Öncelikle forum üyelerine ve yöneticilerine "İyi Yıllar" dilerim.17.1 de depo olarak kullandığım 2. HDD ye 17.3 bağlanamıyorum.
[/code]Error mounting /dev/sdb1 at /media/osman/HERŞEY BURDA: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sdb1" "/media/osman/HERŞEY BURDA"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Failed to mount '/dev/sdb1': Operation not permitted
sudo fdisk -l
Disk /dev/sda: 160.0 GB, 160040803840 bytes
255 heads, 63 sectors/track, 19457 cylinders, toplam 312579695 sektör
Disk kimlikleyicisi: 0x00000001
Aygıt Açılış Başlangıç Bitiş BlokSayısı Kml Sistem
/dev/sda1 * 2048 1026047 512000 7 HPFS/NTFS/exFAT
/dev/sda2 1026048 210178047 104576000 7 HPFS/NTFS/exFAT
/dev/sda3 210178048 214271797 2046875 82 Linux takas / Solaris
/dev/sda4 214272000 312576687 49152344 83 Linux
Disk /dev/sdb: 160.0 GB, 160040803840 bytes
Disk kimlikleyicisi: 0xe9a0013f
/dev/sdb1 * 63 312576704 156288321 7 HPFS/NTFS/exFAT
sudo parted -l
Model: ATA ST3160021A (scsi)
Disk /dev/sda: 160GB
Disk bölümü Tablosu: msdos
Numara Başlangıç Son Boyut Tür Dosya sistemi Bayraklar
1 1049kB 525MB 524MB primary ntfs önyükleme
2 525MB 108GB 107GB primary ntfs
3 108GB 110GB 2096MB primary linux-swap(v1)
4 110GB 160GB 50,3GB primary ext4
Model: ATA SAMSUNG HD161HJ (scsi)
Disk /dev/sdb: 160GB
1 32,3kB 160GB 160GB primary ntfs önyükleme
