Gönderen Konu: Kyk Portal Bağlantının Sürekli Kopması  (Okunma sayısı 3166 defa)
Çevrimdışı nemesis
  • İleti: 14
  • Dağıtım: Linux Mint Cinnamon 17.2
  • Masaüstü Ortamı: Windows 8.1
  • Grafik Kartı: Gt 840M
  • İşlemci: i5 4210u
« : 20 Nisan 2016, 22:47:46 »
Merhaba Arkadaşlar, yurtta kalıyorum linux mint ve windows yükledim. Linux mint'ten çok memnunum. Biraz nazlı kız gibi tribi bol. Ben alttan alıyrum tabii. Kyk portal'a bağlandktan sonra sürekli olarak kopma oluyor. Çıktılar bunlar.
System:    Host: Borderless Kernel: 4.0.9-040009-generic x86_64 (64 bit gcc: 4.8.4)
           Desktop: KDE Plasma 4.14.13 (Qt 4.8.6) Distro: Linux Mint 17.3 Rosa
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 02:00.0
           Card-2: Broadcom BCM43142 802.11b/g/n driver: wl bus-ID: 03:00.0
Borderless border # lspci -nnk | grep -iA2 net
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 10)
        Subsystem: ASUSTeK Computer Inc. Device [1043:200f]
        Kernel driver in use: r8169
03:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
        Subsystem: Lite-On Communications Inc Device [11ad:6675]
        Kernel driver in use: wl
Borderless border # lsusb
Bus 003 Device 003: ID 09da:054f A4Tech Co., Ltd.
Bus 003 Device 002: ID 8087:8000 Intel Corp.
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 0bda:57b5 Realtek Semiconductor Corp.
Borderless border # rfkill list
1: asus-wlan: Wireless LAN
        Soft blocked: no
        Hard blocked: no
2: asus-bluetooth: Bluetooth
        Soft blocked: yes
        Hard blocked: no
3: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
4: brcmwl-0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
Borderless border # sudo lshw -C network
  *-network
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 10
       serial: 78:24:af:b8:ba:65
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-3_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:45 ioport:e000(size=256) memory:f7904000-f7904fff memory:f7900000-f7903fff
  *-network
       product: BCM43142 802.11b/g/n
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlan0
       version: 01
       serial: 18:cf:5e:63:2d:ea
       width: 64 bits
       clock: 33MHz
       configuration: broadcast=yes driver=wl0 driverversion=6.30.223.248 (r487574) ip=192.168.43.33 latency=0 multicast=yes wireless=IEEE 802.11abg
       resources: irq:19 memory:f7800000-f7807fff
Borderless border # iwconfig | grep Power
          Bit Rate=72 Mb/s   Tx-Power=200 dBm
          Power Management:off
Borderless border # lsmod
bbswitch               16384  0
ip6t_REJECT            16384  1
nf_log_ipv6            16384  5
xt_hl                  16384  6
nf_conntrack_ipv6      20480  8
nf_defrag_ipv6         36864  1 nf_conntrack_ipv6
ipt_REJECT             16384  1
rfcomm                 69632  0
nf_log_ipv4            16384  5
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  10
xt_limit               16384  13
xt_tcpudp              16384  18
nf_conntrack_ipv4      16384  8
xt_conntrack           16384  16
wl                   6369280  0
ip6_tables             28672  1 ip6table_filter
iosf_mbi               16384  1 intel_rapl
asus_nb_wmi            24576  0
asus_wmi               24576  1 asus_nb_wmi
mxm_wmi                16384  0
sparse_keymap          16384  1 asus_wmi
intel_powerclamp       20480  0
nf_nat                 24576  1 nf_nat_ftp
nf_conntrack_ftp       20480  1 nf_nat_ftp
videobuf2_core         53248  1 uvcvideo
kvm_intel             155648  0
nf_conntrack          106496  8 nf_nat_ftp,nf_conntrack_netbios_ns,nf_nat,xt_conntrack,nf_conntrack_broadcast,nf_conntrack_ftp,nf_conntrack_ipv4,nf_conntrack_ipv6
ip_tables              28672  1 iptable_filter
rtsx_usb_ms            20480  0
v4l2_common            16384  1 videobuf2_core
kvm                   495616  1 kvm_intel
videodev              159744  3 uvcvideo,v4l2_common,videobuf2_core
memstick               20480  1 rtsx_usb_ms
x_tables               36864  13 ip6table_filter,xt_hl,ip_tables,xt_tcpudp,xt_limit,xt_conntrack,xt_LOG,iptable_filter,ip6t_rt,ipt_REJECT,ip6_tables,xt_addrtype,ip6t_REJECT
bluetooth             499712  11 bnep,btusb,rfcomm
aesni_intel           172032  0
cfg80211              548864  1 wl
snd_hda_codec_realtek    77824  1
snd_hda_codec_generic    69632  1 snd_hda_codec_realtek
snd_soc_rt5640         94208  0
snd_hda_intel          32768  5
cryptd                 20480  3 ghash_clmulni_intel,aesni_intel,ablk_helper
snd_soc_rl6231         16384  1 snd_soc_rt5640
snd_soc_core          196608  1 snd_soc_rt5640
snd_hda_codec         143360  5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
snd_compress           20480  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm               106496  7 snd_soc_rt5640,snd_soc_core,snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller,snd_pcm_dmaengine
wmi                    20480  2 mxm_wmi,asus_wmi
i2c_hid                20480  0
dw_dmac                16384  0
dw_dmac_core           28672  1 dw_dmac
shpchp                 40960  0
spi_pxa2xx_platform    24576  0
snd                    86016  23 snd_hda_codec_realtek,snd_soc_core,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_compress
snd_soc_sst_acpi       16384  0
mei_me                 20480  0
mei                    90112  1 mei_me
i2c_designware_platform    16384  0
8250_dw                16384  0
i2c_designware_core    16384  1 i2c_designware_platform
int3402_thermal        16384  0
processor_thermal_device    16384  0
int340x_thermal_zone    16384  2 int3402_thermal,processor_thermal_device
int3400_thermal        16384  0
acpi_thermal_rel       16384  1 int3400_thermal
rtsx_usb_sdmmc         28672  0
rtsx_usb               24576  2 rtsx_usb_sdmmc,rtsx_usb_ms
hid                   110592  3 i2c_hid,hid_generic,usbhid
i915                 1073152  5
drm_kms_helper        126976  1 i915
psmouse               122880  0
drm                   344064  6 i915,drm_kms_helper
video                  20480  2 i915,asus_wmi
sdhci_acpi             16384  0
sdhci                  45056  1 sdhci_acpi
Yardımcı olabilir misiniz?
Ynt: Kyk Portal Bağlantının Sürekli Kopması
« Yanıtla #1 : 20 Nisan 2016, 23:02:36 »
Aşağıdaki komutu uçbirimde çalıştırıp sistemi yeniden başlatmayı dener misiniz?
echo "lib80211_crypt_tkip" | sudo tee -a /etc/modules
Çevrimdışı nemesis
  • İleti: 14
  • İşlemci: i5 4210u
« Yanıtla #2 : 22 Nisan 2016, 17:52:48 »
Ne yazık ki işe yaramadı. Ama şunu belirtmek isterim ki telefonun hotspot'una sorunsuz bağlanıyor.
« Yanıtla #3 : 22 Nisan 2016, 21:53:45 »
Aşağıdaki komutlar sürücünün güncel bir sürümünü kurmak denenebilir.
sudo add-apt-repository ppa:longsleep/bcmwl
sudo apt-get install bcmwl-kernel-source
Çevrimdışı nemesis
  • İleti: 14
  • İşlemci: i5 4210u
« Yanıtla #4 : 23 Nisan 2016, 00:37:54 »
Borderless border # sudo add-apt-repository ppa:longsleep/bmcwl
"Bu PPA'n\xc4\xb1n trusty deste\xc4\x9fi yok"
PPA eklenemiyor: '"Bu PPA'n\xc4\xb1n trusty deste\xc4\x9fi yok"'.
Borderless border # sudo apt-get update
Yoksay    http://ppa.launchpad.net trusty InRelease
Yoksay    http://mirror.unlockforus.com rosa InRelease
Alınıyor: 1 http://security.ubuntu.com trusty-security InRelease [65,9 kB]
Yoksay    http://archive.canonical.com trusty InRelease
Yoksay    http://extra.linuxmint.com rosa InRelease
Bağlandı  http://ppa.launchpad.net trusty InRelease
Bağlandı  http://mirror.unlockforus.com rosa Release.gpg
Bağlandı  http://archive.canonical.com trusty Release.gpg
Bağlandı  http://extra.linuxmint.com rosa Release.gpg
Bağlandı  http://mirror.unlockforus.com rosa/main amd64 Packages
Alınıyor: 2 http://security.ubuntu.com trusty-security/main amd64 Packages [458 kB]
Bağlandı  http://archive.canonical.com trusty/partner amd64 Packages
Bağlandı  http://mirror.unlockforus.com rosa/upstream amd64 Packages
Bağlandı  http://mirror.unlockforus.com rosa/import amd64 Packages
Yoksay    http://ubuntu.gnu.gen.tr trusty InRelease
Bağlandı  http://archive.canonical.com trusty/partner i386 Packages
Alınıyor: 3 http://ubuntu.gnu.gen.tr trusty-updates InRelease [65,9 kB]
Bağlandı  http://ppa.launchpad.net trusty Release.gpg
Bağlandı  http://mirror.unlockforus.com rosa/main i386 Packages
Bağlandı  http://archive.canonical.com trusty/partner Translation-en
Bağlandı  http://ppa.launchpad.net trusty/main Sources
Bağlandı  http://mirror.unlockforus.com rosa/upstream i386 Packages
Bağlandı  http://extra.linuxmint.com rosa/main amd64 Packages
Bağlandı  http://ubuntu.gnu.gen.tr trusty Release.gpg
Bağlandı  http://ppa.launchpad.net trusty/main amd64 Packages
Bağlandı  http://mirror.unlockforus.com rosa/import i386 Packages
Alınıyor: 4 http://ubuntu.gnu.gen.tr trusty-updates/main amd64 Packages [755 kB]
Bağlandı  http://ppa.launchpad.net trusty/main i386 Packages
Bağlandı  http://ppa.launchpad.net trusty/main Translation-en
Bağlandı  http://extra.linuxmint.com rosa/main i386 Packages
Alınıyor: 5 http://security.ubuntu.com trusty-security/restricted amd64 Packages [13,0 kB]
Alınıyor: 6 http://security.ubuntu.com trusty-security/universe amd64 Packages [127 kB]
Alınıyor: 7 http://security.ubuntu.com trusty-security/multiverse amd64 Packages [4.982 B]
Alınıyor: 8 http://security.ubuntu.com trusty-security/main i386 Packages [431 kB]
Alınıyor: 9 http://ubuntu.gnu.gen.tr trusty-updates/restricted amd64 Packages [15,9 kB]
Alınıyor: 10 http://ubuntu.gnu.gen.tr trusty-updates/universe amd64 Packages [358 kB]
Alınıyor: 11 http://security.ubuntu.com trusty-security/restricted i386 Packages [12,7 kB]
Alınıyor: 12 http://ubuntu.gnu.gen.tr trusty-updates/multiverse amd64 Packages [13,2 kB]
Alınıyor: 13 http://security.ubuntu.com trusty-security/universe i386 Packages [126 kB]
Alınıyor: 14 http://ubuntu.gnu.gen.tr trusty-updates/main i386 Packages [723 kB]
Alınıyor: 15 http://security.ubuntu.com trusty-security/multiverse i386 Packages [5.172 B]
Alınıyor: 16 http://security.ubuntu.com trusty-security/main Translation-en [251 kB]
Alınıyor: 17 http://ubuntu.gnu.gen.tr trusty-updates/restricted i386 Packages [15,6 kB]
Alınıyor: 18 http://security.ubuntu.com trusty-security/multiverse Translation-en [2.570 B]
Alınıyor: 19 http://ubuntu.gnu.gen.tr trusty-updates/universe i386 Packages [359 kB]
Alınıyor: 20 http://security.ubuntu.com trusty-security/restricted Translation-en [3.206 B]
Alınıyor: 21 http://security.ubuntu.com trusty-security/universe Translation-en [74,7 kB]
Alınıyor: 22 http://ubuntu.gnu.gen.tr trusty-updates/multiverse i386 Packages [13,6 kB]
Alınıyor: 23 http://ubuntu.gnu.gen.tr trusty-updates/main Translation-en [377 kB]
Alınıyor: 24 http://ubuntu.gnu.gen.tr trusty-updates/multiverse Translation-en [7.227 B]
Alınıyor: 25 http://ubuntu.gnu.gen.tr trusty-updates/restricted Translation-en [3.699 B]
Yoksay    http://extra.linuxmint.com rosa/main Translation-tr_TR
Alınıyor: 26 http://ubuntu.gnu.gen.tr trusty-updates/universe Translation-en [188 kB]
Bağlandı  http://ubuntu.gnu.gen.tr trusty/main amd64 Packages
Yoksay    http://extra.linuxmint.com rosa/main Translation-en
Bağlandı  http://ubuntu.gnu.gen.tr trusty/restricted amd64 Packages
Bağlandı  http://ubuntu.gnu.gen.tr trusty/universe amd64 Packages
Bağlandı  http://ubuntu.gnu.gen.tr trusty/multiverse amd64 Packages
Bağlandı  http://ubuntu.gnu.gen.tr trusty/main i386 Packages
Bağlandı  http://ubuntu.gnu.gen.tr trusty/restricted i386 Packages
Bağlandı  http://ubuntu.gnu.gen.tr trusty/universe i386 Packages
Bağlandı  http://ubuntu.gnu.gen.tr trusty/multiverse i386 Packages
Bağlandı  http://ubuntu.gnu.gen.tr trusty/main Translation-tr
Bağlandı  http://ubuntu.gnu.gen.tr trusty/main Translation-en
Bağlandı  http://ubuntu.gnu.gen.tr trusty/multiverse Translation-tr
Bağlandı  http://ubuntu.gnu.gen.tr trusty/multiverse Translation-en
Yoksay    http://mirror.unlockforus.com rosa/import Translation-tr_TR
Bağlandı  http://ubuntu.gnu.gen.tr trusty/restricted Translation-tr
Bağlandı  http://ubuntu.gnu.gen.tr trusty/restricted Translation-en
Yoksay    http://mirror.unlockforus.com rosa/import Translation-en
Bağlandı  http://ubuntu.gnu.gen.tr trusty/universe Translation-tr
Yoksay    http://mirror.unlockforus.com rosa/main Translation-tr_TR
Bağlandı  http://ubuntu.gnu.gen.tr trusty/universe Translation-en
Yoksay    http://mirror.unlockforus.com rosa/main Translation-en
Yoksay    http://mirror.unlockforus.com rosa/upstream Translation-tr_TR
Yoksay    http://mirror.unlockforus.com rosa/upstream Translation-en
Yoksay    http://ubuntu.gnu.gen.tr trusty/main Translation-tr_TR
Yoksay    http://ubuntu.gnu.gen.tr trusty/multiverse Translation-tr_TR
Yoksay    http://ubuntu.gnu.gen.tr trusty/restricted Translation-tr_TR
Yoksay    http://ubuntu.gnu.gen.tr trusty/universe Translation-tr_TR
11 sn.'de 4.470 kB alındı (403 kB/s)
Borderless border # sudo apt-get install bmcwl-kernel-source
E: bmcwl-kernel-source paketi bulunamadı
çıktılar bunlar ve bir hareket yok gibi hocam.
« Yanıtla #5 : 23 Nisan 2016, 02:09:59 »
Aşağıdaki komutlarla deneyiniz.
sudo apt-get install bcmwl-kernel-source=6.30.223.271+bdcom-1longsleep0
« Son Düzenleme: 23 Nisan 2016, 02:15:30 Gönderen: Butterfly »
