Gönderen Konu: Hipchat Açılmıyor  (Okunma sayısı 7733 defa)
Çevrimdışı yukarihisar
  • İleti: 74
Hipchat Açılmıyor
« : 09 Eylül 2016, 15:24:43 »
https://www.hipchat.com/ bu adresteki programı kurdum. Fakat programı açtığımda açılıp direk kapanıyor. Pencere görünüp kayboluyor yani.
Uç birimden başlattığımda ise aşağıdaki gibi bir hata alıyorum.
lenovo@Lenovo-linux ~ $ hipchat4
hello 0.267581
PackageLocation: "/opt/HipChat4/share/localweb/package.json"
package.json opened
package.json valid
package.json object
package.json version value =  "4.27.10"
QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
Qt WebEngine ICU data not found at /opt/HipChat4/lib/resources. Trying parent directory...
Installed Qt WebEngine locales directory not found at location /opt/HipChat4/lib/translations/qtwebengine_locales. Trying application directory...
Qt WebEngine locales directory not found at location /opt/HipChat4/lib/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
Qt WebEngine resources not found at /opt/HipChat4/lib/resources. Trying parent directory...
[0909/152305:ERROR:resource_bundle.cc(720)] Failed to load /opt/HipChat4/lib/qtwebengine_devtools_resources.pak
Some features may not be available.
[0909/152305:WARNING:resource_bundle.cc(311)] locale_file_path.empty() for locale
[0909/152305:ERROR:browser_main_loop.cc(217)] Running without the SUID sandbox! See https://chromium.googlesource.com/chromium/src/+/master/docs/linux_suid_sandbox_development.md for more information on developing with the sandbox on.
--type=zygote
hello 0.446625
Qt WebEngine ICU data not found at /home/tm/Qt/5.7/gcc_64/resources. Trying parent directory...
Qt WebEngine ICU data not found at /home/tm/Qt/5.7/gcc_64. Trying application directory...
Installed Qt WebEngine locales directory not found at location /home/tm/Qt/5.7/gcc_64/translations/qtwebengine_locales. Trying application directory...
Qt WebEngine locales directory not found at location /opt/HipChat4/bin/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
Qt WebEngine resources not found at /home/tm/Qt/5.7/gcc_64/resources. Trying parent directory...
Qt WebEngine resources not found at /home/tm/Qt/5.7/gcc_64. Trying application directory...
[0909/152305:ERROR:resource_bundle.cc(720)] Failed to load /opt/HipChat4/bin/qtwebengine_devtools_resources.pak
[0909/152305:ERROR:gl_surface_qt.cpp(187)] GLContextHelper::getXConfig() failed.
[12:23:05][void HipChatApplication::initialize(HipChatApplication::Configuration&):393] datapath "/opt/HipChat4/lib"
[12:23:05][virtual bool OnlineStatus::platformSpecificHasInternetConnectivity():38] org.freedesktop.NetworkManager interface is valid
[12:23:05][void AbstractOnlineStatus::checkOnlineStatus():196] platform online state =  true
[12:23:05][void AbstractOnlineStatus::doSecondaryCheck(bool):205] Do secondary online check
[12:23:05][void AbstractOnlineStatus::doSecondaryCheck(bool):259] onlineStatusUrl is empty
[12:23:05][void AbstractOnlineStatus::handleOnlineStatusResult(bool):171] newOnlineState:  true
[12:23:05][void AbstractOnlineStatus::handleOnlineStatusResult(bool):184] initCheckComplete
[12:23:05][void HipChatApplication::onInitialOnlineCheck(bool):307] HCA isInitOnline:  true
[12:23:05][void HipChatApplication::onInitialOnlineCheck(bool):310] doAuth
Warning: [12:23:05][qt.network.ssl][:0] QSslSocket: cannot resolve SSLv2_client_method
Warning: [12:23:05][qt.network.ssl][:0] QSslSocket: cannot resolve SSLv2_server_method
Warning: [12:23:05][:0]
WARNING: This project is using the experimental QML API extensions for QtWebEngine and is therefore tied to a specific QtWebEngine release.
WARNING: The experimental API will change from version to version, or even be removed. You have been warned!
[12:23:05][qml][onCompleted:7] QML localContentCanAccessRemoteUrls true
[12:23:05][qml][onCompleted:9] QML localStorageEnabled true
[12:23:05][qml][onCompleted:11] QML accessFileUrls true
[12:23:05][virtual void AuthWindow::adjustWindowToScreen(QScreen*, QSize):154] AuthWindow desired height too big.  Scaling by  0.955714  from  500 x 700  to  477 x 669
[12:23:05][virtual void AuthWindow::adjustWindowToScreen(QScreen*, QSize):159] Setting zoom to  0.955714
[12:23:05][qml][zoomFactorChange:38] ***QML Zoom factor changed 0.9557142853736877
[12:23:05][void AuthWindow::init():124] Resizing AuthWindow based on calulated initial zoom to  QSize(500, 700)
[12:23:05][void NativeWebWindow::centerWindowOnScreen(QScreen*):153] Centering Window on screen :  QPoint(445,38)
[12:23:05][void AuthWindow::authenticate():182] No previous login detected
[12:23:05][QUrl WebBridge::createLocalURL(QString) const:38] url =  QUrl("file:///opt/HipChat4/share/localweb/modules/service_selector/service_selector.html")
[12:23:05][void AuthWindow::routeToLandingPage(bool):221] routeToLandingPage show
[12:23:05][int main(int, char**):435] RestartNumber= 0
Warning: [12:23:05][:0] Remote debugging server started successfully. Try pointing a Chromium-based browser to http://127.0.0.1:12345
Warning: [12:23:05][:0] QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
Fatal error: [12:23:05][:0] Failed to create OpenGL context for format QSurfaceFormat(version 2.0, options QFlags(), depthBufferSize 24, redBufferSize -1, greenBufferSize -1, blueBufferSize -1, alphaBufferSize -1, stencilBufferSize 8, samples -1, swapBehavior 2, swapInterval 1, profile  0)
İptal edildi
Ynt: Hipchat Açılmıyor
« Yanıtla #1 : 09 Eylül 2016, 15:49:44 »
  • İleti: 74
« Yanıtla #2 : 09 Eylül 2016, 15:54:01 »
Tabi ki, buyurun.
lenovo@Lenovo-linux ~ $ inxi -SGx
System:    Host: Lenovo-linux Kernel: 4.4.0-36-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: MATE 1.14.1 (Gtk 3.18.9-1ubuntu3.1)
           Distro: Linux Mint 18 Sarah
           Card-2: NVIDIA GK208M [GeForce GT 740M] bus-ID: 01:00.0
           Display Server: X.Org 1.18.3 driver: intel
           Resolution: 1366x768@59.96hz
lenovo@Lenovo-linux ~ $ glxinfo | grep render
lenovo@Lenovo-linux ~ $ lspci | egrep 'VGA|3D|Display'
01:00.0 3D controller: NVIDIA Corporation GK208M [GeForce GT 740M] (rev a1)
lenovo@Lenovo-linux ~ $ xrandr
LVDS1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 345mm x 194mm
   1366x768      59.96*+
   1360x768      59.80    59.96
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
lenovo@Lenovo-linux ~ $ cat /etc/X11/xorg.conf
« Yanıtla #3 : 09 Eylül 2016, 16:19:09 »
Sisteminizde Chrome ya da Chromium tarayıcılardan bir kurulu değilse, kurmayı dener misiniz?
  • İleti: 74
« Yanıtla #4 : 09 Eylül 2016, 16:23:02 »
Chrome yüklü hocam.
lenovo@Lenovo-linux ~ $ google-chrome-stable
Mevcut tarayıcı oturumunda yeni pencere oluşturuldu.
« Yanıtla #5 : 09 Eylül 2016, 16:31:42 »
Tamam sorun OpenGL kaynaklıymış, sistemde Bumblebee mi Nvidia Prime mı kurulu? Çıktıya bakalım.
dpkg -l | egrep 'nvidia|bumblebee'
  • İleti: 74
« Yanıtla #6 : 09 Eylül 2016, 16:36:37 »
Sanırım Nvidia hocam.
lenovo@Lenovo-linux ~ $ dpkg -l | egrep 'nvidia|bumblebee'
ii  nvidia-361                                   361.42-0ubuntu2                            amd64        NVIDIA binary driver - version 361.42
ii  nvidia-opencl-icd-361                        361.42-0ubuntu2                            amd64        NVIDIA OpenCL ICD
ii  nvidia-settings                              361.42-0ubuntu1                            amd64        Tool for configuring the NVIDIA graphics driver
Şöyle bir şey fark ettim. Saatin yanında nvidia simgesinden intel ekran kartını seçtim oturumu kapayıp açtım. Hipchat açıldı. Ekran kartı çıktıları da değişti.
   1366x768      59.96*+
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
« Son Düzenleme: 09 Eylül 2016, 16:54:46 Gönderen: yukarihisar »
« Yanıtla #7 : 09 Eylül 2016, 18:00:51 »
Geçici bir sorundu sanırım, bu durumda sorun çözülmüş görünüyor. Bir kaç defa GPU değişimi yapıp oturumu yenileyip sorun olup olmadığını kontrol edin, eğer sorun yaşanmıyorsa sanırım konu etiketlenebilir.
  • İleti: 74
« Yanıtla #8 : 10 Eylül 2016, 21:00:52 »
Hocam denedim fakat nvidia ekran kartına geçince sorun yine devam ediyor. Ekran çıktıları da eski haline dönüyor. Fakat intele geçtiğimde sorun düzeliyor çıktılarda değişiyor. Sorun nvidia driverlarında mı acaba?
« Yanıtla #9 : 10 Eylül 2016, 21:07:48 »
Intel + Nvidia GPU geçişi ile ilgili yeni bir konu açmanız daha uygun olacaktır.
