Gönderen Konu: Linux Mint 18 Oturumu Kapatma Problemi  (Okunma sayısı 6317 defa)
Çevrimdışı oaydik
  • İleti: 75
  • Dağıtım: Debian-Gnome, LMDE
« : 13 Kasım 2016, 22:33:23 »
Linux Mint 18'de oturumu kapatıp giriyorum ikinci denediğimde ise oturum kapanmıyor ve biraz önce böyle bir hata verdi.
initctl: Upstart'a bağlanılamıyor: Failed to connect to socket /com/ubuntu/upstart: Bağlantı reddedildi
syndaemon: hiçbir işlem bulunamadı
/etc/mdm/Xsession: Beginning session setup...
localuser:evim being added to access control list
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
=== xinerama setup Configuration ===
  Clone: false
  Output: (null) attached to DVI-I-0
     status: off
     width: -1
     height: -1
     rate: -1
     primary: true
     position: -1 -1
  Output: Philips Consumer Electronics Company 17" attached to VGA-0
     status: on
     width: 1280
     height: 1024
     rate: 60
     primary: false
     position: 0 0
  Output: (null) attached to DVI-I-1
     status: off
     width: -1
     height: -1
     rate: -1
     primary: false
     position: -1 -1
  Output: (null) attached to HDMI-0
     status: off
     width: -1
     height: -1
     rate: -1
     primary: false
     position: -1 -1
=== Applying Configuration Configuration ===
  Clone: false
     status: off
     width: -1
     height: -1
     rate: -1
     primary: false
     position: -1 -1
     status: on
     width: 1280
     height: 1024
     rate: 60
     primary: true
     position: 0 0
     status: off
     width: -1
     height: -1
     rate: -1
     primary: false
     position: -1 -1
     status: off
     width: -1
     height: -1
     rate: -1
     primary: false
     position: -1 -1
/usr/lib/blueberry/blueberry-tray.py:5: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
  from gi.repository import Gtk, Gdk, GnomeBluetooth, Gio
/usr/lib/blueberry/blueberry-tray.py:5: PyGIWarning: GnomeBluetooth was imported without specifying a version first. Use gi.require_version('GnomeBluetooth', '1.0') before import to ensure that the right version gets loaded.
sys:1: PyGIWarning: Nemo was imported without specifying a version first. Use gi.require_version('Nemo', '3.0') before import to ensure that the right version gets loaded.
Cjs-Message: JS LOG: About to start Cinnamon
St-Message: cogl npot texture sizes SUPPORTED
Cjs-Message: JS LOG: Cinnamon started at Sun Nov 13 2016 22:25:30 GMT+0300
Cjs-Message: JS LOG: network applet: Cannot find connection for active (or connection cannot be read)
openGL version 3.1 detected (GL3 Cogl Driver)
Cjs-Message: JS LOG: Invalid network device type, is 14
Cjs-Message: JS LOG: network applet: Found connection for active
(cinnamon:3893): St-WARNING **: Failed to load /home/evim/.themes/Linux Mint Blue/cinnamon/scroll-vhandle.svg: Dosya açılırken hata: Böyle bir dosya ya da dizin yok
Initializing folder-color-switcher extension...
cinnamon-session[3713]: WARNING: t+7,77367s: Playing logout sound '/usr/share/mint-artwork-cinnamon/sounds/logout.ogg'
cinnamon-session[3713]: WARNING: t+7,88335s: Finished playing logout sound
cinnamon-session[3713]: WARNING: t+7,88349s: Resuming logout sequence...
Düzenleme : Kod etiketi
« Son Düzenleme: 14 Kasım 2016, 14:55:56 Gönderen: Butterfly »
Ynt: Linux Mint 18 Oturumu Kapatma Problemi
« Yanıtla #1 : 14 Kasım 2016, 14:56:46 »
Linux Mint 18'e, Linux Mint 17.3'den yükseltme ile mi geçiş yaptınız?
Ayrıca aşağıdaki komutun çıktısını da rica edelim.
« Son Düzenleme: 14 Kasım 2016, 15:00:41 Gönderen: Butterfly »
Çevrimdışı oaydik
  • İleti: 75
« Yanıtla #2 : 14 Kasım 2016, 18:48:32 »
iso kalıbını doğrudan indirdim ancak bazı gereksiz ofis uygulamalarını kaldırdım.
System:    Host: evim-System-Product-Name Kernel: 4.4.0-47-generic x86_64 (64 bit gcc: 5.4.0)
           Distro: Linux Mint 18 Sarah
Machine:   Mobo: ASUSTeK model: M4A78-AM v: Rev X.0x
           Bios: American Megatrends v: 1301 date: 01/04/2010
CPU:       Triple core AMD Athlon II X3 425 (-MCP-) cache: 1536 KB
           flags: (lm nx sse sse2 sse3 sse4a svm) bmips: 16243
           clock speeds: max: 2700 MHz 1: 2100 MHz 2: 2100 MHz 3: 2700 MHz
Graphics:  Card: NVIDIA G92 [GeForce 9800 GT] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 driver: nvidia
           Resolution: [email]1280x1024@60.02hz[/email]
           GLX Renderer: GeForce 9800 GT/PCIe/SSE2
           GLX Version: 3.3.0 NVIDIA 340.98 Direct Rendering: Yes
Audio:     Card Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           driver: snd_hda_intel bus-ID: 00:14.2
           Sound: Advanced Linux Sound Architecture v: k4.4.0-47-generic
           driver: r8169 v: 2.3LK-NAPI port: e800 bus-ID: 02:00.0
           IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 335.7GB (3.5% used)
           ID-1: /dev/sda model: WDC_WD3200AVJS size: 320.1GB
           ID-2: USB /dev/sdb model: Cruzer_Blade size: 15.6GB
Partition: ID-1: / size: 60G used: 6.7G (12%) fs: ext4 dev: /dev/sda6
           ID-2: swap-1 size: 3.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 52.0C mobo: 35.0C gpu: 0.0:45C
           Fan Speeds (in rpm): cpu: 2896 sys-1: 0
Info:      Processes: 174 Uptime: 2 min Memory: 575.1/3951.2MB
« Son Düzenleme: 16 Kasım 2016, 08:50:03 Gönderen: Butterfly »
« Yanıtla #3 : 15 Kasım 2016, 11:43:51 »
Aşağıdaki komutun çıktısına da bakalım.
dpkg -l | egrep 'cinnamon|sesssion|mint-meta'
Çevrimdışı oaydik
  • İleti: 75
« Yanıtla #4 : 15 Kasım 2016, 23:15:50 »
ii  cinnamon                                     3.0.7+sarah                                amd64        Modern Linux desktop
ii  cinnamon-common                              3.0.7+sarah                                all          Cinnamon desktop (Common data files)
ii  cinnamon-control-center                      3.0.1+sarah                                amd64        utilities to configure the Cinnamon desktop
ii  cinnamon-control-center-data                 3.0.1+sarah                                all          configuration applets for Cinnamon - data files
ii  cinnamon-desktop-data                        3.0.2+sarah                                all          Common files for Cinnamon desktop apps
ii  cinnamon-l10n                                3.0.3                                      all          Translation files for the Cinnamon desktop
ii  cinnamon-screensaver                         3.0.1+sarah                                amd64        Cinnamon screen saver and locker
ii  cinnamon-session                             3.0.1+sarah                                amd64        Cinnamon Session Manager - Minimal runtime
ii  cinnamon-session-common                      3.0.1+sarah                                all          Cinnamon Session Manager - common files
ii  cinnamon-settings-daemon                     3.0.1+sarah                                amd64        daemon handling the Cinnamon session settings
ii  cinnamon-themes                              2016.05.03                                 all          Cinnamon themes
ii  gir1.2-cinnamondesktop-3.0                   3.0.2+sarah                                amd64        Introspection data for CinnamonDesktop
ii  libcinnamon-control-center1:amd64            3.0.1+sarah                                amd64        utilities to configure the Cinnamon desktop
ii  libcinnamon-desktop4:amd64                   3.0.2+sarah                                amd64        Cinnamon library for loading .desktop files
ii  libcinnamon-menu-3-0                         3.0.2+sarah                                amd64        Cinnamon implementation of the freedesktop menu specification
ii  mint-artwork-cinnamon                        5.2                                        all          Default artwork for the Cinnamon edition of Linux Mint
rc  mint-info-cinnamon                           2016.01.11                                 amd64        Necessary information about the Linux Mint release and edition.
ii  mint-meta-cinnamon                           2016.07.23                                 all          Set of packages installed by default in the Cinnamon edition of Linux Mint
ii  mint-meta-codecs                             2016.05.04                                 all          All the packages required for multimedia support in Linux Mint.
ii  mint-meta-codecs-core                        2016.05.04                                 all          All the packages required for multimedia support in Linux Mint.
ii  mint-meta-core                               2016.07.23                                 all          Core Linux Mint packages
ii  mint-meta-mate                               2016.07.23                                 all          Set of packages installed by default in the MATE edition of Linux Mint
« Son Düzenleme: 16 Kasım 2016, 08:51:20 Gönderen: Butterfly »
« Yanıtla #5 : 16 Kasım 2016, 21:11:55 »
Aşağıdaki komutların çıktılarına da bakalım.
dpkg -l | grep mdm
Bu arada Cinnamon temanızı değiştirmeyi dener misiniz?
Çevrimdışı oaydik
  • İleti: 75
« Yanıtla #6 : 17 Kasım 2016, 19:56:29 »
dpkg -l | grep mdm
evim@evim-System-Product-Name ~ $ inxi -Fxz
           flags: (lm nx sse sse2 sse3 sse4a svm) bmips: 16246
           clock speeds: max: 2700 MHz 1: 1500 MHz 2: 2100 MHz 3: 800 MHz
           Resolution: 1280x1024@60.02hz
Partition: ID-1: / size: 60G used: 6.8G (12%) fs: ext4 dev: /dev/sda6
Sensors:   System Temperatures: cpu: 45.0C mobo: 34.0C gpu: 0.0:44C
           Fan Speeds (in rpm): cpu: 2755 sys-1: 0
Info:      Processes: 172 Uptime: 1:07 Memory: 712.6/3951.2MB
evim@evim-System-Product-Name ~ $ dpkg -l | grep mdm
ii  mdm                                          2.0.10+sarah                               amd64        MDM Display Manager
ii  mint-mdm-themes                              2014.10.29                                 all          Linux Mint MDM Themes
ii  mint-mdm-themes-gdm                          1.8.1                                      all          Linux Mint MDM Themes
ii  mint-mdm-themes-html                         2.0.10                                     all          Linux Mint MDM Themes
