Gönderen Konu: CS: GO Ekran kartıyla Oynayamama ve Kasma Sorunu  (Okunma sayısı 3658 defa)
Çevrimdışı Çağrı07
  • İleti: 391
    • Kayıt Formu
  • Masaüstü Ortamı: XFCE
« : 15 Ekim 2016, 20:17:38 »
Merhabalar CS:GO'yu Steam üzerinden yükledim ama bumblebee üzerinden nvidia ekran kartıyla oyunu açamadım. Intel'le oynarkende çok kasıyor. Yardımcı olabilir misiniz?
chevy@chevy-Aspire-V3-571G ~ $ inxi -Fxz
System:    Host: chevy-Aspire-V3-571G Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18 Sarah
Machine:   System: Acer product: Aspire V3-571G v: V2.21
           Mobo: Acer model: VA50_HC_CR v: Type2 - Board Version
           Bios: Insyde v: V2.21 date: 12/16/2013
CPU:       Quad core Intel Core i7-3630QM (-HT-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 19155
           clock speeds: max: 3400 MHz 1: 1390 MHz 2: 1230 MHz 3: 1472 MHz
           4: 1200 MHz 5: 1259 MHz 6: 1883 MHz 7: 1755 MHz 8: 1205 MHz
           Card-2: NVIDIA GK107M [GeForce GT 730M] bus-ID: 01:00.0
           Resolution: 1366x768@60.01hz
Network:   Card-1: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe
           driver: tg3 v: 3.137 bus-ID: 02:00.0
           IF: enp2s0f0 state: down mac: <filter>
           Card-2: Qualcomm Atheros AR9462 Wireless Network Adapter
           driver: ath9k bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (22.0% used)
           ID-1: /dev/sda model: TOSHIBA_MQ01ABD1 size: 1000.2GB temp: 39C
Partition: ID-1: / size: 119G used: 36G (32%) fs: ext4 dev: /dev/sda6
Sensors:   System Temperatures: cpu: 57.0C mobo: N/A
Info:      Processes: 242 Uptime: 1:33 Memory: 1180.4/15936.8MB
chevy@chevy-Aspire-V3-571G ~ $ apt-cache policy steam
steam:i386:
  Kurulu: 1:1.0.0.48-1ubuntu3
  Aday:   1:1.0.0.48-1ubuntu3
  Sürüm çizelgesi:
 *** 1:1.0.0.48-1ubuntu3 500
        500 http://archive.ubuntu.com/ubuntu xenial/multiverse i386 Packages
        100 /var/lib/dpkg/status
chevy@chevy-Aspire-V3-571G ~ $ optirun -vvv glxgears
[ 5660.778678] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 5660.779039] [INFO]Configured driver: nvidia
[ 5660.779309] [DEBUG]optirun version 3.2.1 starting...
[ 5660.779328] [DEBUG]Active configuration:
[ 5660.779333] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 5660.779337] [DEBUG] X display: :8
[ 5660.779341] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-367:/usr/lib32/nvidia-367
[ 5660.779345] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 5660.779349] [DEBUG] Accel/display bridge: auto
[ 5660.779357] [DEBUG] VGL Compression: proxy
[ 5660.779370] [DEBUG] VGLrun extra options:
[ 5660.779380] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 5660.779439] [DEBUG]Using auto-detected bridge virtualgl
[ 5661.710449] [INFO]Response: Yes. X is active.
[ 5661.710470] [INFO]Running application using virtualgl.
[ 5661.710591] [DEBUG]Process vglrun started, PID 19546.
9891 frames in 5.0 seconds = 1978.064 FPS
10114 frames in 5.0 seconds = 2022.689 FPS
[VGL] ERROR: in readback--
[ 5672.227018] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 5672.227050] [DEBUG]Socket closed.
[ 5672.227062] [DEBUG]Killing all remaining processes.
chevy@chevy-Aspire-V3-571G ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl'
ii  bumblebee                                    3.2.1-96~xenialppa1                        amd64        NVIDIA Optimus support for Linux
ii  nvidia-367                                   367.44-0ubuntu0~gpu16.04.1                 amd64        NVIDIA binary driver - version 367.44
ii  nvidia-settings                              370.28-0ubuntu0~gpu16.04.1                 amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                       20150328-3~xenialppa1                      amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                            20150328-3~xenialppa1                      amd64        Shared libraries for primus
ii  primus-libs:i386                             20150328-3~xenialppa1                      i386         Shared libraries for primus
ii  primus-libs-ia32:i386                        20150328-3~xenialppa1                      i386         Shared libraries for primus (32-bit)
chevy@chevy-Aspire-V3-571G ~ $ dpkg -l | grep steam
ii  steam:i386                                   1:1.0.0.48-1ubuntu3                        i386         Valve's Steam digital software delivery system
konu güncel
« Son Düzenleme: 16 Ekim 2016, 13:12:13 Gönderen: Çağrı07 »
Yaşlanıyorum...
