Gönderen Konu: Aksiyon sahnelerde kırılmalar  (Okunma sayısı 3963 defa)
Çevrimdışı blackson74
  • İleti: 6
  • Dağıtım: Mint 17.2
  • Grafik Kartı: 7670M
  • İşlemci: i7
« : 27 Ekim 2015, 21:35:31 »
Benzeri konuları araştırdım ancak çözüm olmadı, yardım rica ediyorum. İstenilen çıktılarımı aşağıda belirttim.
uname -rm
3.13.0-37-generic x86_64
inxi -Gx
           Card-2: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7500M/7600M Series] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: fglrx,intel Resolution: 1600x900@60.0hz
           GLX Renderer: AMD Radeon HD 7600M Series GLX Version: 1.4 (2.1 (4.4.13374 - CPC 15.20.1013)) Direct Rendering: No
libGL error: dlopen /usr/lib/fglrx/dri/i965_dri.so failed (/usr/lib/fglrx/dri/i965_dri.so: cannot open shared object file: No such file or directory)
libGL error: failed to load driver: i965
libGL error: dlopen /usr/lib/fglrx/dri/swrast_dri.so failed (/usr/lib/fglrx/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL error: failed to load driver: swrast
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
OpenGL renderer string: AMD Radeon HD 7600M Series
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Thames [Radeon HD 7500M/7600M Series]
Screen 0: minimum 320 x 200, current 1600 x 900, maximum 8192 x 8192
LVDS1 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
   1600x900       60.0*+
   1440x900       59.9
   1360x768       59.8     60.0
   1152x864       60.0
   1024x768       60.0
   800x600        60.3     56.2
   640x480        59.9
Direct renderingi ve x11'i düzelttim. Ancak sorun devam etmekte, hızlı sahnelerde kıpraşma ve kırılmalar olmakta.
           GLX Renderer: AMD Radeon HD 7600M Series GLX Version: 4.4.13374 - CPC 15.20.1013 Direct Rendering: Yes
Section "ServerLayout"
Identifier     "amd-layout"
Section "Module"
Section "Monitor"
Option     "VendorName" "ATI Proprietary Driver"
Option     "ModelName" "Generic Autodetecting Monitor"
Option     "DPMS" "true"
Driver      "fglrx"
Option     "TexturedVideoSync" "on"
BusID       "PCI:1:0:0"
Section "Screen"
DefaultDepth     24
SubSection "Display"
Viewport   0 0
Depth     24
EndSubSection
« Son Düzenleme: 27 Ekim 2015, 23:34:35 Gönderen: blackson74 »
Ynt: Aksiyon sahnelerde kırılmalar
« Yanıtla #1 : 28 Ekim 2015, 09:14:33 »
Buradaki öneri denenebilir.
  • İleti: 6
  • İşlemci: i7
« Yanıtla #2 : 28 Ekim 2015, 16:11:19 »
denedim olmadı bu yöntem
