Gönderen Konu: Performans Karşılaştırmaları  (Okunma sayısı 4188 defa)
Çevrimdışı istanbul
  • İleti: 12
« : 16 Ocak 2016, 21:45:38 »
Taşınabilir bilgisayarında dahili 1gb amd ve harici 2gb amd olan amd 4 çekirdekli 2ghz bilgisarımda aşağıdaki performansları alıyorum bunların hangisi iyidir?
Açık kaynak sürücüsünde
301 frames in 5.0 seconds = 60.132 FPS
301 frames in 5.0 seconds = 60.046 FPS
301 frames in 5.0 seconds = 60.049 FPS
fglrx  Power Saving Mode
9178 frames in 5.0 seconds = 1835.513 FPS
9079 frames in 5.0 seconds = 1815.685 FPS
9171 frames in 5.0 seconds = 1834.137 FPS
fglrx High-Performance mode
8896 frames in 5.0 seconds = 1779.150 FPS
9074 frames in 5.0 seconds = 1814.605 FPS
9057 frames in 5.0 seconds = 1811.398 FPS
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1566
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Mullins [Radeon APU A4-6000 with R2 Graphics] (rev 05)
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 9840
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 156b
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
00:08.0 Encryption controller: Advanced Micro Devices, Inc. [AMD] Device 1537
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 11)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 40)
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 39)
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 39)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 42)
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 02)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
00:14.7 SD Host controller: Advanced Micro Devices, Inc. [AMD] FCH SD Flash Controller (rev 01)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1580
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1581
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1582
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1583
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1584
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1585
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Jet XT [Radeon R5 M240]
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device 5287 (rev 01)
02:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
03:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
fglrx High performance mode ikende aşağıdaki çıktıları aldım.
inxi -SGx
System:    Host: xps Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Desktop: Cinnamon 2.8.6 (Gtk 3.10.8~8+qiana) Distro: Linux Mint 17.3 Rosa
Graphics:  Card-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon APU A4-6000 with R2 Graphics] bus-ID: 00:01.0
           Card-2: Advanced Micro Devices [AMD/ATI] Jet XT [Radeon R5 M240] bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 driver: fglrx Resolution: 1366x768@60.0hz
           GLX Renderer: AMD Radeon R5 Graphics GLX Version: 4.4.13374 - CPC 15.20.1013 Direct Rendering: Yes
OpenGL renderer string: AMD Radeon(TM) R5 Graphics
LVDS connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768       60.0*+
   1360x768       60.0
   1280x768       60.0
   1280x720       60.0
   1024x768       60.0
   800x600        60.0
   720x576        60.0
   848x480        60.0
   720x480        60.0
   640x480        60.0
DFP1 disconnected (normal left inverted right x axis y axis)
CRT1 disconnected (normal left inverted right x axis y axis)
Section "ServerLayout"
Section "Module"
Section "Monitor"
    Option        "VendorName" "ATI Proprietary Driver"
    Option        "ModelName" "Generic Autodetecting Monitor"
    Option        "DPMS" "true"
    Driver      "fglrx"
    BusID       "PCI:0:1:0"
Section "Screen"
    DefaultDepth     24
    SubSection "Display"
        Viewport   0 0
        Depth     24
    EndSubSection
Ynt: Performans Karşılaştırmaları
« Yanıtla #1 : 17 Ocak 2016, 00:37:28 »
Açık kaynak sürücüde dikey senkronizasyon (vsysnc) varsayılan olarak etkin olduğu için 60 FPS üstü alamıyorsunuzdur.
Kapalı kaynak sürücüsünde ise, sürücüler arasında geçiş sonrasında sistemi yeniden başlattığınızdan emin misiniz? Hangi sürücünün etkin olduğunu aşağıdaki komut ile anlayabilirsiniz.
aticonfig --pxl
Çevrimdışı istanbul
  • İleti: 12
« Yanıtla #2 : 17 Ocak 2016, 01:23:44 »
her değişimden sonra bilgisayarı yeniden başlatıp kontrol edip ondan sonra glxgears yapıyorum. Önceki bilgisayarımda nvidia optimus vardı onun üzerine kurmuştum içime sinmedi temiz mint kurulum yaptım. Şimdi değerler tasarruf modu içinde performans modu içinde aşağıdaki gibi oldu. Bu donanımda nasıl bir değer görmeliydim.
302 frames in 5.0 seconds = 60.345 FPS
301 frames in 5.0 seconds = 60.051 FPS
301 frames in 5.0 seconds = 60.041 FPS
301 frames in 5.0 seconds = 60.044 FPS
Ayrıca şuan performans modundayım ama catalyst de bilgiye baktığımda 1GB görünüyor, niye 2gb görünmüyor
« Son Düzenleme: 17 Ocak 2016, 01:36:47 Gönderen: istanbul »
« Yanıtla #3 : 17 Ocak 2016, 02:11:36 »
vblank_mode=0 glxgears
Komutu ile dikey senekronizasyonu pasifleştirerek dener misiniz?
RAM miktarı ile ilgili ayrı bir konu açarsanız, bir öneri olursa cevap verilebilir.
Çevrimdışı istanbul
  • İleti: 12
« Yanıtla #4 : 17 Ocak 2016, 02:26:24 »
değişen birşey olmadı
303 frames in 5.0 seconds = 60.412 FPS
301 frames in 5.0 seconds = 60.016 FPS
301 frames in 5.0 seconds = 60.017 FPS
301 frames in 5.0 seconds = 60.015 FPS
