Gönderen Konu: [Çözüldü] Windows ta bağlandığımda halde linux ta internete bağlanamıyorum.  (Okunma sayısı 2552 defa)
Çevrimdışı youshes12
  • İleti: 2
Linux kullanmaya yeni başladım.İlk başta sorun yoktu.Daha sonra internete bağlanmamaya başladı.Linux tekrar yükledim fakat sorun çözülmedi bir türlü.Linux ı Windows un yanına kurdum.Windows ta sorunsuz internete bağlanıyor.
lspci -nnk | grep -iA2 net
00:09.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [10ec:8139] (rev 10)
Subsystem: Foxconn International, Inc. Device [105b:0c84]
Kernel driver in use: 8139too
~ $ sudo lshw -C network
[sudo] password for can:
  *-network
       product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
       physical id: 9
       bus info: pci@0000:00:09.0
       logical name: eth0
       version: 10
       capacity: 100Mbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=32 link=yes maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
       resources: irq:19 ioport:f200(size=256) memory:dffff000-dffff0ff
lsmod
nls_iso8859_1          12617  1
usblp                  18288  0
bnep                   18895  2
rfcomm                 58045  0
snd_hda_codec_hdmi     46396  1
snd_via82xx            28634  2
snd_hda_intel          29285  2
bluetooth             391253  10 bnep,rfcomm
kvm_amd                50814  0
snd_mpu401_uart        13865  1 snd_via82xx
snd_hda_controller     29252  1 snd_hda_intel
snd_ac97_codec        105860  1 snd_via82xx
kvm                   388518  1 kvm_amd
snd_hda_codec         120371  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_controller
ac97_bus               12642  1 snd_ac97_codec
6lowpan_iphc           18262  1 bluetooth
snd_hwdep              13272  1 snd_hda_codec
gameport               15189  1 snd_via82xx
snd_seq_midi_event     14475  1 snd_seq_midi
snd_seq                56592  2 snd_seq_midi_event,snd_seq_midi
snd_rawmidi            25722  2 snd_mpu401_uart,snd_seq_midi
snd_pcm                87194  6 snd_via82xx,snd_ac97_codec,snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller
snd_seq_device         14137  3 snd_seq,snd_rawmidi,snd_seq_midi
serio_raw              13251  0
snd_timer              28648  2 snd_pcm,snd_seq
dm_multipath           22373  0
k8temp                 12854  0
scsi_dh                14458  1 dm_multipath
snd                    66670  20 snd_via82xx,snd_ac97_codec,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_mpu401_uart,snd_seq_device
soundcore              14599  2 snd,snd_hda_codec
i2c_viapro             13107  0
shpchp                 32143  0
mac_hid                13059  0
binfmt_misc            13140  1
parport_pc             32021  1
ppdev                  17391  0
lp                     13299  0
parport                40836  3 lp,ppdev,parport_pc
dm_mirror              21756  0
dm_region_hash         20121  1 dm_mirror
dm_log                 18072  2 dm_region_hash,dm_mirror
hid_generic            12503  0
usbhid                 47035  0
hid                    95946  2 hid_generic,usbhid
pata_acpi              12901  0
uas                    22631  0
usb_storage            52721  2 uas
radeon               1312439  3
i2c_algo_bit           13197  1 radeon
ttm                    85257  1 radeon
8139too                32588  0
drm_kms_helper         55007  1 radeon
8139cp                 27183  0
drm                   255469  6 ttm,drm_kms_helper,radeon
pata_via               13412  0
sata_via               13549  2
mii                    13654  2 8139cp,8139too
floppy                 59708  0
iwconfig | grep 'Power Management'
modinfo rtl8192ce
filename:       /lib/modules/3.16.0-38-generic/kernel/drivers/net/wireless/rtlwifi/rtl8192ce/rtl8192ce.ko
firmware:       rtlwifi/rtl8192cfwU_B.bin
firmware:       rtlwifi/rtl8192cfwU.bin
firmware:       rtlwifi/rtl8192cfw.bin
description:    Realtek 8192C/8188C 802.11n PCI wireless
license:        GPL
author:         Larry Finger <Larry.Finger@lwfinger.net>
author:         Realtek WlanFAE <wlanfae@realtek.com>
author:         lizhaoming <chaoming_li@realsil.com.cn>
srcversion:     BE372FB24A1F38A5218DAA0
alias:          pci:v000010ECd00008176sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008177sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008178sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008191sv*sd*bc*sc*i*
depends:        rtlwifi,rtl_pci,rtl8192c-common,mac80211
intree:         Y
vermagic:       3.16.0-38-generic SMP mod_unload modversions 686
signer:         Magrathea: Glacier signing key
sig_key:        4F:E1:22:64:AD:04:B4:1C:64:ED:44:80:A8:93:42:67:C4:C1:F1:B8
sig_hashalgo:   sha512
parm:           swenc:Set to 1 for software crypto (default 0)
 (bool)
parm:           ips:Set to 0 to not use link power save (default 1)
 (bool)
parm:           swlps:Set to 1 to use SW control power save (default 0)
 (bool)
parm:           fwlps:Set to 1 to use FW control power save (default 1)
 (bool)
parm:           debug:Set debug level (0-5) (default 0) (int)
« Son Düzenleme: 27 Eylül 2015, 14:37:59 Gönderen: youshes12 »
Buradaki öneriyi uygulamayı deneyiniz.
  • İleti: 2
Sorun halloldu teşekkürler.
