü var mıdır ?
« Son Düzenleme: 07 Eylül 2015, 23:24:21 Gönderen: khronoss »
Çevrimdışı khronoss
  • İleti: 10
  • Grafik Kartı: AMD
  • İşlemci: i5-4460
« Yanıtla #12 : 22 Eylül 2015, 18:17:40 »
Arkadaşlar tekrar merhaba uzun bir zaman oldu hala sorunu çözemedim.Ubuntu 14.04 ve Kubuntu dahil farklı sürümleri kurdum denedim.Sonuc alamadım en son olarak Linux mint 17.1 mate 32 bit kurdum ama hala aynı donmalar ve takılmalar devam etmekte Yardımcı olabilecek birisi yok mudur ? Bunun bir çözümü yokmudur.Windowsa xp ye geri mi dönmeliyim  ?
« Yanıtla #13 : 22 Eylül 2015, 18:31:58 »
Chromium'da sorunun düzeldiğini yazmışsınız, firefox için aşağıdaki komutu girerek çalıştırmayı deneyiniz.
firefox -safe-mode
Çevrimdışı khronoss
  • İleti: 10
  • Grafik Kartı: AMD
  • İşlemci: i5-4460
« Yanıtla #14 : 22 Eylül 2015, 18:37:59 »
[code](process:4897): GLib-CRITICAL **: g_slice_set_config: assertion 'sys_page_size == 0' failed
(firefox:4897): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised
(firefox:4897): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised
(firefox:4897): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised
(firefox:4897): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised
Vector smash protection is enabled.
[/code]
bu sekilde bir cıktı verdi.tam ekran da donma yapmıyor ama video izlerken tam ekran yaptıgımda donma ve kasma tekrar yasıyorum.Chrome da da aynı sıkıntıyı yasıyorum ama daha az  firefox a gore.
penecere olarak donma ve kasma yok.tam ekran da donma ve kasılmalar yapıyor
acaba yasadıgım bu sorun ekran kartı kaynaklı olabilir mi ? eskı bı karta sahip oldugumdan ve Ati nin destegi olmadıgı ıcın açık kaynaklı driver kurulmuş durumda ( ben herhngi bir yukleme yapmadım lınux kurdugumda otomatık gelen driver Gallium 0.4 on ATI RC410 isminde bir driver kurulu )
Terminale glxinfo | grep render yazdıgımda aşağıdakiler çıkıyor
tt@tt-BONEFISH ~ $ glxinfo | grep render
OpenGL renderer string: Gallium 0.4 on ATI RC410
« Son Düzenleme: 22 Eylül 2015, 18:55:22 Gönderen: khronoss »
