Gönderen Konu: [Çözüldü] cpu frequency hatası  (Okunma sayısı 5321 defa)
Çevrimdışı can.01
  • İleti: 6
« : 08 Eylül 2016, 16:08:18 »
Bilgisayarı açınca bu hatayı alıyordum sorunu çözmüştüm nvdıa'yı yukleyince tekrar çıktı gerçi nvdıa da sorunlu şuan .
System:    Host: Mr Kernel: 4.4.0-36-generic x86_64 (64 bit gcc: 5.4.0)
           Distro: Linux Mint 18 Sarah
Machine:   Mobo: ASUSTeK model: P8H61-M LX R2.0 v: Rev X.0x
           Bios: American Megatrends v: 0801 date: 11/01/2012
CPU:       Dual core Intel Core i3-3220 (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 13169
           clock speeds: max: 3300 MHz 1: 1699 MHz 2: 1687 MHz 3: 1694 MHz
           4: 1611 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Whistler LE [Radeon HD 6610M/7610M]
           bus-ID: 01:00.0
           Display Server: X.Org 1.18.3 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1280x1024@60.02hz
           GLX Renderer: Gallium 0.4 on AMD TURKS (DRM 2.43.0, LLVM 3.8.0)
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Turks/Whistler HDMI Audio [Radeon HD 6000 Series]
           Card-2 Intel 6 Series/C200 Series Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.4.0-36-generic
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 500.1GB (4.2% used)
           ID-1: /dev/sda model: WDC_WD5000AAKX size: 500.1GB
Partition: ID-1: / size: 455G used: 15G (4%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.24GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
           ID-3: swap-2 size: 0.51GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
           ID-4: swap-3 size: 0.51GB used: 0.00GB (0%) fs: swap dev: /dev/zram1
           ID-5: swap-4 size: 0.51GB used: 0.00GB (0%) fs: swap dev: /dev/zram2
           ID-6: swap-5 size: 0.51GB used: 0.00GB (0%) fs: swap dev: /dev/zram3
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 205 Uptime: 6 min Memory: 852.3/3903.7MB
« Son Düzenleme: 08 Eylül 2016, 18:29:20 Gönderen: can.01 »
Ynt: cpu frequency hatası
« Yanıtla #1 : 08 Eylül 2016, 16:48:40 »
Çevrimdışı can.01
  • İleti: 6
« Yanıtla #2 : 08 Eylül 2016, 18:00:30 »
Forumdaki diger bilgileride yaptım yalnız olmamıştı.
« Yanıtla #3 : 08 Eylül 2016, 18:22:10 »
Aşağıda komutla /etc/default/grub dosyasını açınız.
sudo xed /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="splash quiet"
aşağıdaki şekilde tırnak işaretleri içine intel_pstate=disable değişkenini ekleyiniz ve dosyayı kaydediniz..
GRUB_CMDLINE_LINUX_DEFAULT="splash quiet intel_pstate=disable"
ardından aşağıdaki komutu uçbirimde çalıştırınız ve sistemi yeniden başlatınız.
sudo update-grub
Güncel çekirdeklerde Intel CPU için Pstate güç yönetimi etkin geliyor, Cpufreq'in kullanılması için yukarıdaki şekilde pasifleştirilmesi gerekli.
« Son Düzenleme: 08 Eylül 2016, 18:23:46 Gönderen: Butterfly »
Çevrimdışı can.01
  • İleti: 6
« Yanıtla #4 : 08 Eylül 2016, 18:31:32 »
sudo update-grub
Çok teşekkür ederim.Sorun çözüldü.
« Son Düzenleme: 08 Eylül 2016, 18:34:52 Gönderen: can.01 »
