Gönderen Konu: [Çözüldü] Laptop Wireless Sorunu  (Okunma sayısı 3456 defa)
Çevrimdışı talebeyim
  • İleti: 2
« : 25 Ekim 2016, 18:55:57 »
Cihazda dahili wireless vardır ve İlgili çıktılar aşağıdaki gibidir
Nasıl kurabilirim ?
inxi -SNx
System:    Host: mm-Latitude-D610 Kernel: 4.4.0-45-generic i686 (32 bit gcc: 5.4.0)
           Distro: Linux Mint 18 Sarah
Network:   Card-1: Broadcom NetXtreme BCM5751 Gigabit Ethernet PCI Express
           driver: tg3 v: 3.137 bus-ID: 02:00.0
           Card-2: Broadcom BCM4309 802.11abg Wireless Network Controller
           driver: b43-pci-bridge bus-ID: 03:03.0
 lspci -nnk | grep -iA2 net
02:00.0 Ethernet controller [0200]: Broadcom Corporation NetXtreme BCM5751 Gigabit Ethernet PCI Express [14e4:1677] (rev 01)
   Subsystem: Dell Latitude D610 [1028:0182]
   Kernel driver in use: tg3
03:03.0 Network controller [0280]: Broadcom Corporation BCM4309 802.11abg Wireless Network Controller [14e4:4324] (rev 03)
   Subsystem: Dell Truemobile 1450 MiniPCI [1028:0003]
   Kernel driver in use: b43-pci-bridge
 lsusb
Bus 001 Device 002: ID 12d1:14db Huawei Technologies Co., Ltd. E353/E3131
Bus 005 Device 002: ID 09da:054f A4Tech Co., Ltd.
Bus 004 Device 002: ID 04f3:0234 Elan Microelectronics Corp.
 rfkill list
 sudo lshw -C network
  *-network
       product: NetXtreme BCM5751 Gigabit Ethernet PCI Express
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 01
       serial: 00:12:3f:18:18:ee
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 firmware=5751-v3.29a latency=0 link=no multicast=yes port=twisted pair
       resources: irq:16 memory:dfdf0000-dfdfffff
  *-network
       description: Network controller
       product: BCM4309 802.11abg Wireless Network Controller
       physical id: 3
       bus info: pci@0000:03:03.0
       version: 03
       width: 32 bits
       clock: 33MHz
       capabilities: bus_master
       configuration: driver=b43-pci-bridge latency=64
       resources: irq:17 memory:dfcfe000-dfcfffff
  *-network
       physical id: 2
       logical name: enx582c80139263
       serial: 58:2c:80:13:92:63
       capabilities: ethernet physical
       configuration: broadcast=yes driver=cdc_ether driverversion=22-Aug-2005 firmware=CDC Ethernet Device ip=192.168.1.100 link=yes multicast=yes
 iwconfig | grep Power
enp2s0    no wireless extensions.
enx582c80139263  no wireless extensions.
 lsmod
dell_laptop            24576  0
cdc_ether              16384  0
b43                   401408  0
gpio_ich               16384  0
usbnet                 45056  1 cdc_ether
snd_intel8x0           36864  2
mii                    16384  1 usbnet
dcdbas                 16384  1 dell_laptop
snd_ac97_codec        106496  1 snd_intel8x0
ac97_bus               16384  1 snd_ac97_codec
bcma                   49152  1 b43
dell_smm_hwmon         16384  0
mac80211              659456  1 b43
snd_pcm                94208  2 snd_ac97_codec,snd_intel8x0
cfg80211              499712  2 b43,mac80211
pcmcia                 57344  0
yenta_socket           45056  0
pcmcia_rsrc            20480  1 yenta_socket
snd                    69632  11 snd_ac97_codec,snd_intel8x0,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_seq_device
pcmcia_core            24576  3 pcmcia,pcmcia_rsrc,yenta_socket
lpc_ich                20480  0
irda                  176128  0
crc_ccitt              16384  1 irda
ip6t_REJECT            16384  1
nf_log_ipv6            16384  5
xt_hl                  16384  22
nf_conntrack_ipv6      20480  8
nf_defrag_ipv6         28672  1 nf_conntrack_ipv6
ipt_REJECT             16384  1
nf_log_ipv4            16384  5
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  10
xt_limit               16384  13
xt_tcpudp              16384  18
nf_conntrack_ipv4      16384  8
xt_conntrack           16384  16
ip6_tables             20480  1 ip6table_filter
nf_nat                 24576  1 nf_nat_ftp
nf_conntrack_ftp       16384  1 nf_nat_ftp
nf_conntrack           98304  8 nf_nat_ftp,nf_conntrack_netbios_ns,nf_nat,xt_conntrack,nf_conntrack_broadcast,nf_conntrack_ftp,nf_conntrack_ipv4,nf_conntrack_ipv6
ip_tables              20480  1 iptable_filter
x_tables               24576  13 ip6table_filter,xt_hl,ip_tables,xt_tcpudp,xt_limit,xt_conntrack,xt_LOG,iptable_filter,ip6t_rt,ipt_REJECT,ip6_tables,xt_addrtype,ip6t_REJECT
btrfs                1003520  0
xor                    28672  1 btrfs
hid                    98304  2 hid_generic,usbhid
i915                 1130496  4
drm_kms_helper        139264  1 i915
tg3                   159744  0
psmouse               118784  0
drm                   311296  6 i915,drm_kms_helper
ahci                   36864  0
ptp                    20480  1 tg3
ssb                    57344  1 b43
pps_core               20480  1 ptp
video                  36864  2 i915,dell_laptop
Düzenleme : Kod etiketi ve forum varsayılan yazıtipi
Bakınız =>
İmla ve Yazım Kuralları
Bakınız => İletilerde code Etiketi Kullanımı
« Son Düzenleme: 25 Ekim 2016, 23:50:04 Gönderen: talebeyim »
Ynt: Laptop Wireless Sorunu
« Yanıtla #1 : 25 Ekim 2016, 21:58:54 »
Sisteminizde kablolu olarak internet bağlantısını sağlayıp aşağıdaki komutlarla firmware-b43-installer paketini kurup, sisteminizi yeniden başlatmayı deneyiniz.
sudo apt-get install firmware-b43-installer
  • İleti: 2
« Yanıtla #2 : 25 Ekim 2016, 22:50:24 »
Butterfly Teşekkür ederim yardımınızla sorun çözüldü.
Linux öğrenmeye çalışıyorum. Şuanda ne yaptığımızı bana anlatabilirmisiniz ?
Birde wifi şifrelerini çözebildiğimiz windows altında kullandığım WPS/WPA gibi bir program vardı.
Linuxta tavsiye edebileceğiniz bir program varmı dır ?
« Yanıtla #3 : 25 Ekim 2016, 22:59:43 »
İlk komutla paket depolarındaki paketlerin bilgilerini güncelledik, ikinci komutla kablosuz ağ aygıtınınçalışması için gerekli sahipli sürücüyü barındıran firmware-b43-installer paketini kurduk.
Forumda pentest dağıtımları ve yazılımlarına destek vermiyoruz.
12- Forumda penetrasyon (sızma) testi ile ilgili dağıtım ve yazılımlara destek verilmemektedir. Böyle içereğe sahip konu ve mesajlar tespit edilmesi veya bildirilmesi durumunda bildirimde bulunulmaksızın kaldırılacaktır.
Konu başlığını etiketlerseniz konuyu kilitleyebiliriz.
[okay]Çözülen başlıkların etiketlenmesi hakkında[/okay]
