Gönderen Konu: Hangi Ekran Kartını Almalıyım ?  (Okunma sayısı 4446 defa)
Çevrimdışı Parduser
  • İleti: 2
  • Dağıtım: linux mint
  • İşlemci: ati/amd
« : 18 Ocak 2016, 14:02:56 »
Merhaba arkadaşlar.
Ben bilgisayarımda WoW, Cs:GO, Dota gibi oyunları orta seviyede oynamak istiyorum ama ekran kartlarıyla ilgili fazla bilgim yok  :(. Dolayısıyla hangi ekran kartını almalıyım ya da nasıl seçmeliyim bilgilendirirseniz sevinirim .
Şimdiden teşekkürler.
Ayrıca sudo dmidecode | more çıktısı şu
SMBIOS 2.6 present.
46 structures occupying 1578 bytes.
Table at 0x0009F800.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: V17.10
Release Date: 08/10/2012
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 2048 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 8.15
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: MSI
Product Name: MS-7641
Version: 3.0
Serial Number: To Be Filled By O.E.M.
UUID: 00000000-0000-0000-0000-D43D7E48BE14
Wake-up Type: Power Switch
SKU Number: To Be Filled By O.E.M.
Family: To Be Filled By O.E.M.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: MSI
Product Name: 760GM-P21(FX) (MS-7641)
Version: 3.0
Serial Number: To be filled by O.E.M.
Asset Tag: To Be Filled By O.E.M.
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: To Be Filled By O.E.M.
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Manufacturer: MSI
Type: Desktop
Lock: Not Present
Version: 3.0
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: CPU1
Type: Central Processor
Family: Sempron
Manufacturer: AMD
ID: 63 0F 10 00 FF FB 8B 07
Signature: Family 16, Model 6, Stepping 3
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
Version: AMD Sempron(tm) 145 Processor
Voltage: 1.4 V
External Clock: 200 MHz
Max Speed: 2800 MHz
Current Speed: 2800 MHz
Status: Populated, Disabled By BIOS
Upgrade: Socket AM3
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Part Number: To Be Filled By O.E.M.
Core Count: 1
Core Enabled: 1
Thread Count: 1
Characteristics:
64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 128 kB
Maximum Size: 128 kB
Supported SRAM Types:
Pipeline Burst
Installed SRAM Type: Pipeline Burst
Speed: 1 ns
Error Correction Type: Multi-bit ECC
System Type: Unified
Associativity: 2-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 1024 kB
Maximum Size: 1024 kB
Pipeline Burst
Speed: 1 ns
Associativity: 16-way Set-associative
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3-Cache
Configuration: Enabled, Not Socketed, Level 3
Installed Size: 0 kB
Maximum Size: 0 kB
Pipeline Burst
Speed: 1 ns
Associativity: Other
Handle 0x0008, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: PS1
Internal Connector Type: None
External Reference Designator: PS2 Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0009, DMI type 8, 9 bytes
External Reference Designator: PS2 Keyboard
Port Type: Keyboard Port
Handle 0x000A, DMI type 8, 9 bytes
Internal Reference Designator: COM1
External Reference Designator: COM
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: JACK1
External Reference Designator: Audio Mic In
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x000C, DMI type 8, 9 bytes
External Reference Designator: Audio Line In
Handle 0x000D, DMI type 8, 9 bytes
External Reference Designator: Audio Line Out
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: USB1
External Reference Designator: USB1
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: USB2
Port Type: USB
Handle 0x0010, DMI type 8, 9 bytes
External Reference Designator: USB3
Port Type: USB
Handle 0x0011, DMI type 8, 9 bytes
External Reference Designator: USB4
Port Type: USB
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: LAN
External Reference Designator: LAN
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: JBAT1
Internal Connector Type: Other
External Reference Designator: Not Specified
External Connector Type: None
Port Type: Other
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: CD_IN1
Internal Connector Type: On Board Sound Input From CD-ROM
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: JCI1
Port Type: Other
Handle 0x0016, DMI type 8, 9 bytes
Internal Reference Designator: JUSB1
Port Type: USB
Handle 0x0017, DMI type 8, 9 bytes
Internal Reference Designator: JUSB2
Port Type: USB
Handle 0x0018, DMI type 8, 9 bytes
Internal Reference Designator: JUSB3
Port Type: USB
Handle 0x0019, DMI type 8, 9 bytes
Internal Reference Designator: JFP1
Port Type: Other
Handle 0x001A, DMI type 8, 9 bytes
Internal Reference Designator: JFP2
Port Type: Other
Handle 0x001B, DMI type 8, 9 bytes
Internal Reference Designator: SATA1
Internal Connector Type: SAS/SATA Plug Receptacle
Port Type: SATA
Handle 0x001C, DMI type 8, 9 bytes
Internal Reference Designator: SATA2
Port Type: SATA
Handle 0x001D, DMI type 8, 9 bytes
Internal Reference Designator: SATA3
Port Type: SATA
Handle 0x001E, DMI type 8, 9 bytes
Internal Reference Designator: SATA4
Port Type: SATA
Handle 0x001F, DMI type 8, 9 bytes
Internal Reference Designator: SATA5
Port Type: SATA
Handle 0x0020, DMI type 8, 9 bytes
Internal Reference Designator: SATA6
Port Type: SATA
Handle 0x0021, DMI type 9, 17 bytes
System Slot Information
Designation: PCIE1
Type: x1 PCI Express
Current Usage: In Use
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Bus Address: 0000:01:05.0
Handle 0x0022, DMI type 9, 17 bytes
Designation: PCIE2
Type: x16 PCI Express
Current Usage: Available
Length: Long
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:00:00.0
Handle 0x0023, DMI type 9, 17 bytes
Designation: PCI1
Type: 32-bit PCI
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0024, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 1
en|US|iso8859-1
Currently Installed Language: en|US|iso8859-1
Handle 0x0025, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 8 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x0026, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0012FFFFFFF
Range Size: 4864 MB
Physical Array Handle: 0x0025
Partition Width: 1
Handle 0x0027, DMI type 17, 28 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM1
Bank Locator: BANK0
Type: Other
Type Detail: Synchronous
Speed: 1066 MHz
Manufacturer: Manufacturer00
Serial Number: 00000000
Asset Tag: AssetTagNum0
Part Number: F3-10666CL9-4GBNT0
Rank: Unknown
Handle 0x0028, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Device Handle: 0x0027
Memory Array Mapped Address Handle: 0x0026
Partition Row Position: 1
Handle 0x0029, DMI type 17, 28 bytes
Memory Device
Total Width: Unknown
Data Width: 64 bits
Size: No Module Installed
Form Factor: Other
Set: None
Locator: DIMM2
Bank Locator: BANK1
Type: Unknown
Type Detail: None
Speed: Unknown
Manufacturer: Manufacturer01
Serial Number: SerNum01
Asset Tag: AssetTagNum1
Part Number: ModulePartNumber01
Rank: Unknown
Handle 0x002A, DMI type 126, 19 bytes
Inactive
Handle 0x002B, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x002C, DMI type 41, 11 bytes
Onboard Device
Reference Designation:   To Be Filled By O.E.M.
Type: Video
Status: Enabled
Type Instance: 0
Handle 0x002D, DMI type 127, 4 bytes
End Of Table
« Son Düzenleme: 18 Ocak 2016, 14:04:37 Gönderen: Parduser »
Ynt: Hangi Ekran Kartını Almalıyım ?
« Yanıtla #1 : 18 Ocak 2016, 14:54:18 »
WoW, Cs:GO, Dota
Bu oyunlar için öyle abartılı ekran kartı almanıza gerek yok. Piyasadaki fiyat / performans değeri yüksek ürünlerden biri işinizi görecektir. Kendi adıma Linux tarafında daha uzun destek süresine sahip olduğu için Nvidia GPU tavsiye edebilirim.
Çevrimdışı Parduser
  • İleti: 2
  • İşlemci: ati/amd
« Yanıtla #2 : 18 Ocak 2016, 15:17:25 »
sizce bu ekran kartı iyi mi?
https://www.msi.com/product/graphics-card/N730-2GD3.html#hero-overview
ve driverı bulunur mu bu ekran kartının ?
« Son Düzenleme: 18 Ocak 2016, 15:49:48 Gönderen: Parduser »
