Gönderen Konu: [Çözüldü] Play on Linux LoL Kurulum Hatası - (Error in POL_System_wget)  (Okunma sayısı 5850 defa)
Çevrimdışı Kullanıcı Adı
  • İleti: 2
  • Dağıtım: Ubuntu
  • Masaüstü Ortamı: 14.04 LTS
  • Grafik Kartı: İntel Hd Graphics 530
  • İşlemci: İ3 6100 3.7@Ghz
Ubuntuyu henüz yeni kurdum Wine ve Pol ü kurdum fakat Pol'den LoL ı kurarken bu hata ile karşılaştım. Yardımcı olabilecek varsa şimdiden teşekkürler.
Hata :
POL_System_wget failed: Server issued an error response
--2016-09-18 02:38:04-- http://l3cdn.riotgames.com/Installer/SingleFileInstall/LeagueOfLegendsBaseEUW.exel3cdn.riotgames.com (l3cdn.riotgames.com) çözümleniyor... 31.3.4.79l3cdn.riotgames.com (l3cdn.riotgames.com)[31.3.4.79]:80 bağlanılıyor... bağlantı kuruldu.HTTP isteği gönderildi, cevap bekleniyor... 404 Not Found2016-09-18 02:38:05 HATA 404: Not Found.
Donanımım :
System:    Host: erkam Kernel: 4.4.0-31-generic x86_64 (64 bit, gcc: 4.8.4) Desktop: Gnome Distro: Ubuntu 14.04 trusty
Machine:   Mobo: ASUSTeK model: H110M-K D3 version: Rev X.0x Bios: American Megatrends version: 0405 date: 08/27/2015
CPU:       Dual core Intel Core i3-6100 CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 14782.4
           Clock Speeds: 1: 799.980 MHz 2: 799.980 MHz 3: 799.980 MHz 4: 799.980 MHz
Graphics:  Card: Intel Sky Lake Integrated Graphics bus-ID: 00:02.0
           X.Org: 1.18.3 drivers: intel (unloaded: fbdev,vesa) Resolution: 1440x900@59.9hz
           GLX Renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2) GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
Audio:     Card-1: Intel Sunrise Point-H HD Audio driver: snd_hda_intel bus-ID: 00:1f.3 Sound: ALSA ver: k4.4.0-31-generic
           Card-2: Razer USA driver: USB Audio usb-ID: 001-002
           driver: r8169 ver: 2.3LK-NAPI port: e000 bus-ID: 03:00.0
Drives:    HDD Total Size: 128.0GB (4.5% used) 1: id: /dev/sda model: Samsung_SSD_850 size: 128.0GB
Partition: ID: / size: 110G used: 5.4G (6%) fs: ext4 ID: swap-1 size: 7.43GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 217 Uptime: 4:22 Memory: 1076.1/6894.6MB Runlevel: 2 Gcc sys: 4.8.4
Edit: Yukarıda ki hatayı düzelttim fakat oyunu çalıştırdığımda LoL simgesi geliyor daha sonra bug splat hatası çıkıyor ve kapanmıyor.
« Son Düzenleme: 19 Eylül 2016, 22:55:32 Gönderen: Kullanıcı Adı »
Ynt: Play on Linux LoL Kurulum Hatası - (Error in POL_System_wget)
« Yanıtla #1 : 18 Eylül 2016, 23:53:44 »
Diğer sorun için (bug splat) yeni bir konu açmanız daha uygun olur, sorun hakkında bilgisi olan üyelerimiz böylece dönüş yapabilirler.
Oyunun kurulması için indirilmesi sırasında sorun yaşayanlar, önce buradaki gibi DNS adresini değiştirip, kurulum sırasında "North America" yansısını seçmeyi deneyebilirler, bu yansı ile kurulum dosyası indirilebiliyor.
[member=3809]Kullanıcı Adı[/member] siz farklı bir şekilde çözüme ulaştı iseniz, çözümü buraya aktarıp akabinde konu başlığını etiketleyebilirsiniz.
  • İleti: 2
  • Dağıtım: Ubuntu
« Yanıtla #2 : 19 Eylül 2016, 22:51:47 »
Cevap için teşekkürler. Bu şekilde oyunu kurabildim. Fakat LoL ı açınca LoL in simgesi donuyor daha sonra kapatmakla bitmeyen bug splat hatası açılıyor.
Forum da bununla ilgili bir konu zaten mevcut oradan takip ederim sağolun  :)
Malesef LoL linux tarafında sıkıntı yaratan bir oyun, örneğin denemek amaçlı sistemine kurduğum oyun sorunsuz bir şekilde çalışırken, gelen bir güncelleme sonrasında sürekli bug splat hatası verip güncelleme yapmıyordu. Ben de alternatif olarak, windows altında güncellenmiş oyun dosyalarını linux altında ki dosyalarla değiştirip giriş yapabiliyordum, bu da çok zahmetli oluyor her güncelleme sonrası.
