Gönderen Konu: X86 32 bit işlemciler ve 3GB RAM sınırı  (Okunma sayısı 5805 defa)
Çevrimdışı dirent
  • İleti: 293
  • Grafik Kartı: Nvidia 8400GS
  • İşlemci: P4 3.2 GHz
« : 14 Aralık 2015, 00:24:44 »
Forumda gezinirken aşağıdaki siteye verilmiş bir link gördüm:
http://linuxogrenmekistiyorum.com/2013/12/03/ramin-dusuk-gozukmesi-ve-cozumu/
Burada yazılanlar doğru mudur? 32 bit sistemde örneğin 4 GB takıp Linux Mint'te uygun bir çekirdek var mıdır kullanabileceğim?
Çıktılar:
inxi
CPU~Single core Intel Pentium 4 (-HT-) speed~3200 MHz (max)
Kernel~3.16.0-55-generic i686 Up~8:37 Mem~1630.4/3035.0MB
HDD~500.1GB(7.9% used) Procs~163 Client~Shell inxi~2.2.28
inxi -SGx
System:    Host: export-Ezel Kernel: 3.16.0-55-generic i686 (32 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Graphics:  Card: NVIDIA GT218 [GeForce 8400 GS Rev. 3] bus-ID: 04:00.0
           Display Server: X.Org 1.15.1 driver: nvidia
           Resolution: 1366x768@59.8hz
           GLX Renderer: GeForce 8400GS/PCIe/SSE2
           GLX Version: 3.3.0 NVIDIA 340.96 Direct Rendering: Yes
OpenGL renderer string: GeForce 8400GS/PCIe/SSE2
    GL_NV_ES1_1_compatibility, GL_NV_blend_square, GL_NV_conditional_render,
04:00.0 VGA compatible controller: NVIDIA Corporation GT218 [GeForce 8400 GS Rev. 3] (rev a2)
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 8192 x 8192
DVI-I-0 disconnected (normal left inverted right x axis y axis)
VGA-0 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 410mm x 230mm
   1366x768       59.8*+
   1280x1024      75.0     60.0
   1280x720       60.0
   1024x768       75.0     60.0
   800x600        75.0     60.3
   640x480        75.0     72.8     59.9
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 346.72  (buildd@comet)  Tue May 19 14:46:08 UTC 2015
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    Option         "Xinerama" "0"
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Philips PHL 193V5"
    HorizSync       30.0 - 83.0
    VertRefresh     56.0 - 76.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
    BoardName      "GeForce 8400GS"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "CRT-1"
    Option         "metamodes" "1366x768_60 +0+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
Cevaplarınız için şimdiden teşekkürler.
Bayılıyorum buraya
Ynt: X86 32 bit işlemciler ve 3GB RAM sınırı
« Yanıtla #1 : 14 Aralık 2015, 08:46:51 »
PAE destekli çekirdek ile gelen 32 bit Linux dağıtımları, 4 GB.'dan fazla RAM desteğine sahiptir. Linux Mint 17.x serisinintüm 32 bit sürümleri PAE destekli çekirdek ile gelmektedir. Bunun güncel Linux dağıtımlarının çoğu için geçerli olduğunu öngörebilirsiniz.
Çevrimdışı dirent
  • İleti: 293
« Yanıtla #2 : 14 Aralık 2015, 10:54:39 »
Çok iyi.
Sistemde var olan 1 GB ve 2GB RAM modüllerine ilaveten 1 GB daha taktım.
BIOS okuma ekranında 3400 gibi bir rakam için, RAM OK dedi.
Şu an Sistem Gözlemcisinden baktığımda da 3.3 GB RAM var görünüyor.
Terminal'den bakınca 3415 MB yazıyor.
Çıktı şu şekilde:
inxi
CPU~Single core Intel Pentium 4 (-HT-) speed/max~2800/3200 MHz
Kernel~3.16.0-55-generic i686 Up~6 min
Mem~781.5/3415.0MB
HDD~500.1GB(7.9% used) Procs~141
Neden 4 GB RAM görünmüyor?
Bayılıyorum buraya
« Yanıtla #3 : 14 Aralık 2015, 11:39:32 »
Entegre GPU kullanıyorsanız, RAM'ın bir kısmını BIOS'dan buna ayırmış olabilirsiniz.
Çevrimdışı dirent
  • İleti: 293
« Yanıtla #4 : 14 Aralık 2015, 14:48:37 »
Yok hayır Nvidia 8400 GS ekran karti var.
Bayılıyorum buraya
« Yanıtla #5 : 14 Aralık 2015, 16:19:37 »
BIOS ayarlarında bir sıkıntı olabilir, yukarıdaki bilgiye göre sorunun yazılımsal değilde donanımsal olabileceği daha muhtemel görünüyor.
Çevrimdışı dirent
  • İleti: 293
« Yanıtla #6 : 14 Aralık 2015, 23:47:02 »
Valla RAM ayari ile ilgili bir yer göremedim.   :-\
Bayılıyorum buraya
« Yanıtla #7 : 15 Aralık 2015, 12:53:24 »
Bu sistemin BIOS güncellemesi var mıdır, öncelikle bunu kontrol etmenizi öneririm. Paylaştığınız bilgiye göre sistemin RAM miktarını algılaması ile ilgili donanımsal bir sorun olduğunu düşünüyorum.
Çevrimdışı dirent
  • İleti: 293
« Yanıtla #8 : 15 Aralık 2015, 13:54:59 »
Donanım ile ilgili bir durum olduğu konusunda sizinle hemfikirim.
Sisteme bakınca:
Machine:   Mobo: ASUSTeK model: P5LD2-SE v: Rev x.xx
           Bios: American Megatrends v: 1301 date: 08/16/2007
yazıyor.
Sizden şu adrese girip BIOS seçeneklerini açmanızı rica ederim:
http://www.asus.com/tr/support/Download/1/22/14/3/ly0uHyAg2GI5nzmr/23/
Burada yazan Version 1301 ile bendeki Version tutuyor. Ama tarihler tutmuyor
« Son Düzenleme: 15 Aralık 2015, 14:06:23 Gönderen: dirent »
Bayılıyorum buraya
« Yanıtla #9 : 15 Aralık 2015, 14:26:35 »
Sizin BIOS güncel görünüyor.
BIOS'dan "Memory Hole Remapping" seçeneğini etkinleştirmeyi dener misiniz?
Çevrimdışı dirent
  • İleti: 293
« Yanıtla #10 : 15 Aralık 2015, 14:42:09 »
Az önce girip baktım ancak BIOS'ta öyle bir alan göremedim.
Bayılıyorum buraya
