Gönderen Konu: [Çözüldü] Bumblebee Sorunum (GeForce GTX 860M)  (Okunma sayısı 6969 defa)
Çevrimdışı minimin
  • İleti: 12
  • Dağıtım: mint
  • Masaüstü Ortamı: mate
  • Grafik Kartı: gtx860m
« : 17 Nisan 2016, 11:28:32 »
Sürücüleri silip kurdum olmadı, bumblebee.conf ta kernel driverı nvidia, nvidia-current, nvidia-361 olarak denedim olmadı yardım edebilir msiniz?
Linux Mint 17.3 Mate
sudo optirun glxgears
[  367.858725] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.socket was incorrect.
[  367.858739] [ERROR]Could not connect to bumblebee daemon - is it running?
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 860M] (rev a2)
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-361
PMMethod=auto
LibraryPath=/usr/lib/nvidia-361:/usr/lib32/nvidia-361
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-361/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
ii  bumblebee                                   3.2.1-93~trustyppa1                                 amd64        NVIDIA Optimus support
ii  bumblebee-nvidia                            3.2.1-93~trustyppa1                                 amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
rc  nvidia-304                                  304.131-0ubuntu0.14.04.1                            amd64        NVIDIA legacy binary driver - version 304.131
ii  nvidia-361                                  361.42-0ubuntu0~gpu14.04.1                          amd64        NVIDIA binary driver - version 361.42
ii  nvidia-settings                             364.15-0ubuntu0~gpu14.04.1                          amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20150328-1~trustyppa1                               amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20150328-1~trustyppa1                               amd64        Shared libraries for primus
ii  primus-libs:i386                            20150328-1~trustyppa1                               i386         Shared libraries for primus
ii  primus-libs-ia32                            20150328-1~trustyppa1                               i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.4.1-1~trustyppa1                                  amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.4.1-1~trustyppa1                                  amd64        Library files for virtualgl
Düzenleme: Yazım. Başlık düzenlendi.
karakartala
« Son Düzenleme: 17 Nisan 2016, 19:09:18 Gönderen: minimin »
Ynt: bumblebee sorunum
« Yanıtla #1 : 17 Nisan 2016, 15:49:55 »
Çevrimdışı minimin
  • İleti: 12
  • Dağıtım: mint
« Yanıtla #2 : 17 Nisan 2016, 16:12:45 »
Ynt: Bumblebee Sorunum (GeForce GTX 860M)
« Yanıtla #3 : 17 Nisan 2016, 16:18:32 »
Komutların çıktısına bakalım.
inxi -SGx
optirun -vvv glxgears
Çevrimdışı minimin
  • İleti: 12
  • Dağıtım: mint
« Yanıtla #4 : 17 Nisan 2016, 16:29:00 »
inxi -SGx
inxi -SGx
System:    Host: moon Kernel: 4.5.1-040501-generic x86_64 (64 bit gcc: 5.2.1)
           Distro: Linux Mint 17.3 Rosa
           Card-2: NVIDIA GM107M [GeForce GTX 860M] bus-ID: 01:00.0
           Resolution: 1920x1080@60.0hz
[18790.028194] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[18790.028377] [INFO]Configured driver: nvidia
[18790.028406] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.socket was incorrect.
[18790.028409] [DEBUG]Socket closed.
[18790.028414] [ERROR]Could not connect to bumblebee daemon - is it running
« Yanıtla #5 : 17 Nisan 2016, 18:12:03 »
Aşağıdaki komutu uçbirimde çalıştırıp çıktısını paylaşınız.
Çevrimdışı minimin
  • İleti: 12
  • Dağıtım: mint
« Yanıtla #6 : 17 Nisan 2016, 18:26:51 »
stop: Unknown instance:
bumblebeed start/running, process 4884
bu arada virtualbox başlatmada sorun yaşıyorum kernel ile ilgili,
sanırım şuan ki kernel sistemde sorun yaratıyor ilk kurduğumda 3.19du.
şimdi yeniden kurulum yapıcam. sormak istediğim linux mint 18 çıktığında  programlarımın ve yapılandırmalaraının kaybetmek istemiyorum.  hazır tekrardan kurulum yapacakken ilerdeki güncellemede sorun yaşamamak için sadece /home klasörünü ayırmam yeterli mi
« Yanıtla #7 : 17 Nisan 2016, 18:59:01 »
Aynı konu içinde birden fazla soru ve sorun hakkında konuşmuyoruz. Bu konunun kapsamı dışına çıkmayalım.
Güncelleme Yönetici => Görünüm menüsü => Linux çekirdekleri bölümünden depodaki en güncel çekirdeği (şu an 4.4.0-18 sürüm) kurup sistemi bununla açamayı deneyebilirsiniz.
