merhaba
ubi reader kurulumu yapmak istedim ama hata veriyor. linux konusunda fazla bilgim yok bu konuda yardımcı olabilirmisiniz.
linuxmint-18-mate-64bit kullanıyorum.
$ sudo apt-get install liblzo2-dev
If it is available.
$ sudo apt-get install python-lzo
Else you will need to install from sources.
$ git clone
https://github.com/jd-boyd/python-lzo.git$ cd python-lzo
$ python setup.py install
$ git clone
https://github.com/jrspruitt/ubi_reader$ cd ubi_reader
$ sudo python setup.py install
docea37-K53SD ubi_reader # sudo python setup.py install
File "setup.py", line 3, in <module>
from setuptools import setup,find_packages
ImportError: No module named setuptools
docea37-K53SD python-lzo # python setup.py install
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'tests_require'
warnings.warn(msg)
running install
running build
running build_ext
building 'lzo' extension
x86_64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/lzo -I/usr/include/python2.7 -c lzomodule.c -o build/temp.linux-x86_64-2.7/lzomodule.o
lzomodule.c:34:20: fatal error: Python.h: Böyle bir dosya ya da dizin yok
compilation terminated.
error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
