Gönderen Konu: ThinkPad Console Audio Control (Dolby Advenced Audio)  (Okunma sayısı 5523 defa)
Çevrimdışı Just4KiLL
  • İleti: 3
  • Dağıtım: Linux 17.3
  • Grafik Kartı: GT 740M
  • İşlemci: Core i5 3230m
Bu konudakileri uyguladım.
Ama ben cihazımdaki Thinkpad ses kartını kullanmak istiyorum. AlsaMixer dan gözüküyor.
System:    Host: Pisi Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Machine:   System: LENOVO product: 20160 v: Lenovo V580c
           Mobo: LENOVO model: 20160
           Bios: LENOVO v: H1ET73WW(1.16) date: 04/10/2013
CPU:       Dual core Intel Core i5-3230M (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10376
           clock speeds: max: 3200 MHz 1: 1322 MHz 2: 2132 MHz 3: 1992 MHz
           4: 1969 MHz
           Card-2: NVIDIA GK208M [GeForce GT 740M] bus-ID: 01:00.0
           Resolution: 1366x768@60.0hz
Network:   Card-1: Intel Centrino Wireless-N 2230
           driver: iwlwifi v: in-tree: bus-ID: 03:00.0
           driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 04:00.0
Drives:    HDD Total Size: 1000.2GB (1.0% used)
           ID-1: /dev/sda model: ST1000LM024_HN size: 1000.2GB
Partition: ID-1: / size: 46G used: 5.6G (13%) fs: ext4 dev: /dev/sda8
           ID-2: swap-1 size: 4.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda7
Sensors:   System Temperatures: cpu: 55.0C mobo: 41.0C
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 176 Uptime: 7 min Memory: 618.3/5806.5MB
inxi -SMAx
cat /proc/asound/card0/codec#* | grep Codec
Codec: Realtek ALC269VC
Codec: Intel PantherPoint HDMI
cat /proc/asound/modules
 0 snd_hda_intel
29 thinkpad_acpi
lsmod | grep snd
snd_hda_codec_realtek    81920  1
snd_hda_codec_generic    69632  1 snd_hda_codec_realtek
snd_hda_intel          36864  6 snd_hda_codec_hdmi
snd_hda_codec         143360  5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
snd_pcm               106496  5 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller
snd                    86016  21 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,thinkpad_acpi,snd_seq_device
aplay -l
**** PLAYBACK Donanım Aygıtlarının Listesi ****
kart 0: PCH [HDA Intel PCH], aygıt 0: ALC269VC Analog [ALC269VC Analog]
  Altaygıtlar: 0/1
  Altaygıt #0: subdevice #0
kart 0: PCH [HDA Intel PCH], aygıt 3: HDMI 0 [HDMI 0]
  Altaygıtlar: 1/1
« Son Düzenleme: 24 Mayıs 2016, 12:51:51 Gönderen: Just4KiLL »
Ynt: ThinkPad Console Audio Control (Dolby Advenced Audio)
« Yanıtla #1 : 24 Mayıs 2016, 14:59:59 »
Bu Thinkpad ses aygıtı BIOS'la ilgili bipvb. seslei çıkarıyor olmasın.
  • İleti: 3
« Yanıtla #2 : 27 Mayıs 2016, 00:19:09 »
Olabilir bilmiyorum. Normalde böyle bir şeye rastgeldiniz mi hiç?
Konu ile alakasız bir sorum daha var bu yazılım kaynaklarından bir kaç depo sildim nasıl varsayılan hale döndürebilirim?
« Yanıtla #3 : 27 Mayıs 2016, 17:57:30 »
 0 snd_hda_intel
29 thinkpad_acpi
Ben daha önce bu aygıtlardan kullanmadığım için bilemiyorum, bu sonucu thinkpad_acpi mosülünü inceleyince çıkarttım.
modinfo thinkpad_acpi
Diğer sorun ile ilgili yeni bir konu açabilirsiniz, ama forumda halihazırda cevabı bulunmakta. Forumda aynı başlık altında birbirinden farklı konuları konuşmuyoruz, birbirinden farklı hususlar için yeni konu açılması gerekiyor.
https://forum.linuxmint.net.tr/index.php?topic=5421.msg34366#msg34366
https://forum.linuxmint.net.tr/index.php?topic=2107.msg13392#msg13392
  • İleti: 3
« Yanıtla #4 : 29 Mayıs 2016, 19:43:46 »
Peki bu ses sorununa nasıl bir çözüm üretebilirim? Windowstaki gibi çıkmıyor.
Verdiğiniz komutun çıktısı
filename:       /lib/modules/3.19.0-32-generic/kernel/drivers/platform/x86/thinkpad_acpi.ko
license:        GPL
version:        0.25
description:    ThinkPad ACPI Extras
author:         Henrique de Moraes Holschuh <hmh@hmh.eng.br>
author:         Borislav Deianov <borislav@users.sf.net>
alias:          dmi:bvnIBM:bvrI[MU]ET??WW*
alias:          tpacpi
srcversion:     FA1168AFD8B724428C6F768
alias:          acpi*:LEN0068:*
alias:          acpi*:IBM0068:*
depends:        nvram,snd
intree:         Y
vermagic:       3.19.0-32-generic SMP mod_unload modversions
signer:         Magrathea: Glacier signing key
sig_key:        0C:8B:EF:E0:C1:E2:89:E4:D8:99:09:26:11:7A:DA:3B:DF:EB:41:9C
sig_hashalgo:   sha512
parm:           experimental:Enables experimental features when non-zero (int)
parm:           debug:Sets debug level bit-mask (uint)
parm:           force_load:Attempts to load the driver even on a mis-identified ThinkPad when true (bool)
parm:           fan_control:Enables setting fan parameters features when true (bool)
parm:           brightness_mode:Selects brightness control strategy: 0=auto, 1=EC, 2=UCMS, 3=EC+NVRAM (uint)
parm:           brightness_enable:Enables backlight control when 1, disables when 0 (uint)
parm:           volume_mode:Selects volume control strategy: 0=auto, 1=EC, 2=N/A, 3=EC+NVRAM (uint)
parm:           volume_capabilities:Selects the mixer capabilites: 0=auto, 1=volume and mute, 2=mute only (uint)
parm:           volume_control:Enables software override for the console audio control when true (bool)
parm:           software_mute:Request full software mute control (bool)
parm:           index:ALSA index for the ACPI EC Mixer (int)
parm:           id:ALSA id for the ACPI EC Mixer (charp)
parm:           enable:Enable the ALSA interface for the ACPI EC Mixer (bool)
parm:           hotkey:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           bluetooth:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           video:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           light:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           cmos:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           led:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           beep:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           brightness:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           volume:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           fan:Simulates thinkpad-acpi procfs command at module load, see documentation
parm:           dbg_wlswemul:Enables WLSW emulation (uint)
parm:           wlsw_state:Initial state of the emulated WLSW switch (bool)
parm:           dbg_bluetoothemul:Enables bluetooth switch emulation (uint)
parm:           bluetooth_state:Initial state of the emulated bluetooth switch (bool)
parm:           dbg_wwanemul:Enables WWAN switch emulation (uint)
parm:           wwan_state:Initial state of the emulated WWAN switch (bool)
parm:           dbg_uwbemul:Enables UWB switch emulation (uint)
parm:           uwb_state:Initial state of the emulated UWB switch (bool)
« Yanıtla #5 : 29 Mayıs 2016, 20:40:49 »
Çıktıyı modül açıklamasını görmeniz için ekelemiştim, paylaşmaya gerek yok aslında.
Ses seviyesi için aşağıdaki komutu uçbirimden çalıştırınız ve düşük ses kanalı varsa yükseltmeyi deneyiniz.
alsamixer
Buradaki mesajı da inceleyebilirsiniz.
« Son Düzenleme: 29 Mayıs 2016, 20:48:12 Gönderen: Butterfly »
