Merhabalar. Parola kutucuğunun sağ üst köşede C2 seçtim sonra default seçip tekrar giriş yaptım ama kasma sorunum düzelmedi.
System: Host: Cagdas Kernel: 4.2.0-27-generic x86_64 (64 bit gcc: 4.8.2)
Distro: Linux Mint 17.3 Rosa
Machine: System: Sony product: SVE1513Q1ESI v: C10GPZK6
Mobo: Sony model: VAIO Bios: Insyde v: R0170D5 date: 11/14/2012
CPU: Dual core Intel Core i5-3230M (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10376
clock speeds: max: 3200 MHz 1: 2965 MHz 2: 2999 MHz 3: 3001 MHz
4: 2999 MHz
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller
Resolution: 1366x768@60.0hz
GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.6, 256 bits)
Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.2.0-27-generic
Network: Card-1: Qualcomm Atheros AR9485 Wireless Network Adapter
driver: ath9k bus-ID: 01:00.0
driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 03:00.0
Drives: HDD Total Size: 750.2GB (9.6% used)
ID-1: /dev/sda model: TOSHIBA_MQ01ABD0 size: 750.2GB
Partition: ID-1: / size: 684G used: 64G (10%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 4.17GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 67.0C mobo: N/A
Info: Processes: 186 Uptime: 23 min Memory: 875.2/3831.4MB
cagdas@Cagdas ~ $ cat /etc/mdm/mdm.conf
# MDM Configuration file.
# This file is the appropriate place for specifying your customizations to the
# MDM configuration. If you run mdmsetup, it will automatically edit this
# file for you and will cause the daemon and any running MDM GUI programs to
# automatically update with the new configuration. Not all configuration
# options are supported by mdmsetup, so to modify some values it may be
# necessary to modify this file directly by hand.
# This file overrides the default configuration settings. These settings
# are stored in the MDM System Defaults configuration file, which is found
# at the following location.
# /usr/share/mdm/defaults.conf.
# Default settings are first overriden by you distribution in /usr/share/mdm/distro.conf
# and then by the settings present in this file.
# This file contains comments about the meaning of each configuration option,
# so is also a useful reference. In short, to hand-edit
# this file, simply add or modify the key=value combination in the
# appropriate section in the template below this comment section.
# For example, if you want to specify a different value for the Enable key
# in the "[debug]" section of your MDM System Defaults configuration file,
# then add "Enable=true" in the "[debug]" section of this file. If the
# key already exists in this file, then simply modify it.
# If you hand edit a MDM configuration file, you can run the following
# command and the MDM daemon will immediately reflect the change. Any
# running MDM GUI programs will also be notified to update with the new
# configuration.
# mdmflexiserver --command="UPDATE_CONFIG <configuration key>"
# e.g, the "Enable" key in the "[debug]" section would be "debug/Enable".
# You can also run mdm-restart or mdm-safe-restart to cause MDM to restart and
# re-read the new configuration settings. You can also restart MDM by sending
# a HUP or USR1 signal to the daemon. HUP behaves like mdm-restart and causes
# any user session started by MDM to exit immediately while USR1 behaves like
# mdm-safe-restart and will wait until all users log out before restarting MDM.
# NOTE: Lines that begin with "#" are considered comments.
# Have fun!
[daemon]
[security]
[xdmcp]
[gui]
[greeter]
[chooser]
[debug]
# Note that to disable servers defined in the MDM System Defaults
# configuration file (such as 0=Standard, you must put a line in this file
# that says 0=inactive, as described in the Configuration section of the MDM
# documentation.
[servers]
# Also note, that if you redefine a [server-foo] section, then MDM will
# use the definition in this file, not the MDM System Defaults configuration
# file. It is currently not possible to disable a [server-foo] section
# defined in the MDM System Defaults configuration file.
