Gönderen Konu: [Çözüldü] RTL8187 Kablosuz Ağ Bağlantı Kesilmesi Sorunu  (Okunma sayısı 5323 defa)
Çevrimdışı Enterprise-1701A
  • İleti: 32
    • Kullanmıyorum
  • Masaüstü Ortamı: Cinnamon 4.6.6
  • Grafik Kartı: [AMD/ATI] RS690M
  • İşlemci: AMD Athlon 64 X2 TK-57
Linux mate 18 mint'i yakında kurdum. Çok da sevdim. Tam hiç bir sorunum yok derken wifi kopmalarını farkettim. Sistemin özellikleri şöyledir:
System:    Host: sedat-SATELLITE-L300D Kernel: 4.4.0-21-generic i686 (32 bit gcc: 5.3.1)
           Desktop: MATE 1.14.1 (Gtk 3.18.9-1ubuntu3) Distro: Linux Mint 18 Sarah
Machine:   System: TOSHIBA product: SATELLITE L300D v: PSLC0E-00900WTE
           Mobo: TOSHIBA model: N/A Bios: Insyde v: 1.70 date: 09/16/2008
CPU:       Dual core AMD Athlon 64 X2 TK-57 (-MCP-) cache: 512 KB
           flags: (lm nx pae sse sse2 sse3 svm) bmips: 3199
           clock speeds: max: 1900 MHz 1: 800 MHz 2: 800 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RS690M [Radeon Xpress 1200/1250/1270] bus-ID: 01:05.0
           Display Server: X.Org 1.18.3 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1280x800@59.98hz
           GLX Renderer: Gallium 0.4 on ATI RS690 GLX Version: 2.1 Mesa 11.2.0 Direct Rendering: Yes
Audio:     Card Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA) driver: snd_hda_intel bus-ID: 00:14.2
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 03:00.0
           IF: enp3s0 state: down mac: <filter>
           Card-2: Realtek RTL8187B Wireless Adapter driver: rtl8187 usb-ID: 001-004
           IF: wlx00225f256bd6 state: N/A mac: N/A
Drives:    HDD Total Size: 910.2GB (40.9% used) ID-1: /dev/sda model: WDC_WD1600BEVT size: 160.0GB temp: 45C
           ID-2: USB /dev/sdb model: Transcend size: 750.2GB temp: 0C
Partition: ID-1: / size: 145G used: 5.6G (5%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.01GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 66.0C mobo: N/A
Info:      Processes: 190 Uptime: 3:07 Memory: 655.2/1884.0MB Init: systemd runlevel: 5 Gcc sys: 5.3.1
Lütfen biri yardım edebilir mi?
Düzenleme : Konu başlığı
Bakınız =>
« Son Düzenleme: 10 Ağustos 2016, 01:34:13 Gönderen: Enterprise-1701A »
Daha önce hiç kimsenin gitmeye cesaret edemediği yerlere korkusuzca gitmek için.
  • İleti: 32
    • Kullanmıyorum
Ynt: RTL8187 Kablosuz Ağ Bağlantı Kesilmesi Sorunu
« Yanıtla #2 : 08 Ağustos 2016, 02:07:52 »
Kodların çıktıları şöyledir:
sedat@sedat-SATELLITE-L300D ~ $ inxi -SNx
sedat@sedat-SATELLITE-L300D ~ $ lspci -nnk | grep -iA2 net
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 02)
Subsystem: Toshiba America Info Systems RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [1179:ff68]
Kernel driver in use: r8169
Kernel modules: r8169
sedat@sedat-SATELLITE-L300D ~ $ lsusb
Bus 001 Device 005: ID 04f2:b070 Chicony Electronics Co., Ltd Camera
Bus 001 Device 004: ID 0bda:8197 Realtek Semiconductor Corp. RTL8187B Wireless Adapter
Bus 001 Device 002: ID 174c:5106 ASMedia Technology Inc. ASM1051 SATA 3Gb/s bridge
Bus 003 Device 002: ID 05e3:1205 Genesys Logic, Inc. Afilias Optical Mouse H3003 / Trust Optical USB MultiColour Mouse MI-2330
sedat@sedat-SATELLITE-L300D ~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
sedat@sedat-SATELLITE-L300D ~ $ sudo lshw -C network
[sudo] password for sedat:
  *-network
       product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: enp3s0
       version: 02
       serial: 00:1e:33:6e:ba:3a
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:26 ioport:2000(size=256) memory:89010000-89010fff memory:89000000-8900ffff
  *-network
       physical id: 1
       bus info: usb[member=3516]1[/member]:6
       logical name: wlx00225f256bd6
       serial: 00:22:5f:25:6b:d6
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8187 driverversion=4.4.0-21-generic firmware=N/A ip=192.168.1.3 link=yes multicast=yes wireless=IEEE 802.11bg
sedat@sedat-SATELLITE-L300D ~ $ iwconfig | grep Power
enp3s0    no wireless extensions.
          Bit Rate=5.5 Mb/s   Tx-Power=20 dBm
          Power Management:off
sedat@sedat-SATELLITE-L300D ~ $ lsmod
rtl8187                57344  0
mac80211              659456  1 rtl8187
cfg80211              499712  2 mac80211,rtl8187
eeprom_93cx6           16384  1 rtl8187
uvcvideo               77824  0
videobuf2_v4l2         28672  1 uvcvideo
videobuf2_core         36864  2 uvcvideo,videobuf2_v4l2
v4l2_common            16384  1 videobuf2_v4l2
videodev              155648  4 uvcvideo,v4l2_common,videobuf2_core,videobuf2_v4l2
snd_hda_codec_realtek    73728  1
snd_hda_codec_generic    69632  1 snd_hda_codec_realtek
kvm                   471040  0
snd_hda_intel          36864  3
snd_hda_codec         118784  4 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel
edac_mce_amd           24576  0
k8temp                 16384  0
snd_hda_core           61440  5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
edac_core              49152  0
snd_pcm                94208  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
snd                    69632  17 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
i2c_piix4              20480  0
toshiba_acpi           36864  0
sparse_keymap          16384  1 toshiba_acpi
wmi                    20480  1 toshiba_acpi
toshiba_bluetooth      16384  0
btrfs                1003520  0
xor                    28672  1 btrfs
uas                    20480  0
usb_storage            57344  2 uas
hid                    98304  2 hid_generic,usbhid
radeon               1466368  2
psmouse               118784  0
r8169                  77824  0
i2c_algo_bit           16384  1 radeon
pata_atiixp            16384  0
ttm                    90112  1 radeon
drm_kms_helper        131072  1 radeon
drm                   311296  5 ttm,drm_kms_helper,radeon
ati_agp                16384  0
video                  36864  1 toshiba_acpi
İlgilendiğiniz için teşekkür ederim.
« Yanıtla #3 : 08 Ağustos 2016, 08:56:52 »
Kablosuz ağ arabirimini öğrenmek için aşağıdaki komutun çıktısına da bakalım.
iwconfig
  • İleti: 32
    • Kullanmıyorum
« Yanıtla #4 : 08 Ağustos 2016, 11:01:34 »
Sonuç şudur:
wlx00225f256bd6  IEEE 802.11bg  ESSID:"EVEREST"
          Mode:Managed  Frequency:2.417 GHz  Access Point: 64:51:7E:17:70:FA
          Bit Rate=1 Mb/s   Tx-Power=20 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Link Quality=39/70  Signal level=-71 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:281  Invalid misc:7   Missed beacon:0
« Yanıtla #5 : 08 Ağustos 2016, 11:31:40 »
Buradaki öneriyi Linux Mint 18'e uyarlamayı deneyelim.
Önce aşağıdaki komutu uçbirimde çalıştırınız.
echo "options mac80211 probe_wait_ms=5000" | sudo tee  /etc/modprobe.d/mac80211.conf
Sonra aşağıdaki komutu uçbirimde çalıştırarak rc.local dosyasını açınız.
sudo xed /etc/rc.local
Açılan dosyada exit 0 satırının üstüne aşağıdaki satırları kopyalayıp yapıştırınız ve dosyayı kaydediniz.
modprobe -r rtl8187
modprobe -r mac80211
modprobe rtl8187
iwconfig wlx00225f256bd6 rate 16M fixed
iwconfig wlx00225f256bd6 frag 2346
iwconfig wlx00225f256bd6 rts 2347
iwconfig wlx00225f256bd6 txpower 30
Ardından sisteminizi yeniden başlatınız.
Çevrimdışı gencharitaci
  • İleti: 8
    • gencharitaci
    • Genç Haritacı
  • Dağıtım: Linux Mint 18
  • Grafik Kartı: Nvidia GeForce 960M
  • İşlemci: Intel i7-4712MQ
« Yanıtla #6 : 08 Ağustos 2016, 12:47:39 »
Ben de RTL8192'de benzer sorun yaşamıştım. Wireless bir-iki dakikada bir sürekli kopuyordu. Hatta kopmakla da kalmıyor wifiden bağlanmama rağmen ilginç bir şekilde modemin de interneti düşüyordu. Dolayısıyla evdeki tüm cihazların (TV, Tablet, cep telefonları vs.) internet bağlantısı kesiliyordu.
Sorunu buradan çözdüm.  İnceleyebilirsiniz. RTL8188 var ama 8187 için olur mu bilemiyorum.
https://github.com/pvaret/rtl8192cu-fixes
Umarım işe yarar.
« Yanıtla #7 : 08 Ağustos 2016, 12:51:14 »
Bu farklı bir çipset için öneri olabilir, bu öneriyi denemek bu çipset (RTL8187) için çözüm olmayacaktır, zira kullanılan sürücü modülü farklı.
  • İleti: 32
    • Kullanmıyorum
« Yanıtla #8 : 08 Ağustos 2016, 15:29:02 »
Önerilerinizi uyguladım. 20 dakika boyunca kesilmeyince, oldu galiba, diye sevinmiştim. Ama birden kesilip bağlamaya başladı. Bu sefer daha uzun sürede bağlanıyor. Ve bağlı iken de sayfaları çok yavaş açıyor, bazen açamıyor da.  Bulunduğum yerle mi alakası var diyerek, wifi kaynağının 2-3 metre yakınına gittim. Orada bağlantı hiç kopmuyor. Ben şuan diğer odada 10 metrelik bir alanın içindeyim. Burada kopmalar devam ediyor. Acaba internet için 2-3 metrelik alanda mı kalsam. Ne dersiniz?
« Yanıtla #9 : 08 Ağustos 2016, 22:51:22 »
Aşağıdaki komutla linux-firmware-nonfree paketini yükleyip sistemi yeniden başlatmayı deneyiniz.
sudo apt-get install linux-firmware-nonfree
  • İleti: 32
    • Kullanmıyorum
« Yanıtla #10 : 08 Ağustos 2016, 23:13:00 »
Şöyle yazıyor:
sedat@sedat-SATELLITE-L300D ~ $ sudo apt-get install linux-firmware-nonfree
E: linux-firmware-nonfree paketi bulunamadı
« Yanıtla #11 : 09 Ağustos 2016, 00:03:07 »
İlgili paket Linux Mint 18 deposunda yokmuş.
Aşağıdaki komutları sırasıyla uçbirimde çalıştırarak çekirdek sürümünü elle güncellemeyi deneyebilirsiniz.
mkdir linux4.6.5 & cd linux4.6.5
wget -c --no-check-certificate kernel.ubuntu.com/~kernel-ppa/mainline/v4.6.5/linux-headers-4.6.5-040605_4.6.5-040605.201607271333_all.deb
wget -c --no-check-certificate kernel.ubuntu.com/~kernel-ppa/mainline/v4.6.5/linux-headers-4.6.5-040605-generic_4.6.5-040605.201607271333_amd64.deb
wget -c --no-check-certificate kernel.ubuntu.com/~kernel-ppa/mainline/v4.6.5/linux-image-4.6.5-040605-generic_4.6.5-040605.201607271333_amd64.deb
sudo dpkg -i *.deb
Kurulum sonrasında sistemi yeniden başlattığınızda, yeni kurduğunuz çekirdek ile açılacaktır.
  • İleti: 32
    • Kullanmıyorum
« Yanıtla #12 : 10 Ağustos 2016, 00:11:20 »
Son önerinizi uyguladım. Bir süre sonra bağlantı kopunca, ilk önce olmamış diye düşündüm. Sonra tekrar bağlandı ve şimdiye kadar bu  sürekli kopup bağlanmalar devam edecek mi diye bekleyip işi garantiye almak istedim. Sadece iki defa koptu o kadar da olacak. Sanırım artık sorun çözüldü. Çok teşekkür ederim, emeğinize, bilginize sağlık. Tekrar aynı sorunu yaşarsam, yeni bir konu mu açmalıyım yoksa bu mesajın altına cevap mı yazmalıyım. Saygılarımla.
Ynt: [Çözüldü] RTL8187 Kablosuz Ağ Bağlantı Kesilmesi Sorunu
« Yanıtla #13 : 10 Ağustos 2016, 14:58:43 »
Rica ederiz.
Forumda çözülen konuları kilitliyoruz. Eğer sorun yaşanmaya devam ederse bu konudan devam etmek için, bu mesajdaki "Moderatöre rapor et" kısayolunu kullanarak konu kilidinin açılmasını isteyebilirsiniz.
