Gönderen Konu: [Çözüldü] Yazılım görsel işleme kipinde çalışıyor  (Okunma sayısı 5030 defa)
merhabalar,
Bilgisayarımı açtığımda yazılımsal görsel işleme kipinde çalışıyor uyarısı alıyorum. Ve ekran çok mat.
Ekran kartı bilgileri;
$ inxi -SGx
System:    Host: bilgiislem Kernel: 3.16.0-51-generic x86_64 (64 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7550M/7570M/7650M]
           bus-ID: 01:00.0
           Display Server: X.Org 1.15.1 drivers: fbdev,ati (unloaded: vesa,radeon)
           Resolution: 1024x768@76.0hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.4, 256 bits)
           GLX Version: 2.1 Mesa 10.1.3 Direct Rendering: Yes
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.4, 256 bits)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Thames [Radeon HD 7550M/7570M/7650M]
Screen 0: minimum 1024 x 768, current 1024 x 768, maximum 1024 x 768
default connected primary 1024x768+0+0 0mm x 0mm
   1024x768       76.0*
inxi -Fx
Machine:   System: Sony product: SVE1513T1EW v: C10GKXWM
           Mobo: Sony model: VAIO Bios: Insyde v: R0170D5 date: 11/14/2012
CPU:       Dual core Intel Core i5-3230M (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10376
           clock speeds: max: 3200 MHz 1: 1390 MHz 2: 1598 MHz 3: 1385 MHz
           4: 1774 MHz
           bus-ID: 01:00.0
Audio:     Card-1 Intel 7 Series/C210 Series Family High Definition Audio Controller
           Card-2 Advanced Micro Devices [AMD/ATI] Turks/Whistler HDMI Audio [Radeon HD 6000 Series]
           Sound: Advanced Linux Sound Architecture v: k3.16.0-51-generic
           driver: ath9k bus-ID: 07:00.0
           IF: wlan0 state: up mac: b8:76:3f:e4:73:ff
           driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 09:00.0
           IF: eth0 state: down mac: 30:f9:ed:d6:b1:58
Drives:    HDD Total Size: 120.0GB (86.7% used)
           ID-1: /dev/sda model: ESA3SMD2HSLB120G size: 120.0GB
Partition: ID-1: / size: 105G used: 92G (93%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 6.39GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 69.0C mobo: N/A
Info:      Processes: 212 Uptime: 5 min Memory: 1333.6/5919.2MB
« Son Düzenleme: 14 Ocak 2016, 13:58:18 Gönderen: mehmethanifi »
Ynt: Yazılım görsel işleme kipinde çalışıyor
« Yanıtla #1 : 14 Ocak 2016, 12:48:43 »
Aşağıdaki komutun çıktısına da bakalım.
dpkg -l | grep fglrx
« Yanıtla #2 : 14 Ocak 2016, 12:49:34 »
rc  fglrx-updates                                               2:15.200-0ubuntu0.5                                 amd64        Video driver for the AMD graphics accelerators
ii  fglrx-updates-core                                          2:15.200-0ubuntu0.5                                 amd64        Minimal video driver for the AMD graphics accelerators
« Yanıtla #3 : 14 Ocak 2016, 12:53:53 »
Fglrx-updates sürücü paketini kaldırıp açık kaynak sürücüleri yeniden kurmamışsınız. Aşağıdaki komutla fglrx-updates paketini yeniden kurabilirsiniz.
sudo aticonfig --initial -f
« Yanıtla #4 : 14 Ocak 2016, 13:00:22 »
Düzeldi Hocam.
« Son Düzenleme: 14 Ocak 2016, 13:57:57 Gönderen: mehmethanifi »
