Gönderen Konu: Wine Photoshop CS6 Hata  (Okunma sayısı 4012 defa)
Çevrimdışı webkahriman
  • İleti: 78
  • Dağıtım: MİNT 17
« : 05 Kasım 2015, 04:24:18 »
Merhaba arkadaşlar,
sudo add-apt-repository ppa:ubuntu-wine/ppa
sudo apt-get install wine1.7 winetricks
winetricks atmlib gdiplus msxml3 msxml6 vcrun2005 vcrun2005sp1 vcrun2008 ie6 fontsmooth-rgb gecko
yaptıktan sonra
wine Set-up.exe komutuyla beraber aldığım terminaldeki hata aşağıdaki gibidir.
webkahriman[member=844]webkahriman[/member] /media/webkahriman/Yeni Birim/Programlar/Adobe CS6 $ wine Set-up.exe
fixme:ole:RemUnknown_QueryInterface No interface for iid {00000019-0000-0000-c000-000000000046}
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/p11-kit-trust.so: /usr/lib/i386-linux-gnu/pkcs11/p11-kit-trust.so: paylaşımlı nesne dosyası açılamıyor: Böyle bir dosya ya da dizin yok
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: paylaşımlı nesne dosyası açılamıyor: Böyle bir dosya ya da dizin yok
fixme:heap:RtlSetHeapInformation (nil) 1 (nil) 0 stub
fixme:thread:GetThreadPreferredUILanguages 52, 0x32dfa4, 0x32e014 0x32dfac
fixme:console:AttachConsole stub ffffffff
Starting installer...
UI mode : Full GUI.
fixme:wuapi:update_installer_get_IsBusy
fixme:wuapi:update_installer_get_RebootRequiredBeforeInstallation
fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
fixme:nls:GetUserPreferredUILanguages stub: 8 0x33d310 (nil) 0x33d314
fixme:heap:RtlSetHeapInformation 0x240000 0 0x23fce0 4 stub
Exiting Installer with Code: 0
webkahriman[member=844]webkahriman[/member] /media/webkahriman/Yeni Birim/Programlar/Adobe CS6 $ fixme:imm:ImmReleaseContext (0x10088, 0x207df40): stub
fixme:msvcrt:__clean_type_info_names_internal (0x369c80) stub
fixme:msvcrt:__clean_type_info_names_internal (0x10006510) stub
Aşağıdaki resimde "Dosyalardan biri eksik olabilir" diyor lakin aynı dosyayı Windowsta kurabiliyorum.
Not: Konu kategorisi yanlış yere açılmış olabilir. Lakin daha önce böyle bir problemle karşılaştığımda konum bu kategoriye taşındığı için burayı tercih ettim.
Düzenleme: Görüntü imgur.com sitesine yüklendi
« Son Düzenleme: 08 Kasım 2015, 12:21:31 Gönderen: Reddet »
Ynt: Wine Photoshop CS6 Hata
« Yanıtla #1 : 08 Kasım 2015, 01:21:41 »
libntlm0 paketini yükledikten sonra kurulumu tekrar deneyebilir misiniz?
sudo apt-get install libntlm0
