Gönderen Konu: [Çözüldü] dpkg dosyalarını bulamıyor  (Okunma sayısı 6451 defa)
Çevrimdışı meriyd
  • İleti: 11
    • iremydkc
  • Dağıtım: mint,ubuntu
« : 01 Aralık 2016, 01:12:10 »
upgrade ve install işlemlerinde aşağıdaki hatayı veriyor
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
9 not fully installed or removed.
Need to get 24,5 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu/ trusty-updates/main libavahi-client3 i386 0.6.31-4ubuntu1.1 [24,5 kB]
Fetched 24,5 kB in 0s (85,6 kB/s)
dpkg: error processing package libavahi-client3:i386 (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
dpkg: dependency problems prevent configuration of libcups2:i386:
 libcups2:i386 depends on libavahi-client3 (>= 0.6.16); however:
  Package libavahi-client3:i386 is not configured yet.
dpkg: error processing package libcups2:i386 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libcupsfilters1:i386:
 libcupsfilters1:i386 depends on libcups2 (>= 1.7.0); however:
  Package libcups2:i386 is not configured yet.
dpkg: error processing package libcupsfilters1:i386 (--configure):
dpkg: dependency problems prevent configuration of libcupsimage2:i386:
 libcupsimage2:i386 depends on libcups2 (= 1.7.2-0ubuntu1.7); however:
 libcupsimage2:i386 depends on libcupsfilters1 (>= 1.0~b1); however:
  Package libcupsfilters1:i386 is not configured yet.
dpkg: error processing package libcupsimage2:i386 (--configure):
dpkg: dependency problems prevent configuration of libgtk2.0-0:i386:
 libgtk2.0-0:i386 depends on libcups2 (>= 1.6.2); however:
dpkg: error processing package libgtk2.0-0:i386 (--configure):
dpkg: dependency problems prevent configuration of libgail18:i386:
 libgail18:i386 depends on libgtk2.0-0 (= 2.24.23-0ubuntu1.4); however:
  Package libgtk2.0-0:i386 is not configured yet.
dpkg: error processing package libgail18:i386 (--configure):
dpkg: dependency problems prevent configuration of gtk2-engines-pixbuf:i386:
 gtk2-engines-pixbuf:i386 depends on libgtk2.0-0 (= 2.24.23-0ubuntu1.4); however:
dpkg: error processing package gtk2-engines-pixbuf:i386 (--configure):
dpkg: dependency problems prevent configuration of ibus-gtk:i386:
 ibus-gtk:i386 depends on libgtk2.0-0 (>= 2.24.5-4); however:
dpkg: error processing package ibus-gtk:i386 (--configure):
dpkg: dependency problems prevent configuration of libgail-common:i386:
 libgail-common:i386 depends on libgail18 (= 2.24.23-0ubuntu1.4); however:
  Package libgail18:i386 is not configured yet.
dpkg: error processing package libgail-common:i386 (--configure):
 libcups2:i386
 libcupsimage2:i386
 libgtk2.0-0:i386
 libgail18:i386
 ibus-gtk:i386
 libgail-common:i386
bu kütüphane dosyalarını elle kurmaya çalışıyorum aşağıdaki libavahi kütüphanesinde olduğu gibi  bir hata veriyor:
bin# apt-get install libavahi
E: Unable to locate package libavahi
çok fazla komut denedim ancak hep ilk yazdığım uzun hatayı alıyorum ne yapabilirim? bu arada /usr/bin altında dpkg dosyaları görünüyor. /usr/lib altında dpkg için
dpkg                                    libkcddb.so.4                          libpimactivity.so.4
olarak görülüyor.
« Son Düzenleme: 03 Aralık 2016, 04:32:32 Gönderen: meriyd »
Ynt: dpkg dosyalarını bulamıyor
« Yanıtla #1 : 01 Aralık 2016, 01:20:29 »
Sanırım 32 bit uygulama kurmaya çalışıyorsunuz.
sudo dpkg --add-architecture i386
sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386
Bunu deneyin.
Çevrimdışı meriyd
  • İleti: 11
    • iremydkc
« Yanıtla #2 : 01 Aralık 2016, 01:23:50 »
stackoverflow,linux forum ve askubuntu dan buna yönelik komutlar denedim ancak hep ilk yazdığım uzun hatayı alıyorum ne yapabilirim? bu arada gerekli olur mu bilmiyorum ama  /usr/bin altında dpkg dosyaları görünüyor. /usr/lib altında dpkg için
olarak görülüyor.
[/quote]
aslında çalışmıyorum sadece update ettim ve upgrade sonrasında bu hatayı almaya başladım mesela git i kurmak isityorum
sudo apt-get install git ama yine bu hatayı alıyorum yazdığınız komutlar geçerli mi hala :)
« Son Düzenleme: 01 Aralık 2016, 01:31:28 Gönderen: meriyd »
« Yanıtla #3 : 01 Aralık 2016, 01:39:17 »
çıktısına bakalım muhtemelen size telegram için ilk verdiğim depo sorunsalından dolayı hata alıyorsunuz bakalım ona göre ppa adreslerini silelim.
Çevrimdışı meriyd
  • İleti: 11
    • iremydkc
« Yanıtla #4 : 01 Aralık 2016, 01:43:45 »
evet muhtemelen
Ign http://archive.ubuntu.com trusty InRelease
Ign http://archive.canonical.com trusty InRelease
Get:1 http://archive.ubuntu.com trusty-updates InRelease [65,9 kB]
Hit http://archive.canonical.com trusty Release.gpg
Get:2 http://security.ubuntu.com trusty-security InRelease [65,9 kB]
Ign http://packages.linuxmint.com rosa InRelease
Ign http://extra.linuxmint.com rosa InRelease
Hit http://archive.canonical.com trusty/partner amd64 Packages
Hit http://extra.linuxmint.com rosa Release.gpg
Hit http://packages.linuxmint.com rosa Release.gpg
Hit http://archive.ubuntu.com trusty Release.gpg
Hit http://archive.canonical.com trusty/partner i386 Packages
Get:3 http://archive.ubuntu.com trusty-updates/main amd64 Packages [926 kB]
Hit http://archive.canonical.com trusty/partner Translation-en
Get:4 http://security.ubuntu.com trusty-security/main amd64 Packages [562 kB]
Hit http://extra.linuxmint.com rosa/main amd64 Packages
Hit http://packages.linuxmint.com rosa/main amd64 Packages
Hit http://extra.linuxmint.com rosa/main i386 Packages
Hit http://packages.linuxmint.com rosa/upstream amd64 Packages
Get:5 http://archive.ubuntu.com trusty-updates/restricted amd64 Packages [16,4 kB]
Get:6 http://archive.ubuntu.com trusty-updates/universe amd64 Packages [389 kB]
Hit http://packages.linuxmint.com rosa/import amd64 Packages
Hit http://packages.linuxmint.com rosa/main i386 Packages
Get:7 http://archive.ubuntu.com trusty-updates/multiverse amd64 Packages [14,0 kB]
Get:8 http://archive.ubuntu.com trusty-updates/main i386 Packages [886 kB]
Hit http://packages.linuxmint.com rosa/upstream i386 Packages
Hit http://packages.linuxmint.com rosa/import i386 Packages
Get:9 http://security.ubuntu.com trusty-security/restricted amd64 Packages [13,3 kB]
Get:10 http://security.ubuntu.com trusty-security/universe amd64 Packages [145 kB]
Ign http://extra.linuxmint.com rosa/main Translation-en_US
Get:11 http://archive.ubuntu.com trusty-updates/restricted i386 Packages [16,2 kB]
Get:12 http://archive.ubuntu.com trusty-updates/universe i386 Packages [390 kB]
Get:13 http://security.ubuntu.com trusty-security/multiverse amd64 Packages [4.138 B]
Get:14 http://archive.ubuntu.com trusty-updates/multiverse i386 Packages [14,5 kB]
Get:15 http://security.ubuntu.com trusty-security/main i386 Packages [521 kB]
Hit http://archive.ubuntu.com trusty-updates/main Translation-en
Hit http://archive.ubuntu.com trusty-updates/multiverse Translation-en
Hit http://archive.ubuntu.com trusty-updates/restricted Translation-en
Hit http://archive.ubuntu.com trusty-updates/universe Translation-en
Hit http://archive.ubuntu.com trusty/main amd64 Packages
Hit http://archive.ubuntu.com trusty/restricted amd64 Packages
Hit http://archive.ubuntu.com trusty/universe amd64 Packages
Hit http://archive.ubuntu.com trusty/multiverse amd64 Packages
Hit http://archive.ubuntu.com trusty/main i386 Packages
Hit http://archive.ubuntu.com trusty/restricted i386 Packages
Hit http://archive.ubuntu.com trusty/universe i386 Packages
Hit http://archive.ubuntu.com trusty/multiverse i386 Packages
Hit http://archive.ubuntu.com trusty/main Translation-en
Hit http://archive.ubuntu.com trusty/multiverse Translation-en
Hit http://archive.ubuntu.com trusty/restricted Translation-en
Hit http://archive.ubuntu.com trusty/universe Translation-en
Get:16 http://security.ubuntu.com trusty-security/restricted i386 Packages [13,1 kB]
Get:17 http://security.ubuntu.com trusty-security/universe i386 Packages [145 kB]
Get:18 http://security.ubuntu.com trusty-security/multiverse i386 Packages [4.289 B]
Get:19 http://security.ubuntu.com trusty-security/main Translation-en [307 kB]
Ign http://archive.ubuntu.com trusty/main Translation-en_US
Ign http://archive.ubuntu.com trusty/multiverse Translation-en_US
Ign http://archive.ubuntu.com trusty/restricted Translation-en_US
Ign http://archive.ubuntu.com trusty/universe Translation-en_US
Ign http://packages.linuxmint.com rosa/import Translation-en_US
Ign http://packages.linuxmint.com rosa/main Translation-en_US
Get:20 http://security.ubuntu.com trusty-security/multiverse Translation-en [2.201 B]
Get:21 http://security.ubuntu.com trusty-security/restricted Translation-en [3.349 B]
Ign http://packages.linuxmint.com rosa/upstream Translation-en_US
Get:22 http://security.ubuntu.com trusty-security/universe Translation-en [85,3 kB]
Fetched 4.590 kB in 9s (464 kB/s)
« Yanıtla #5 : 01 Aralık 2016, 09:03:01 »
ilk komut için 'This PPA does not support trusty'
Cannot add PPA: ''This PPA does not support trusty''.
Telegram kurulumu için verilen PPA deposu, sürüm desteklemediği için sisteme eklenmemiş.
Aşağıdaki komutla bağımlılık sorunlarını çözmeyi deneyebilirsiniz. Bazen kuruum sonrası betiği, yerel dilde sorun çıkartabiliyor, bu sebeple paketlerin yapılandırması tam olarak bitmediği varsayılıyor. Bu olası osrunun etrafından dolaşmak için, komutu aşağıdaki şekilde çalıştırınca, bağımlılık ve yapılandırma sorunlarını çözmek için apt'yi varsayılan dilde çalıştırmış oluyoruz.
env LC_ALL=C sudo apt-get install -f
Çevrimdışı meriyd
  • İleti: 11
    • iremydkc
« Yanıtla #6 : 01 Aralık 2016, 09:14:10 »
maalesef olmadı
Need to get 0 B/24.5 kB of archives.
yerel dil demişsiniz ilk kurduğumda ingilizceydi sonra sistem ayarlarından değiştirdim dili değiştirsem ingiliceye sorun çözülür mü yani?
« Son Düzenleme: 01 Aralık 2016, 09:17:11 Gönderen: meriyd »
« Yanıtla #7 : 01 Aralık 2016, 09:23:40 »
Yukarıdaki komutla çalıştırınca aynı kapıya çıkıyor, bu zaten her zaman görülebilen bir durum değil, ufak da olsa olasılık olduğu için bu şekilde önerdim. Görülüyor ki farklı bir sorun var ortada. Aşağıdaki komutun çıktısına bakalım bir de.
inxi -Sr
Çevrimdışı meriyd
  • İleti: 11
    • iremydkc
« Yanıtla #8 : 01 Aralık 2016, 09:38:19 »
System:    Host: Linux Kernel: 3.19.0-32-generic x86_64 (64 bit) Desktop: KDE Plasma 4.14.2
           Distro: Linux Mint 17.3 Rosa
Repos:     Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
           deb http://packages.linuxmint.com rosa main upstream import #id:linuxmint_main
           deb http://extra.linuxmint.com rosa main #id:linuxmint_extra
« Yanıtla #9 : 01 Aralık 2016, 11:42:34 »
Aşağıdaki şekilde sistemi güncelleyerek kurulum deneyelim.
sudo apt-get upgrade
sudo apt-get dist-upgrade
Güncelleme sırasında bazı yapılandırma dosyalarının içeriğinin değiştirilmesi ile ilgili uyarı alabilirsiniz, bu durumda dosyaların olduğu gibi kalması için varsayılan (N) tuş seçeneğini kullanınız.
Çevrimdışı meriyd
  • İleti: 11
    • iremydkc
« Yanıtla #10 : 03 Aralık 2016, 04:31:53 »
sudo apt-get install --reinstall libavahi-client3:i386 ile sorun çözüldü arkadaşlar teşekkür ederim
