Gönderen Konu: Acer travelmate 5310- Wireless çalışmıyor ve bilgisayar kapanmıyor  (Okunma sayısı 3195 defa)
Çevrimdışı kenaniler
  • İleti: 17
  • Dağıtım: linux mint 17.1 rebecca
  • Masaüstü Ortamı: mate
  • İşlemci: intel
Linux Mint Rafaela'yı kurdum fakat kablosuz ağ çalışmıyor ve pc kapanmıyor. Wireless Broadcam BCM94311MCG, sorun kernelden mi kaynaklanıyor  ?
acer acer-TravelMate-5310 ~ $ inxi -Fx
System:    Host: acer-TravelMate-5310 Kernel: 3.16.0-38-generic i686 (32 bit, gcc: 4.8.2)
           Desktop: MATE 1.10.2  Distro: Linux Mint 17.2 Rafaela
Machine:   System: Acer product: TravelMate 5310 version: 0100
           Mobo: Acer model: Dallen version: Rev Bios: Phoenix version: V1.07 date: 07/12/2007
CPU:       Single core Intel Celeron M CPU 520 (-UP-) cache: 1024 KB flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 3199.72 clocked at 1599.864 MHz
Graphics:  Card: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics Controller bus-ID: 00:02.0
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1280x800@59.9hz
           GLX Renderer: Mesa DRI Intel 945GM x86/MMX/SSE2 GLX Version: 1.4 Mesa 10.1.3 Direct Rendering: Yes
Audio:     Card: Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Broadcom BCM4311 802.11b/g WLAN driver: wl bus-ID: 03:00.0
           IF: N/A state: N/A mac: N/A
           Card-2: Broadcom NetLink BCM5787M Gigabit Ethernet PCI Express driver: tg3 ver: 3.137 bus-ID: 02:00.0
           IF: eth0 state: down mac: 00:16:d3:e2:4d:3e
Drives:    HDD Total Size: 80.0GB (7.1% used) 1: id: /dev/sda model: Hitachi_HTS54168 size: 80.0GB
Partition: ID: / size: 18G used: 5.4G (32%) fs: ext4 ID: swap-1 size: 1.47GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 51.0C mobo: 49.0C
Info:      Processes: 145 Uptime: 27 min Memory: 435.1/1502.1MB Runlevel: 2 Gcc sys: 4.8.4
acer acer-TravelMate-5310 ~ $ glxinfo | grep render
OpenGL renderer string: Mesa DRI Intel(R) 945GM x86/MMX/SSE2
Düzenleme : Kod etiketi
« Son Düzenleme: 24 Kasım 2015, 09:12:05 Gönderen: Butterfly »
Bağlantıdaki komutların çıktılarını da rica edelim.
Ağ / Internet / Network ile İlgili Sorularda Verilmesi Gereken Çıktılar
  • İleti: 17
  • İşlemci: intel
Biraz geciktim özür dilerim. Çıktıyı aldım
acer[member=226]acer[/member]-TravelMate-5310 ~ $ inxi -SNx
acer[member=226]acer[/member]-TravelMate-5310 ~ $ lspci -nnk | grep -iA2 net
02:00.0 Ethernet controller [0200]: Broadcom Corporation NetLink BCM5787M Gigabit Ethernet PCI Express [14e4:1693] (rev 02)
   Subsystem: Acer Incorporated [ALI] Device [1025:011c]
   Kernel driver in use: tg3
03:00.0 Network controller [0280]: Broadcom Corporation BCM4311 802.11b/g WLAN [14e4:4311] (rev 01)
   Subsystem: AMBIT Microsystem Corp. Device [1468:0422]
   Kernel driver in use: wl
acer[member=226]acer[/member]-TravelMate-5310 ~ $ lsusb
Bus 001 Device 006: ID 1004:6344 LG Electronics, Inc.
acer[member=226]acer[/member]-TravelMate-5310 ~ $ rfkill list
1: acer-wireless: Wireless LAN
   Soft blocked: no
   Hard blocked: no
acer[member=226]acer[/member]-TravelMate-5310 ~ $ sudo lshw -C network
[sudo] password for acer:
  *-network
       açıklama: Eternet interface
       ürün: NetLink BCM5787M Gigabit Ethernet PCI Express
       üretici: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:02:00.0
       mantıksal ad: eth0
       sürüm: 02
       serial: 00:16:d3:e2:4d:3e
       kapasite: 1Gbit/s
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: pm vpd msi pciexpress bus_master cap_list eternet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       yapılandırma: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 firmware=5787m-v3.23 latency=0 link=no multicast=yes port=twisted pair
       kaynaklar: irq:45 bellek:d6000000-d600ffff
  *-network
       açıklama: Network controller
       ürün: BCM4311 802.11b/g WLAN
       physical id: 0
       bus info: pci@0000:03:00.0
       sürüm: 01
       genişlik: 32 bits
       saat: 33MHz
       kapasiteler: pm msi pciexpress bus_master cap_list
       yapılandırma: driver=wl latency=0
       kaynaklar: irq:17 bellek:d8000000-d8003fff
  *-network
       physical id: 1
       mantıksal ad: usb0
       serial: 02:1c:42:43:30:08
       kapasiteler: eternet physical
       yapılandırma: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.66 link=yes multicast=yes
acer[member=226]acer[/member]-TravelMate-5310 ~ $ iwconfig | grep Power
usb0      no wireless extensions.
acer[member=226]acer[/member]-TravelMate-5310 ~ $ lsmod
rndis_host             14097  0
cdc_ether              13977  1 rndis_host
usbnet                 37829  2 rndis_host,cdc_ether
cdc_acm                32093  0
mii                    13654  1 usbnet
ctr                    12905  0
ccm                    17496  0
acer_wmi               31735  0
sparse_keymap          13708  1 acer_wmi
arc4                   12536  0
bnep                   18895  2
rfcomm                 58045  0
bluetooth             391253  10 bnep,rfcomm
6lowpan_iphc           18262  1 bluetooth
ath9k_htc              65174  0
wl                   6144840  1
snd_hda_codec_realtek    70475  1
snd_hda_codec_generic    62931  2 snd_hda_codec_realtek
ath9k_common           24878  1 ath9k_htc
snd_hda_intel          29285  3
snd_hda_controller     29252  1 snd_hda_intel
ath9k_hw              430710  2 ath9k_common,ath9k_htc
snd_hda_codec         120371  4 snd_hda_codec_realtek,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
snd_hwdep              13272  1 snd_hda_codec
snd_pcm                87194  3 snd_hda_codec,snd_hda_intel,snd_hda_controller
snd_seq_midi_event     14475  1 snd_seq_midi
ath                    24182  3 ath9k_common,ath9k_htc,ath9k_hw
snd_rawmidi            25722  1 snd_seq_midi
coretemp               13201  0
mac80211              559100  1 ath9k_htc
pcmcia                 51828  0
snd_seq                56592  2 snd_seq_midi_event,snd_seq_midi
joydev                 17113  0
dm_multipath           22373  0
scsi_dh                14458  1 dm_multipath
snd_seq_device         14137  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              28648  2 snd_pcm,snd_seq
serio_raw              13251  0
yenta_socket           40215  0
lpc_ich                16877  0
snd                    66670  16 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
pcmcia_rsrc            18319  1 yenta_socket
tifm_7xx1              13182  0
binfmt_misc            13140  1
cfg80211              418839  5 wl,ath,ath9k_common,mac80211,ath9k_htc
pcmcia_core            22328  3 pcmcia,pcmcia_rsrc,yenta_socket
tifm_core              15133  1 tifm_7xx1
soundcore              14599  2 snd,snd_hda_codec
shpchp                 32143  0
mac_hid                13059  0
parport_pc             32021  0
ppdev                  17391  0
lp                     13299  0
parport                40836  3 lp,ppdev,parport_pc
dm_mirror              21756  0
dm_region_hash         20121  1 dm_mirror
dm_log                 18072  2 dm_region_hash,dm_mirror
i915                  808682  3
firewire_ohci          35647  0
tg3                   156360  0
ahci                   25622  2
sdhci_pci              18640  0
firewire_core          61867  1 firewire_ohci
ptp                    18861  1 tg3
i2c_algo_bit           13197  1 i915
libahci                26970  1 ahci
psmouse                91277  0
drm_kms_helper         55007  1 i915
sdhci                  38345  1 sdhci_pci
crc_itu_t              12627  1 firewire_core
pps_core               18799  1 ptp
pata_acpi              12901  0
drm                   255469  5 i915,drm_kms_helper
wmi                    18689  1 acer_wmi
video                  19475  2 i915,acer_wmi
« Son Düzenleme: 30 Kasım 2015, 23:17:44 Gönderen: Danny »
sudo apt-get install firmware-b43-installer
dedikten sonra sistemi yeniden başlatıp, tekrar deneyin.
« Son Düzenleme: 30 Kasım 2015, 23:21:02 Gönderen: Danny »
  • İleti: 17
  • İşlemci: intel
Şöyle sonuç aldım :
acer[member=226]acer[/member]-TravelMate-5310 ~ $ sudo apt-get install firmware-b43-installer
firmware-b43-installer zaten en yeni sürümde.
0 paket yükseltilecek, 0 yeni paket kurulacak, 0 paket kaldırılacak ve 32 paket yükseltilmeyecek.
Sorun kernelden kaynaklanabilir mi  ? Şöyle ki Menü- Çıkış - kapat seçiyorum fakat M ekranında kalıyor sürekli. Bilgisayar kapanmıyor . Yani wireless ve kapanmama problemi aynı kaynaktan olabilir mi ?
« Son Düzenleme: 30 Kasım 2015, 23:35:44 Gönderen: Danny »
Güncelleme Yöneticisi => Düzenle menüsü => Tercihler => Seviyeler kısmından 4. seviye güncellemeleri işaretleyiniz ve Yenile düğmesine tıklayıp Güncellemeleri Kur düğmesine tıklayarak sisteminizi güncelleyiniz.
Ardından, Güncelleme Yöneticisi => Görünüm menüsü => Linux çekirdekleri aracı yardımıyla 3.16.x serisi çekirdeğin son sürümünü (şu an itibariyle 3.16.0-50 sürümde) kurunuz.
Ayrıca lütfen, çıktıları code etiketi içerisine alalım bu şekilde, ayırt edilmesi zor oluyor.
