Gönderen Konu: Mint 18 Kablosuz Ağ Problemi  (Okunma sayısı 6435 defa)
Çevrimdışı furkan
  • İleti: 52
  • Masaüstü Ortamı: XFCE
  • Grafik Kartı: Nvidia GT 840M
  • İşlemci: Intel Core i7-4510U CPU @ 2.00GHz x 2
« : 27 Temmuz 2016, 13:46:01 »
Merhaba, arkadaşım Linux Mint 18 Cinnamon yükledi, sistem şuan kablosuz ağları görmüyor yardımcı olabilir misiniz ?
lspci -nnk | grep -iA2 net
lspci: Unable to load libkmod resources: error -12
02:00.0 Network controller [0280]: Qualcomm Atheros AR9485 Wireless Network Adapter [168c:0032] (rev 01)
Subsystem: Samsung Electronics Co Ltd AR9485 Wireless Network Adapter [144d:410e]
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06)
Subsystem: Samsung Electronics Co Ltd RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [144d:c711]
Kernel driver in use: r8169
 sudo lshw -C network
[sudo]:
  *-network UNCLAIMED
       description: Network controller
       product: AR9485 Wireless Network Adapter
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: memory:f7900000-f797ffff memory:f7980000-f798ffff
  *-network
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: enp3s0
       version: 06
       serial: 18:67:b0:43:8e:44
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.1.10 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:28 ioport:d000(size=256) memory:f7800000-f7800fff memory:f2100000-f2103fff
lsmod
nouveau              1495040  1
i915                 1208320  3
ttm                    98304  1 nouveau
i2c_algo_bit           16384  2 i915,nouveau
drm_kms_helper        147456  2 i915,nouveau
psmouse               126976  0
drm                   360448  8 ttm,i915,drm_kms_helper,nouveau
wmi                    20480  2 mxm_wmi,nouveau
video                  40960  2 i915,nouveau,
 iwconfig | grep 'Power Management'
enp3s0    no wireless extensions.
« Son Düzenleme: 27 Temmuz 2016, 13:52:44 Gönderen: furkan »
Ynt: Mint 18 Kablosuz Ağ Problemi
« Yanıtla #1 : 27 Temmuz 2016, 14:36:43 »
rfkill list
çıktısına da bakalım.
Çevrimdışı furkan
  • İleti: 52
« Yanıtla #2 : 27 Temmuz 2016, 15:05:28 »
rfkill list
Bir çıktı vermedi bu komut .
« Yanıtla #3 : 27 Temmuz 2016, 15:31:37 »
Buradaki güncel linux-firmware paketini indirip sağ tık Gdebi ile kurmayı dener misiniz? Sonrasında sistemi yeniden başlatınız.
Çevrimdışı furkan
  • İleti: 52
« Yanıtla #4 : 27 Temmuz 2016, 16:23:55 »
Bu hatayı almakta.
Error:no longer provides linux-firmware
« Yanıtla #5 : 27 Temmuz 2016, 17:03:40 »
Aşağıdaki komutlarla kurulum dener misiniz? Kurulum sağlanmazsa komutların çıktılarını paylaşırsınız.
wget -c --no-check-certificate mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.159_all.deb
sudo dpkg -i linux-firmware_1.159_all.deb
Çevrimdışı furkan
  • İleti: 52
« Yanıtla #6 : 27 Temmuz 2016, 17:47:44 »
kurulum başarılı bi şekilde oldu ama kablosuz ağları görememe sorunu devam ediyor.
« Yanıtla #7 : 27 Temmuz 2016, 17:48:50 »
Sistemi yeniden başlattınız mı?
Çevrimdışı furkan
  • İleti: 52
« Yanıtla #8 : 27 Temmuz 2016, 18:43:27 »
Evet, başlatıldı.
« Yanıtla #9 : 27 Temmuz 2016, 20:06:39 »
Aşağıdaki komutların çıktılarına bakalım yeniden.
lsmod
rfkill list all
*-network UNCLAIMED
Kablosuz ağ cihazı önceki paylaşımlarda psaif olarak görünüyordu.
Çevrimdışı furkan
  • İleti: 52
« Yanıtla #10 : 27 Temmuz 2016, 22:25:38 »
lsmod
rfkill list all
inxi -fxz
CPU:       Dual core Intel Core i5-3230M (-HT-MCP-) cache: 3072 KB
           bmips: 10376
           clock speeds: max: 3200 MHz 1: 1369 MHz 2: 1299 MHz 3: 1391 MHz
           4: 1238 MHz
           CPU Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts
           clflush cmov constant_tsc cx16 cx8 de ds_cpl dtes64 dtherm dts
           eagerfpu epb ept erms est f16c flexpriority fpu fsgsbase fxsr ht
           ida lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae
           pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pts
           rdrand rdtscp rep_good sep smep ss sse sse2 sse4_1 sse4_2 ssse3
           syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
           x2apic xsave xsaveopt xtopology xtpr
lsmod
nouveau              1495040  1
i915                 1208320  3
ttm                    98304  1 nouveau
psmouse               126976  0
lsmod
nouveau              1495040  1
i915                 1208320  3
ttm                    98304  1 nouveau
psmouse               126976  0
 *-network UNCLAIMED
       physical id: 0
       version: 01
       width: 64 bits
       clock: 33MHz
  *-network
       physical id: 0
       version: 06
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168e-3_0.0.4 03/27/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
rfkill list all komutu çıktı vermedi.
« Yanıtla #11 : 28 Temmuz 2016, 09:51:29 »
Kablolu bağlantı yardımıyla aşağıdaki şekilde sistemi güncellemeyi dener misiniz?
Ardından, Güncelleme Yöneticisi => Görünüm menüsü => "Linux çekirdekleri" aracı yardımıyla 4.4.x serisi çekirdeğin son sürümünü (şu an itibariyle 4.4.0-31 sürümde) kurunuz.
Ardından sisteminizi yeniden başlatmayı deneyiniz.
Eğer sorun bu şekilde çözülmezse BIOS ayarlarını sıfırlamayı deneyebilirsiniz.
Cihazda kablosuz ağ aygıtını pasifleştirmeye yarayacak bir düğme ya da klavye kısayolu varsa bununla kablosuz ağ cihazını etkinleştirmek denenebilir.
Çevrimdışı furkan
  • İleti: 52
« Yanıtla #12 : 29 Temmuz 2016, 10:05:03 »
Merhaba, arkadaşım dün tekrar kurmuş sistemi şuan sorunsuz çalışmakta. Yardımlarınız için teşekkür ederiz, konuyu kilitleyebilirsiniz iyi günler...
