Gönderen Konu: Flash Plugins Sorunu  (Okunma sayısı 2229 defa)
Çevrimdışı Mstyle34
  • İleti: 57
    • Mstyle34
  • Dağıtım: Linux Mint 17.3 Rosa
  • Grafik Kartı: AMD Radeon HD 5450
  • İşlemci: Pentium(R) Dual-core CPU E6600 @3.07 GHZ
« : 07 Ocak 2016, 15:41:16 »
Tarayıcımı çalıştırıp video izlemek istediğimde aşağıdaki sorunu alıyorum
inxi -SNx:
System:    Host: Tufuk-Pegatron Kernel: 3.16.0-38-generic x86_64 (64 bit, gcc: 4.8.2)
           Desktop: Cinnamon 2.8.2  Distro: Linux Mint 17.2 Rafaela
Network:   Card-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce port: d800 bus-ID: 03:00.0
           driver: r8169 ver: 2.3LK-NAPI port: c800 bus-ID: 02:00.0
           Card-3: Ralink RT2870/RT3070 Wireless Adapter driver: rt2800usb ver: 2.3.0 usb-ID: 001-004
lspci -nnk | grep -iA2 net:
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 03)
Subsystem: Pegatron Device [1b0a:0048]
Kernel driver in use: r8169
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter [10ec:8176] (rev 01)
Subsystem: ASUSTeK Computer Inc. Device [1043:84b5]
Kernel driver in use: rtl8192ce
lsusb:
Bus 001 Device 005: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
Bus 001 Device 004: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 004 Device 003: ID 1a2c:0023 China Resource Semico Co., Ltd
Bus 004 Device 002: ID 0000:0538
rfkill list:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
sudo lshw -C network:
-network
       açıklama: Kablosuz arayüz
       ürün: RTL8188CE 802.11b/g/n WiFi Adapter
       physical id: 0
       bus info: pci@0000:03:00.0
       mantıksal ad: wlan0
       sürüm: 01
       serial: 10:bf:48:4a:75:9c
       genişlik: 64 bits
       saat: 33MHz
       yapılandırma: broadcast=yes driver=rtl8192ce driverversion=3.16.0-38-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11bgn
       kaynaklar: irq:16 ioport:d800(boyut=256) bellek:feafc000-feafffff
  *-network
       açıklama: Eternet interface
       physical id: 0
       bus info: pci@0000:02:00.0
       mantıksal ad: eth0
       sürüm: 03
       serial: 70:71:bc:77:d1:a0
       boyut: 10Mbit/s
       kapasite: 1Gbit/s
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: pm msi pciexpress msix vpd bus_master cap_list rom eternet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       yapılandırma: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8168d-1.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       kaynaklar: irq:43 ioport:c800(boyut=256) bellek:dffff000-dfffffff bellek:dfff8000-dfffbfff bellek:fe9e0000-fe9fffff
  *-network
       physical id: 3
       bus info: usb@1:7
       mantıksal ad: wlan1
       serial: 98:3f:9f:22:78:58
       yapılandırma: broadcast=yes driver=rt2800usb driverversion=3.16.0-38-generic firmware=0.29 ip=192.168.128.190 link=yes multicast=yes wireless=IEEE 802.11bgn
iwconfig | grep Power:
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Power Management:off
          Bit Rate=11 Mb/s   Tx-Power=20 dBm
lsmod:
nls_utf8               12557  1
udf                    93821  1
crc_itu_t              12707  1 udf
rfcomm                 69509  0
bluetooth             446409  10 bnep,rfcomm
6lowpan_iphc           18702  1 bluetooth
binfmt_misc            17468  1
fglrx               12457916  93
gpio_ich               13586  0
dm_multipath           22843  0
scsi_dh                14882  1 dm_multipath
rt2800usb              27189  0
rt2x00usb              20742  1 rt2800usb
rt2800lib              89076  1 rt2800usb
joydev                 17393  0
rt2x00lib              55307  3 rt2x00usb,rt2800lib,rt2800usb
crc_ccitt              12707  1 rt2800lib
arc4                   12608  4
snd_hda_codec_realtek    77467  1
snd_hda_codec_generic    69011  1 snd_hda_codec_realtek
snd_hda_codec_hdmi     47548  1
coretemp               13441  0
kvm_intel             143590  0
kvm                   452088  1 kvm_intel
snd_hda_intel          30469  5
snd_hda_controller     30228  1 snd_hda_intel
snd_hda_codec         139682  5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
snd_hwdep              17698  1 snd_hda_codec
snd_pcm               104112  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller
snd_seq_midi           13564  0
snd_rawmidi            30876  1 snd_seq_midi
snd_seq                63074  2 snd_seq_midi_event,snd_seq_midi
serio_raw              13483  0
lpc_ich                21093  0
rtl8192ce              53516  0
rtl_pci                26690  1 rtl8192ce
snd_timer              29562  2 snd_pcm,snd_seq
rtlwifi                64255  2 rtl_pci,rtl8192ce
rtl8192c_common        53172  1 rtl8192ce
snd                    79468  21 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
mac80211              652777  6 rtl_pci,rtlwifi,rt2x00lib,rt2x00usb,rt2800lib,rtl8192ce
cfg80211              494362  3 mac80211,rtlwifi,rt2x00lib
soundcore              15047  2 snd,snd_hda_codec
amd_iommu_v2           18916  1 fglrx
shpchp                 37047  0
mac_hid                13227  0
parport_pc             32741  0
dm_mirror              22135  0
dm_region_hash         20862  1 dm_mirror
dm_log                 18411  2 dm_region_hash,dm_mirror
hid_generic            12559  0
usbhid                 52616  0
hid                   110426  2 hid_generic,usbhid
uas                    23159  0
usb_storage            66545  1 uas
psmouse               106610  0
pata_acpi              13053  0
r8169                  71694  0
mii                    13934  1 r8169
« Son Düzenleme: 08 Ocak 2016, 12:21:09 Gönderen: Mstyle34 »
Önce doğruyu biImek gerekir, doğru biIinirse yanIış da biIinir: ama önce yanIış biIinirse doğruya uIaşıIamaz.
