Gönderen Konu: Ralink RT2870/RT3070 Wireless Adapteri Yüklenmiyor  (Okunma sayısı 4223 defa)
Çevrimdışı kontiki
  • İleti: 17
  • Dağıtım: linux mint 17,3 Rosa 32 bit
  • Masaüstü Ortamı: Mate 1.12.0
  • İşlemci: Intel® Atom™ CPU Z520 @ 1.33GHz × 2
Sn Butterfly; Yukarıda yazılı harici adaptörü. CD'si olmasına rağmen sisteme tanıtamadım. Cd içindeki /home/ceyhun/Masaüstü/RT3070_LinuxSTA_V2.3.0.1_20100208.tar.bz2 Dosyasını çalıştıramadım. Bu nedenle yardım rica ediyorum. Çıktılar şöyledir:
ceyhun@desktop ~ $ inxi -SNx
System:    Host: desktop Kernel: 3.19.0-32-generic i686 (32 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Network:   Card-1: Broadcom NetXtreme BCM5788 Gigabit Ethernet
           driver: tg3 v: 3.137 bus-ID: 02:01.0
           Card-2: Broadcom BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller
           driver: b43-pci-bridge bus-ID: 02:02.0
           Card-3: Ralink RT2870/RT3070 Wireless Adapter
           driver: rt2800usb v: 2.3.0 usb-ID: 001-004
ceyhun@desktop ~ $ lspci -nnk | grep -iA2 net
02:01.0 Ethernet controller [0200]: Broadcom Corporation NetXtreme BCM5788 Gigabit Ethernet [14e4:169c] (rev 03)
Subsystem: Hewlett-Packard Company MX6125 [103c:308b]
Kernel driver in use: tg3
02:02.0 Network controller [0280]: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller [14e4:4318] (rev 02)
Subsystem: Hewlett-Packard Company Broadcom 802.11b/g WLAN [103c:1356]
Kernel driver in use: b43-pci-bridge
ceyhun@desktop ~ $ lsusb
Bus 001 Device 004: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 003 Device 003: ID 1c4f:0032 SiGma Micro
Bus 003 Device 002: ID 08ff:2580 AuthenTec, Inc. AES2501 Fingerprint Sensor
Bus 002 Device 002: ID 03f0:171d Hewlett-Packard Bluetooth 2.0 Interface [Broadcom BCM2045]
ceyhun@desktop ~ $ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
ceyhun@desktop ~ $ sudo lshw -C network
[sudo] password for ceyhun:
Üzgünüm, yeniden deneyin.
  *-network:0      er
       açıklama: Eternet interface
       ürün: NetXtreme BCM5788 Gigabit Ethernet
       üretici: Broadcom Corporation
       physical id: 1
       bus info: pci@0000:02:01.0
       mantıksal ad: eth0
       sürüm: 03
       serial: 00:16:d4:05:54:95
       kapasite: 1Gbit/s
       genişlik: 32 bits
       saat: 66MHz
       kapasiteler: pm vpd msi bus_master cap_list eternet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       yapılandırma: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 firmware=5788-v3.26 latency=64 link=no mingnt=64 multicast=yes port=twisted pair
       kaynaklar: irq:23 bellek:d0000000-d000ffff
  *-network:1
       açıklama: Network controller
       ürün: BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller
       physical id: 2
       bus info: pci@0000:02:02.0
       sürüm: 02
       genişlik: 32 bits
       saat: 33MHz
       kapasiteler: bus_master
       yapılandırma: driver=b43-pci-bridge latency=64
       kaynaklar: irq:22 bellek:d0010000-d0011fff
  *-network:0
       açıklama: Kablosuz arayüz
       physical id: 1
       mantıksal ad: wlan0
       serial: 00:14:a5:a5:4e:8f
       yapılandırma: broadcast=yes driver=b43 driverversion=3.19.0-32-generic firmware=666.2 ip=192.168.0.11 link=yes multicast=yes wireless=IEEE 802.11bg
  *-network:1
       physical id: 2
       bus info: usb@1:5
       mantıksal ad: wlan1
       serial: 00:e0:4c:63:03:87
       yapılandırma: broadcast=yes driver=rt2800usb driverversion=3.19.0-32-generic firmware=0.29 link=no multicast=yes wireless=IEEE 802.11bgn
ceyhun@desktop ~ $ iwconfig | grep Power
          Bit Rate=54 Mb/s   Tx-Power=20 dBm
          Power Management:off
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
ceyhun@desktop ~ $ lsmod
nls_utf8               16384  1
isofs                  40960  1
ctr                    16384  2
ccm                    20480  2
ip6t_REJECT            16384  1
nf_log_ipv6            16384  10
xt_hl                  16384  6
nf_conntrack_ipv6      20480  8
nf_defrag_ipv6         28672  1 nf_conntrack_ipv6
ipt_REJECT             16384  1
nf_log_ipv4            16384  10
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  20
xt_limit               16384  3
xt_tcpudp              16384  18
rfcomm                 61440  12
nf_conntrack_ipv4      16384  8
xt_conntrack           16384  16
snd_atiixp_modem       20480  0
snd_atiixp             20480  2
snd_ac97_codec        106496  2 snd_atiixp_modem,snd_atiixp
ip6_tables             20480  1 ip6table_filter
ac97_bus               16384  1 snd_ac97_codec
arc4                   16384  4
snd_pcm                94208  3 snd_ac97_codec,snd_atiixp_modem,snd_atiixp
nf_nat                 24576  1 nf_nat_ftp
nf_conntrack_ftp       16384  1 nf_nat_ftp
rt2800usb              28672  0
nf_conntrack           90112  8 nf_nat_ftp,nf_conntrack_netbios_ns,nf_nat,xt_conntrack,nf_conntrack_broadcast,nf_conntrack_ftp,nf_conntrack_ipv4,nf_conntrack_ipv6
rt2x00usb              20480  1 rt2800usb
b43                   397312  0
rt2800lib              86016  1 rt2800usb
ip_tables              20480  1 iptable_filter
x_tables               24576  13 ip6table_filter,xt_hl,ip_tables,xt_tcpudp,xt_limit,xt_conntrack,xt_LOG,iptable_filter,ip6t_rt,ipt_REJECT,ip6_tables,xt_addrtype,ip6t_REJECT
rt2x00lib              49152  3 rt2x00usb,rt2800lib,rt2800usb
pcmcia                 53248  0
bcma                   49152  1 b43
crc_ccitt              16384  1 rt2800lib
snd_timer              28672  2 snd_pcm,snd_seq
mac80211              618496  4 b43,rt2x00lib,rt2x00usb,rt2800lib
k8temp                 16384  0
snd                    69632  12 snd_ac97_codec,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_seq_device,snd_atiixp_modem,snd_atiixp
edac_core              49152  0
cfg80211              450560  3 b43,mac80211,rt2x00lib
scsi_dh                16384  1 dm_multipath
edac_mce_amd           24576  0
yenta_socket           40960  0
pcmcia_rsrc            20480  1 yenta_socket
tifm_7xx1              16384  0
tifm_core              16384  1 tifm_7xx1
pcmcia_core            24576  3 pcmcia,pcmcia_rsrc,yenta_socket
btusb                  32768  0
bluetooth             430080  22 bnep,btusb,rfcomm
i2c_piix4              20480  0
tpm_infineon           20480  0
lp                     16384  0
parport                40960  3 lp,ppdev,parport_pc
hid                    98304  2 hid_generic,usbhid
radeon               1425408  2
i2c_algo_bit           16384  1 radeon
ttm                    86016  1 radeon
tg3                   159744  0
firewire_ohci          36864  0
sdhci_pci              20480  0
drm_kms_helper        114688  1 radeon
firewire_core          65536  1 firewire_ohci
psmouse               102400  0
ptp                    20480  1 tg3
sdhci                  45056  1 sdhci_pci
drm                   286720  5 ttm,drm_kms_helper,radeon
pps_core               20480  1 ptp
pata_atiixp            16384  3
ssb                    57344  1 b43
crc_itu_t              16384  1 firewire_core
wmi                    20480  1 hp_wmi
ati_agp                16384  0
video                  20480  0
ceyhun@desktop ~ $
Yardımlarınız için şimdiden teşekkürler...
« Son Düzenleme: 25 Nisan 2016, 17:35:26 Gönderen: kontiki »
Ynt: Ralink RT2870/RT3070 Wireless Adapteri Yüklenmiyor
« Yanıtla #1 : 26 Nisan 2016, 13:09:38 »
Güncelleme Yöneticisi => Görünüm  menüsü => Linux çekirdekleri aracı yardımıyla, 4.4..x serisi çekirdeğin en son sürümünü kurup sistemi yeniden başlatmayı dener misiniz?
Çevrimdışı kontiki
  • İleti: 17
« Yanıtla #2 : 27 Nisan 2016, 21:00:35 »
Sn. Butterfly görünüm menüsünde bulunan  4.4.0-21 Linux çekirdeğini yükleyerek yeniden başlattım fakat adaptörü görmedi... Bilginize
« Yanıtla #3 : 28 Nisan 2016, 08:37:09 »
  *-network:1
       physical id: 2
       bus info: usb@1:5
       mantıksal ad: wlan1
İlk verdiğiniz çıktılarda dahi kablosuz ağ aygıtının tanındığı görünüyor. Bağlantı sorunları olma ihtimalini düşünerek güncelleme önerisi sunmuştum. Ağ ayarlarında USB Wifi görünüyor mu kontrol eder misiniz?
« Son Düzenleme: 28 Nisan 2016, 08:38:42 Gönderen: Butterfly »
Çevrimdışı kontiki
  • İleti: 17
« Yanıtla #4 : 28 Nisan 2016, 12:20:59 »
Sn Butterfly ilginiz için tşk.ederim... Bu sabah linux mate yüklü bilgisayarımı açmak istediğimde 4.4.0-21 generic ve 3.19.032 generic olmak üzere iki tercih gördüm her iki sistemi de (recover modları dahil olmak üzere) çalıştırmayı denedim. açılmadı! Recovery modlarda /dev/sda1/ hatalı dosya sistem içeriyor mesajı verdi. hatta FSCK yapınız gibi bir mesaj da aldım. ( bu satırları bir başka dizüstünden yazıyorum) sanırım. 4.4.0-21 generic benim bilgisayarımı kasıyor ve başlatmıyor. Dosya bilgilerimi yüklememiştim. sanırım Format atmak zorunda (mı) kalacağım?.
« Yanıtla #5 : 28 Nisan 2016, 12:35:44 »
[member=2919]kontiki[/member], forumda aynı başlık altında farklı konuları konuşmuyoruz. Bu sebeple bu sorunla ilgili yeni bir konu açmak daha uygun olacaktır. Kurtarma kipi seçenekleri arasında fsck seçeneği olmalı, bununla dosya sistemini taratmayı deneyiniz. Eğer sorun çözülmezse konuyu böler öyle devam ederiz.
Çevrimdışı kontiki
  • İleti: 17
« Yanıtla #6 : 28 Nisan 2016, 12:49:29 »
 Haklısınız. Tşk.ler
