Gönderen Konu: nvidia 620 ve intel ekran kartı bumblebee sorunu  (Okunma sayısı 4441 defa)
Çevrimdışı oflu61
  • İleti: 3
  • Dağıtım: linux mint debian edition x64 ve pardus
  • Grafik Kartı: nvidia 620m
  • İşlemci: intel
« : 11 Aralık 2016, 01:20:18 »
Merhaba
System:    Host: corleone Kernel: 3.16.0-4-amd64 x86_64 (64 bit gcc: 4.8.4)
           Desktop: Cinnamon 2.4.7 (Gtk 3.14.5+4) Distro: LinuxMint 2 betsy
           Card-2: NVIDIA GF108M [GeForce GT 620M] bus-ID: 01:00.0
           Display Server: X.Org 1.16.4 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.07hz
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 620M] (rev ff)
LVDS1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1366x768      60.07*+
   1360x768      59.80    59.96
   1024x768      60.00
   800x600       60.32    56.25
   640x480       59.94
ii  bumblebee                                    3.2.1-7                             amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                             3.2.1-7                             amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  glx-alternative-nvidia                       0.5.1                               amd64        allows the selection of NVIDIA as GLX provider
ii  libegl1-nvidia:amd64                         340.96-1                            amd64        NVIDIA binary EGL libraries
ii  libgl1-nvidia-glx:amd64                      340.96-1                            amd64        NVIDIA binary OpenGL libraries
ii  libnvidia-eglcore:amd64                      340.96-1                            amd64        NVIDIA binary EGL core libraries
ii  libnvidia-ml1:amd64                          340.96-1                            amd64        NVIDIA Management Library (NVML) runtime library
ii  nvidia-alternative                           340.96-1                            amd64        allows the selection of NVIDIA as GLX provider
ii  nvidia-driver                                340.96-1                            amd64        NVIDIA metapackage
ii  nvidia-driver-bin                            340.96-1                            amd64        NVIDIA driver support binaries
ii  nvidia-installer-cleanup                     20141201+1                          amd64        cleanup after driver installation with the nvidia-installer
ii  nvidia-kernel-common                         20141201+1                          amd64        NVIDIA binary kernel module support files
ii  nvidia-kernel-dkms                           340.96-1                            amd64        NVIDIA binary kernel module DKMS source
ii  nvidia-modprobe                              340.46-1                            amd64        utility to load NVIDIA kernel modules and create device nodes
ii  nvidia-settings                              340.46-2                            amd64        tool for configuring the NVIDIA graphics driver
ii  nvidia-support                               20141201+1                          amd64        NVIDIA binary graphics driver support files
ii  nvidia-vdpau-driver:amd64                    340.96-1                            amd64        Video Decode and Presentation API for Unix - NVIDIA driver
ii  nvidia-xconfig                               340.46-1                            amd64        X configuration tool for non-free NVIDIA drivers
ii  primus                                       0~20140711-1                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                            0~20140711-1                        amd64        Shared libraries for primus
ii  primus-libs:i386                             0~20140711-1                        i386         Shared libraries for primus
ii  primus-libs-ia32                             0~20140711-1                        i386         Shared libraries for primus (32-bit)
ii  xserver-xorg-video-nvidia                    340.96-1                            amd64        NVIDIA binary Xorg driver
glxgears  tek başına çalıştırdıgmda.
Running synchronized to the vertical refresh.  The framerate should be
approximately the same as the monitor refresh rate.
302 frames in 5.0 seconds = 60.201 FPS
301 frames in 5.0 seconds = 60.089 FPS
301 frames in 5.0 seconds = 60.083 FPS
301 frames in 5.0 seconds = 60.085 FPS
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
      after 4901 requests (4901 known processed) with 0 events remaining.
optirun glxgears çalıştırdıgımda.
304 frames in 5.0 seconds = 60.718 FPS
301 frames in 5.0 seconds = 60.086 FPS
301 frames in 5.0 seconds = 60.084 FPS
aralarında hiç fark yok sanırım 2. ekran kartım sağlıklı çalışmıyor ayrıca nvidia-settings de sürekli xorg.conf dosyası duzenlememı ıstıyor.  nvidia-xconfig ile oluşturur isem xorg açılışta hata veriyor açılmıyor.
forumdaki bumbble kurulumu debian versiyonda  bahsedilen paketler depolara eklenmıyor ppa desteklenmiyor hatası alıyorum.
yardımcı olamanız dileğiyle iyi forumlar saygılar
Ynt: nvidia 620 ve intel ekran kartı bumblebee sorunu
« Yanıtla #1 : 11 Aralık 2016, 10:27:51 »
Lütfen forum kurallarımız arasında bulunan ve önemsediğimiz  yazım kurallarına özen gösteriniz.
[warning]İmla ve Yazım Kuralları[/warning]
Bumblebee'nin çalışmasında sorun yok, olması gerektiği gibi çalışıyor. Şu an köprü olarak primus kullanılıyor, primus köprüsünde varsayılan dikey eşitleme (vsync) etkin olduğundan 60 FPS üstüne çıkış olmuyor sadece.
LMDE, Debian tabanlı ve PPA depolarını desteklemez. Forumda anlatılan konuda LMDE kurulumu için PPA deposu eklemesinden bahsedilmiyor.
https://forum.linuxmint.net.tr/index.php?topic=5777.msg36742#msg36742
« Son Düzenleme: 11 Aralık 2016, 10:29:12 Gönderen: Butterfly »
Çevrimdışı oflu61
  • İleti: 3
  • İşlemci: intel
« Yanıtla #2 : 11 Aralık 2016, 15:06:17 »
Merhabalar  öncelikle verdiğiniz yanıtlar için teşekkürler.
Şöyle bir kullanım söz konusu olabilirmi ya intel ya nvidia şeklinde köprü modunu kullanmak istemiyorum.
LMDE2 64 bit için  nvidia resmi sitesinden indiridğim run dosyasıyla kurulum yaptıgımda xorg ile ilgili yapılandırma hatası alıyorum. Bu hatanın bir çözümü varmıdır.
iyi forumlar
« Yanıtla #3 : 11 Aralık 2016, 19:33:56 »
Debian tabanlı sistemlerde Intel + Nvidia hibrit GPU'lu sistemler için tek seçenek Bumblebee. İndirdiğiniz sürücüyü doğrudan kuramazsınız. Ubuntu tabanlı Linux Mint (17.x , 18.x gibi) serisinde ayrıca Nvidia Prime çözümü var, bunu LMDE'de kullanamıyorsunuz.
Çevrimdışı oflu61
  • İleti: 3
  • İşlemci: intel
« Yanıtla #4 : 11 Aralık 2016, 21:46:31 »
malesef ubuntu tabanli linux mint ve ubuntu bilgisayarimda calismiyor daha aciklayici olmak gerekiyorsa bilgisayarimi boot ettikten sonra cok asiri bir kasma basliyor bilgisayari kapatmak bile imkansiz hala geliyor bundan dolayi debian ile devam etmek zorunda kaliyorum.
Linux mint debian 2  cok basarili bir dagitim bence cinnamon kde mate xfce  gibi masa ustlerinden cok daha iyi durumda  birazda pardus a katki saglamak adina suan icin pardus debian surumune geridonuyorum yanitlariniz icin cok cok tesekkurler saygilar iyi forumlar.
