Gönderen Konu: [Çözüldü] wifi bğlantı sorunu  (Okunma sayısı 2986 defa)
Çevrimdışı brathme
  • İleti: 6
  • Dağıtım: mint
  • İşlemci: amd
« : 10 Ekim 2016, 22:24:59 »
s.a arkadaşlar.linuxta yeniyim.wifi bağlantım çok yavaş ve sürekli kopmalar oluyor.forumu incelerken https://forum.linuxmint.net.tr/index.php?topic=2740.0 şu sayfadaki kodlara denk geldim.sırasıyla kopyala yapıştır enter yapıp kodları buraya attım.yarımcı olurmusunuz  :'(
inxi -SNx
System:    Host: brathme35 Kernel: 4.4.0-21-generic i686 (32 bit gcc: 5.3.1)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18 Sarah
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: e800 bus-ID: 02:00.0
           Card-2: Realtek RTL8192CU 802.11n WLAN Adapter
           driver: rtl8192cu usb-ID: 001-006
lspci -nnk | grep -iA2 net
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 02)
   Subsystem: Foxconn International, Inc. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [105b:0e0c]
   Kernel driver in use: r8169
   Kernel modules: r8169
lsusb
Bus 001 Device 005: ID 15a4:1336 Afatech Technologies, Inc. SDHC/MicroSD/MMC/MS/M2/CF/XD Flash Card Reader
Bus 001 Device 006: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
Bus 003 Device 002: ID 1bcf:0007 Sunplus Innovation Technology Inc. Optical Mouse
Bus 002 Device 002: ID 1c4f:0026 SiGma Micro Keyboard
rfkill list
1: phy1: Wireless LAN
   Soft blocked: no
   Hard blocked: no
sudo lshw -C network
 *-network
       product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 02
       serial: 00:22:68:80:d4:04
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:26 ioport:e800(size=256) memory:fdfff000-fdffffff memory:fdfe0000-fdfeffff memory:febe0000-febfffff
  *-network
       physical id: 1
       bus info: usb[member=3516]1[/member]:3
       logical name: wlx081078c5de7d
       serial: 08:10:78:c5:de:7d
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8192cu driverversion=4.4.0-21-generic firmware=N/A ip=192.168.1.20 link=yes multicast=yes wireless=IEEE 802.11bgn
iwconfig | grep Power
enp2s0    no wireless extensions.
          Bit Rate=72.2 Mb/s   Tx-Power=20 dBm
          Power Management:off
lsmod
drbg                   28672  1
ctr                    16384  1
ccm                    20480  1
rtl8xxxu               69632  0
rtl8192cu              65536  0
rtl_usb                20480  1 rtl8192cu
rtl8192c_common        49152  1 rtl8192cu
rtlwifi                69632  3 rtl_usb,rtl8192c_common,rtl8192cu
mac80211              659456  4 rtl8xxxu,rtl_usb,rtlwifi,rtl8192cu
cfg80211              499712  2 mac80211,rtlwifi
snd_hda_codec_realtek    73728  1
snd_hda_codec_generic    69632  1 snd_hda_codec_realtek
snd_hda_intel          36864  5
snd_hda_codec         118784  4 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel
snd_hda_core           61440  5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
snd_pcm                94208  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
kvm_amd                57344  0
kvm                   471040  1 kvm_amd
edac_mce_amd           24576  0
edac_core              49152  0
snd                    69632  21 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
i2c_piix4              20480  0
tpm_infineon           20480  0
btrfs                1003520  0
xor                    28672  1 btrfs
uas                    20480  0
usb_storage            57344  1 uas
hid                    98304  2 hid_generic,usbhid
radeon               1466368  6
i2c_algo_bit           16384  1 radeon
ttm                    90112  1 radeon
drm_kms_helper        131072  1 radeon
psmouse               118784  0
pata_atiixp            16384  0
drm                   311296  9 ttm,drm_kms_helper,radeon
r8169                  77824  0
floppy                 61440  0
ati_agp                16384  0
Çıktıları lütfen code etiketi altında paylaşın.
Bakınız : https://forum.linuxmint.net.tr/index.php?topic=2629.0
« Son Düzenleme: 13 Ekim 2016, 21:07:45 Gönderen: brathme »
Ynt: wifi bğlantı sorunu
« Yanıtla #1 : 11 Ekim 2016, 09:04:26 »
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get install rtl8192cu-dkms linux-firmware
yukarıdaki komutları girerek deneyebilirsiniz.
Çevrimdışı brathme
  • İleti: 6
  • Dağıtım: mint
  • İşlemci: amd
« Yanıtla #2 : 11 Ekim 2016, 23:04:32 »
şu an için sorun çözüldü gibi.çok teşekkür ederim.
« Yanıtla #3 : 13 Ekim 2016, 20:44:18 »
Başlığı etiketlerseniz konuyu kilitleyelim.
 Çözülen başlıkların etiketlenmesi hakkında.
