Gönderen Konu: [Çözüm] LMDE Bumblebee [ERROR]Cannot Access Secondary GPU Sorunu  (Okunma sayısı 12585 defa)
Çevrimdışı Çağrı07
  • İleti: 391
    • Kayıt Formu
  • Masaüstü Ortamı: XFCE
Ynt: [Çözüm] LMDE Bumblebee [ERROR]Cannot Access Secondary GPU Sorunu
« Yanıtla #15 : 05 Aralık 2014, 18:40:35 »
Hocam artık komutu her verdiğimde açılıyor, sanırım sorun çözüldü :)
aspire@v3-571g:~/Desktop$ optirun -vvv glxgears
[ 1375.041378] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1375.041769] [INFO]Configured driver: nvidia
[ 1375.042087] [DEBUG]optirun version 3.2.1 starting...
[ 1375.042131] [DEBUG]Active configuration:
[ 1375.042161] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1375.042175] [DEBUG] X display: :8
[ 1375.042188] [DEBUG] LD_LIBRARY_PATH: /usr/lib/x86_64-linux-gnu/nvidia:/usr/lib/i386-linux-gnu/nvidia:/usr/lib/nvidia
[ 1375.042203] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1375.042216] [DEBUG] Accel/display bridge: auto
[ 1375.042229] [DEBUG] VGL Compression: proxy
[ 1375.042243] [DEBUG] VGLrun extra options:
[ 1375.042257] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus:/usr/lib/primus:/usr/lib32/primus
[ 1375.054505] [DEBUG]Using auto-detected bridge primus
[ 1380.161699] [INFO]Response: Yes. X is active.
[ 1380.161721] [INFO]Running application using primus.
[ 1380.161863] [DEBUG]Process glxgears started, PID 18287.
303 frames in 5.0 seconds = 60.485 FPS
primus: warning: dropping a frame to avoid deadlock
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0"
      after 29 requests (29 known processed) with 0 events remaining.
primus: warning: timeout waiting for display worker
[ 1389.571382] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 1389.571404] [DEBUG]Socket closed.
[ 1389.571417] [DEBUG]Killing all remaining processes.
Yalnız birşey sormak istiyorum LM Cinnamon'da 2000 Fps değerlerinde geziyor (Ayarlamaları ilk yaptığımda 60 Fbs falandı) bu durum normal mi hocam ?
« Son Düzenleme: 05 Aralık 2014, 19:39:45 Gönderen: Çağrı07 »
Yaşlanıyorum...
« Yanıtla #16 : 06 Aralık 2014, 17:32:58 »
FPS değerinin 60 civarı olması dikey senkronizasyon (vysnc) ile ilgili, etkin olduğu için böyle oluyor. Vsync etkin olduğunda video yırtılmaları vb. görüntü sorunlarını da engelliyor.
Çevrimdışı Çağrı07
  • İleti: 391
    • Kayıt Formu
« Yanıtla #17 : 13 Aralık 2014, 18:56:55 »
Peki masaüstünde ki bumblubee-ui klasörünü silsem sorun olur mu hocam ?
Yaşlanıyorum...
