Gönderen Konu: [Çözüldü] Bluetooth çalışmıyor  (Okunma sayısı 5273 defa)
Çevrimdışı 25furkan
  • İleti: 131
  • Dağıtım: Mint 17.2
« : 18 Aralık 2015, 17:09:59 »
Uzun süredir kullanıyordum bluetooth ne olduysa çalışmıyor artık.Realtek  rtl8723ae combo kartın üzerinde bluetooth,zaten bu kartın kablosuz ağını çalıştıramadık 2 yıldır,bluetooth da çalışmayacaksa çıkarıp çekiçle ufatayım bu kartı o derece sinirliyim.
furkan[member=1622]furkan-CR61-3M ~ $ dmesg | grep Blue
[    2.501004] usb 4-2: Product: RT Bluetooth Radio
[   14.515269] Bluetooth: Core ver 2.20
[   14.515312] Bluetooth: HCI device and connection manager initialized
[   14.515321] Bluetooth: HCI socket layer initialized
[   14.515327] Bluetooth: L2CAP socket layer initialized
[   14.515340] Bluetooth: SCO socket layer initialized
[   14.556955] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=1200
[   14.556962] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723a_fw.bin
[   14.704785] Bluetooth: hci0: Failed to load rtl_bt/rtl8723a_fw.bin
[   16.250857] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.250866] Bluetooth: BNEP filters: protocol multicast
[   16.250877] Bluetooth: BNEP socket layer initialized
[   16.254341] Bluetooth: RFCOMM TTY layer initialized
[   16.254357] Bluetooth: RFCOMM socket layer initialized
[   16.254368] Bluetooth: RFCOMM ver 1.11
furkan[member=1622]furkan-CR61-3M ~ $ rfkill list
0: hci0: Bluetooth
   Soft blocked: yes
   Hard blocked: no
1: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
2: phy1: Wireless LAN
   Soft blocked: no
   Hard blocked: no
furkan[member=1622]furkan-CR61-3M ~ $ lsusb
Bus 003 Device 004: ID 5986:014c Acer, Inc
Bus 003 Device 002: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 004 Device 002: ID 13d3:3394 IMC Networks
furkan[member=1622]furkan-CR61-3M ~ $ hcitool dev
Devices:
furkan[member=1622]furkan-CR61-3M ~ $ hcitool scan
Device is not available: No such device
Düzenleme : bbcode
« Son Düzenleme: 19 Aralık 2015, 15:21:00 Gönderen: 25furkan »
Ynt: Bluetooth çalışmıyor
« Yanıtla #1 : 18 Aralık 2015, 17:21:24 »
rfkill list
0: hci0: Bluetooth
   Soft blocked: yes
Donanımı  yazılımsal olarak kilitlediğiniz görülüyor. Aşağıdaki komutu çalıştırmayı deneyiniz.
sudo rfkill unblock all
Çevrimdışı 25furkan
  • İleti: 131
« Yanıtla #2 : 18 Aralık 2015, 17:24:51 »
İşe yaramadı,donanımsal olarak açık ışığı yanıyor bluetooth uygulamalarına girince kapalı diyor aç diyorum ama çalışmıyor.
« Yanıtla #3 : 18 Aralık 2015, 17:35:02 »
Çıktıya bakalım tekrar.
rfkill list
Sorun sonradan ortaya çıkmış, herhangi bir düzenleme yaptınız mı? Sorun neden sonra ortaya çıktı?
Çevrimdışı 25furkan
  • İleti: 131
« Yanıtla #4 : 18 Aralık 2015, 20:37:09 »
Her hangi bir düzenleme yapmadım çalışıyordu çekirdek güncellemeden sonrada çalıştı uzun süre birden gitti.
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
Düzenleme : bbcode
« Son Düzenleme: 18 Aralık 2015, 21:49:45 Gönderen: Butterfly »
« Yanıtla #5 : 18 Aralık 2015, 21:54:15 »
Aşağıdaki komutlar ile linux-firmware paketini yeniden kurmayı deneyiniz.
sudo apt-get install --reinstall linux-firmware
Çevrimdışı 25furkan
  • İleti: 131
« Yanıtla #6 : 19 Aralık 2015, 15:20:44 »
Teşekkürler sorun çözüldü,çalışıyor.
