Gönderen Konu: [Çözüldü] Tp-Link Wireles adaptör sinyal seviyesi  (Okunma sayısı 3258 defa)
Çevrimdışı novice
  • İleti: 16
  • Dağıtım: mint 16
Tp-Link Wireles adaptör sinyal seviyesi çok mdüşük ve değişken. Modeme çok yakın olmama rağmen seviye  %50 ile %70 aralığında anlık olarak değişiyor. Tabi bu durum interneti etkiliyor. Bazen sayfa açma sorunu yaşıyorum.
inxi -SNx
cemil@cemil-MS-7255 ~ $ inxi -SNx
System:    Host: cemil-MS-7255 Kernel: 3.16.0-38-generic x86_64 (64 bit, gcc: 4.8.2)
Network:   Card-1: Techsan B2C2 FlexCopII DVB chip / Technisat SkyStar2 DVB card
           driver: b2c2_flexcop_pci port: ec00 bus-ID: 04:04.0
           Card-2: VIA VT6102 [Rhine-II] driver: via-rhine port: b000 bus-ID: 00:12.0
           Card-3: Realtek RTL8192CU 802.11n WLAN Adapter driver: rtl8192cu usb-ID: 001-002
lspci -nnk | grep -iA2 net
cemil@cemil-MS-7255 ~ $ lspci -nnk | grep -iA2 net
00:12.0 Ethernet controller [0200]: VIA Technologies, Inc. VT6102 [Rhine-II] [1106:3065] (rev 7c)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Device [1462:7255]
    Kernel driver in use: via-rhine
04:04.0 Network controller [0280]: Techsan Electronics Co Ltd B2C2 FlexCopII DVB chip / Technisat SkyStar2 DVB card [13d0:2103] (rev 02)
    Subsystem: Techsan Electronics Co Ltd B2C2 FlexCopII DVB chip / Technisat SkyStar2 DVB card [13d0:2103]
    Kernel driver in use: b2c2_flexcop_pci
lsusb
Bus 001 Device 004: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
Bus 001 Device 005: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 002: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
rfkill lis
Usage:    rfkill [options] command
Options:
    --version    show version (0.5-1ubuntu1 (Ubuntu))
Commands:
    help
    event
    list [IDENTIFIER]
    block IDENTIFIER
    unblock IDENTIFIER
where IDENTIFIER is the index no. of an rfkill switch or one of:
    <idx> all wifi wlan bluetooth uwb ultrawideband wimax wwan gps fm nfc
sudo lshw -C network
  *-network
       açıklama: Eternet interface
       ürün: VT6102 [Rhine-II]
       üretici: VIA Technologies, Inc.
       physical id: 12
       bus info: pci@0000:00:12.0
       mantıksal ad: eth0
       sürüm: 7c
       serial: 00:19:db:73:d0:d1
       boyut: 10Mbit/s
       kapasite: 100Mbit/s
       genişlik: 32 bits
       saat: 33MHz
       kapasiteler: pm bus_master cap_list eternet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       yapılandırma: autonegotiation=on broadcast=yes driver=via-rhine driverversion=1.5.1 duplex=half latency=32 link=no maxlatency=8 mingnt=3 multicast=yes port=MII speed=10Mbit/s
       kaynaklar: irq:23 ioport:b000(boyut=256) bellek:fcfff800-fcfff8ff
  *-network
       açıklama: Network controller
       ürün: B2C2 FlexCopII DVB chip / Technisat SkyStar2 DVB card
       üretici: Techsan Electronics Co Ltd
       physical id: 4
       bus info: pci@0000:04:04.0
       sürüm: 02
       genişlik: 32 bits
       saat: 33MHz
       kapasiteler: bus_master
       yapılandırma: driver=b2c2_flexcop_pci latency=32
       kaynaklar: irq:16 bellek:feaf0000-feafffff ioport:ec00(boyut=32)
  *-network
       açıklama: Kablosuz arayüz
       physical id: 1
       bus info: usb@1:1
       mantıksal ad: wlan0
       serial: c0:4a:00:1c:c6:88
       yapılandırma: broadcast=yes driver=rtl8192cu driverversion=3.16.0-38-generic firmware=N/A ip=192.168.1.41 link=yes multicast=yes wireless=IEEE 802.11bgn
iwconfig | grep Power
          Bit Rate=72.2 Mb/s   Tx-Power=20 dBm
          Power Management:off
lsmod
v4l2loopback           34037  0
videodev              153793  1 v4l2loopback
media                  21903  1 videodev
ctr                    13049  2
ccm                    17773  2
rfcomm                 69509  0
bluetooth             446409  10 bnep,rfcomm
6lowpan_iphc           18702  1 bluetooth
binfmt_misc            17468  1
nvidia              10561213  49
snd_hda_codec_hdmi     47548  4
rtl8192cu              67741  0
rtl_usb                18448  1 rtl8192cu
rtlwifi                64255  2 rtl_usb,rtl8192cu
rtl8192c_common        53172  1 rtl8192cu
mac80211              652777  3 rtl_usb,rtlwifi,rtl8192cu
snd_hda_codec_realtek    77467  1
dvb_pll                18840  1
snd_hda_codec_generic    69011  1 snd_hda_codec_realtek
snd_hda_intel          30469  5
snd_hda_controller     30228  1 snd_hda_intel
snd_hda_codec         139682  5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
cfg80211              494362  2 mac80211,rtlwifi
snd_hwdep              17698  1 snd_hda_codec
snd_pcm               104112  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller
stv0299                18574  1
snd_seq_midi           13564  0
b2c2_flexcop_pci       15026  0
snd_rawmidi            30876  1 snd_seq_midi
snd_seq                63074  2 snd_seq_midi_event,snd_seq_midi
b2c2_flexcop           31065  1 b2c2_flexcop_pci
snd_timer              29562  2 snd_pcm,snd_seq
s5h1420                18520  1 b2c2_flexcop
cx24113                17829  1 b2c2_flexcop
joydev                 17393  0
snd                    79468  21 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
cx24123                19116  1 b2c2_flexcop
coretemp               13441  0
soundcore              15047  2 snd,snd_hda_codec
dvb_core              121659  2 stv0299,b2c2_flexcop
drm                   311018  3 nvidia
dm_multipath           22843  0
serio_raw              13483  0
scsi_dh                14882  1 dm_multipath
i2c_viapro             13323  0
shpchp                 37047  0
parport_pc             32741  1
mac_hid                13227  0
dm_mirror              22135  0
dm_region_hash         20862  1 dm_mirror
dm_log                 18411  2 dm_region_hash,dm_mirror
hid_generic            12559  0
usbhid                 52616  0
hid                   110426  2 hid_generic,usbhid
pata_acpi              13053  0
uas                    23159  0
usb_storage            66545  1 uas
psmouse               106610  0
via_rhine              32979  0
sata_via               17957  5
mii                    13934  1 via_rhine
pata_via               13677  0
« Son Düzenleme: 05 Kasım 2015, 22:17:29 Gönderen: novice »
Ynt: Tp-Link Wireles adaptör sinyal seviyesi
« Yanıtla #1 : 05 Kasım 2015, 21:48:39 »
https://forum.linuxmint.net.tr/index.php?topic=3785.msg24174#msg24174
« Son Düzenleme: 05 Kasım 2015, 21:49:43 Gönderen: Butterfly »
Çevrimdışı novice
  • İleti: 16
  • Dağıtım: mint 16
« Yanıtla #2 : 05 Kasım 2015, 22:17:10 »
Teşekkürler sorun çözüldü. Sinyal seviyesi şimdi %99 ile %100 arasında ve internet erişimi gayet sağlıklı.
