Gönderen Konu: [Çözüldü] Cinnamon Çöktü Fallback Kipinde Çalışıyor Hatası  (Okunma sayısı 6701 defa)
Çevrimdışı _X_
  • İleti: 118
  • Grafik Kartı: Ati
  • İşlemci: Amd
17.3 Linux Mint kullanıyorum. 4.4.0-45-generic çekirdeğine güncellediğimde başlıkta belirtilen hatayı almaktayım.
Ekran kartı çıktıları ;
System:    Host: tlg Kernel: 4.4.0-45-generic x86_64 (64 bit gcc: 4.8.4)
           Distro: Linux Mint 17.3 Rosa
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Pitcairn PRO [Radeon HD 7850 / R7 265 / R9 270 1024SP]
           bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 drivers: ati,fglrx (unloaded: fbdev,vesa,radeon)
           Resolution: 1920x1080@60.0hz
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  156 (ATIFGLEXTENSION)
  Minor opcode of failed request:  66 ()
  Serial number of failed request:  13
  Current serial number in output stream:  13
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Pitcairn PRO [Radeon HD 7850 / R7 265 / R9 270 1024SP]
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 1920 x 1920
DFP1 disconnected (normal left inverted right x axis y axis)
DFP2 disconnected (normal left inverted right x axis y axis)
DFP3 disconnected (normal left inverted right x axis y axis)
DFP4 disconnected (normal left inverted right x axis y axis)
DFP5 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 476mm x 268mm
   1920x1080      60.0*+   50.0     59.9     50.0     60.1     60.0
   1600x1200      60.0
   1776x1000      50.0     59.9     50.0     60.0
   1680x1050      60.0
   1400x1050      60.0
   1600x900       60.0
   1280x1024      75.0     60.0
   1440x900       59.9
   1280x960       60.0
   1152x864       59.9     75.0
   1280x768       60.0
   1280x720       50.0     60.0     59.9
   1024x768       75.0     70.1     60.0
   1152x648       50.0     59.9
   720x480        60.0     59.9
   640x480        72.8     75.0     60.0     59.9
DFP6 disconnected (normal left inverted right x axis y axis)
DFP7 disconnected (normal left inverted right x axis y axis)
CRT1 disconnected (normal left inverted right x axis y axis)
tlg[member=97]tlg[/member] ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'
ii  fglrx                                                       2:15.201-0ubuntu0.14.04.1                           amd64        Video driver for the AMD graphics accelerators
ii  fglrx-core                                                  2:15.201-0ubuntu0.14.04.1                           amd64        Minimal video driver for the AMD graphics accelerators
ii  nvidia-prime-applet                                         1.0.3                                               all          An applet for NVIDIA Prime
ii  xvba-va-driver                                              0.7.8-1ubuntu3                                      amd64        XvBA-based backend for VA API (AMD fglrx implementation)
« Son Düzenleme: 26 Ekim 2016, 17:10:35 Gönderen: _X_ »
Ynt: Cinnamon Çöktü Fallback Kipinde Çalışıyor Hatası
« Yanıtla #1 : 26 Ekim 2016, 15:45:25 »
Fglrx sürücüsünün güncel çekirdek için desteği olmadığından çökme yaşanmış. Öncelikle aşağıdaki komutların çıktısını paylaşınız.
apt-get changelog *3.19.0-73*
dpkg -l | grep linux-image
Çevrimdışı _X_
  • İleti: 118
  • Grafik Kartı: Ati
  • İşlemci: Amd
« Yanıtla #2 : 26 Ekim 2016, 15:46:24 »
E: *3.19.0-73* paketi bulunamadı
E: Regex derleme hatası - Önceleme düzenli ifadesi geçersiz
E: '*3.19.0-73*' düzenli ifadesini içeren herhangi bir paket bulunamadı
tlg[member=97]tlg[/member] ~ $ dpkg -l | grep linux-image
ii  linux-image-3.19.0-32-generic                               3.19.0-32.37~14.04.1                                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-45-generic                                4.4.0-45.66~14.04.1                                 amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-3.19.0-32-generic                         3.19.0-32.37~14.04.1                                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-45-generic                          4.4.0-45.66~14.04.1                                 amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
« Yanıtla #3 : 26 Ekim 2016, 16:18:45 »
Çekirdeğin 3.19.0-73 sürümü paket deposunda görünüyor aslında. Buradaki bilgiye göre bu çekirdekte de CVE-2016-5195 ile ilgili düzeltme yapılmış. Bende Linux mint 17.x kurulu olmadığı için doğrulamak istemiştim. Sistemi Grub önyükleyici gelişmiş seçeneklerinden 3.19.0-32 sürüm çekirdek ile açıp, Güncelleme Yöneticisindeki Linux Çekirdekleri aracı yardımıyla 4.4.0-45 sürüm çekirdeği kaldırıp, 3.19.0-73 sürüm çekirdeği kurarsanız sorun çözülecektir.
Çevrimdışı _X_
  • İleti: 118
  • Grafik Kartı: Ati
  • İşlemci: Amd
« Yanıtla #4 : 26 Ekim 2016, 16:36:52 »
Boşu boşuna kurmuş oldum o zaman dimi hocam ? düzeltme yapılmışsa herhangi bir güncelleme yapmadım 3.19.0-32 sürümü daha sonra güvenlik açısından sıkıntı yaşamam değil mi hocam
peki Sistemi Grub önyükleyici gelişmiş seçeneği nası açacağım
« Son Düzenleme: 26 Ekim 2016, 16:43:07 Gönderen: _X_ »
« Yanıtla #5 : 26 Ekim 2016, 16:42:59 »
Çekirdeğin 3.19.0-73.81 sürümü ile bu sorun düzeltilmiş görünüyor.
linux (3.19.0-73.81) vivid; urgency=low
  * CVE-2016-5195
    - SAUCE: mm: remove gup_flags FOLL_WRITE games from __get_user_pages()
 -- Stefan Bader <stefan.bader@canonical.com>  Tue, 18 Oct 2016 10:24:22 +0200
Çekirdek güncelemeleri 3.19.x sürüm için ayrı, 4.4.x sürüm için ayrı ilerliyor. 4.4.x çekirdeği kullananlar 4.4.0-45 sürüm ve sonrasını, 3.19.x sürüm çekirdek kullananların 3.19.0-73 sürüm ve sonrasını kurması gerekiyor.
« Son Düzenleme: 26 Ekim 2016, 16:45:04 Gönderen: Butterfly »
Çevrimdışı _X_
  • İleti: 118
  • Grafik Kartı: Ati
  • İşlemci: Amd
« Yanıtla #6 : 26 Ekim 2016, 16:50:01 »
Hocam peki Sistemi Grub önyükleyici ile açmak için hangi tuşa basmam gerek yani pc yi yeniden başlattığımda bu ekrana nasıl düşeceğim. ?
« Yanıtla #7 : 26 Ekim 2016, 16:52:49 »
Sistemde tek işletim sistemi varsa Grub menüsü gizlenir, açılış sırasında üst karakter (shift) tuşunu basılı tutarsanız ulaşabilirsiniz.
Çevrimdışı _X_
  • İleti: 118
  • Grafik Kartı: Ati
  • İşlemci: Amd
« Yanıtla #8 : 26 Ekim 2016, 17:10:21 »
3.19.0-73-generic çekirdek sürümünü kurdum.Yardımlarınız için gerçekten çok teşekkür ederim.Bu tarz problem yaşayan arkadaşlara da bu  konu çok faydalı olur.
Konuyu kilitlemeden emin olmak için aşağıdaki komutu çalıştırdıktan sonra,
aşağıdaki komutun çıktısını yeniden paylaşınız.
Çevrimdışı _X_
  • İleti: 118
  • Grafik Kartı: Ati
  • İşlemci: Amd
apt-get changelog linux-image-3.19.0-73-generic
Paketin adını tam yazınca değişim günlüğünü indiriyor, Linux Mint 17.3 kurulu bir sistemde aşağıdaki şekilde doğrulama yapabildim. Kurduğunuz çekidek sürümünde CVE-2016-5195 ile ilgili hata düzeltmesi yapılmış görünüyor. Bu sebeple konuyu kilitleyelim.
linux-lts-vivid (3.19.0-73.81~14.04.1) trusty; urgency=low
  * CVE-2016-5195
 -- Seth Forshee <seth.forshee@canonical.com>  Tue, 18 Oct 2016 16:06:08 -0500
linux (3.19.0-71.79) vivid; urgency=low
