Gönderen Konu: hp compaq 6720s wifi girmiyor driver  (Okunma sayısı 2505 defa)
Çevrimdışı secretsens
  • İleti: 1
  • Dağıtım: mint 18
  • Masaüstü Ortamı: loptop
« : 11 Aralık 2016, 13:36:53 »
ILK DEFA LINUX KULLANIYORUM YUKLEDIM LINUX 18 FAKAT BIR TURLU WIRELESS GIRMIYOR YARDIMCI OLURSANIZ .OK MEMNUN OLURUM
System:    Host: mint Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
           Distro: Linux Mint 18 Sarah
Network:   Card-1: Intel 82562GT 10/100 Network Connection
           driver: e1000e v: 3.2.6-k port: 4020 bus-ID: 00:19.0
           Card-2: Broadcom BCM4311 802.11a/b/g
           driver: b43-pci-bridge bus-ID: 10:00.0
00:19.0 Ethernet controller [0200]: Intel Corporation 82562GT 10/100 Network Connection [8086:10c4] (rev 03)
   Subsystem: Hewlett-Packard Company 82562GT 10/100 Network Connection [103c:30d8]
   Kernel driver in use: e1000e
   Kernel modules: e1000e
10:00.0 Network controller [0280]: Broadcom Corporation BCM4311 802.11a/b/g [14e4:4312] (rev 02)
   Subsystem: Hewlett-Packard Company Broadcom 802.11a/b/g WLAN [103c:1371]
   Kernel driver in use: b43-pci-bridge
Bus 002 Device 003: ID 0781:5571 SanDisk Corp. Cruzer Fit
Bus 004 Device 002: ID 04d9:0499 Holtek Semiconductor, Inc. Optical Mouse
0: hp-wifi: Wireless LAN
   Soft blocked: no
   Hard blocked: no
1: hp-bluetooth: Bluetooth
   Soft blocked: yes
   Hard blocked: no
2: hp-gps: GPS
   Soft blocked: yes
   Hard blocked: yes
 *-network
       product: 82562GT 10/100 Network Connection
       vendor: Intel Corporation
       physical id: 19
       bus info: pci@0000:00:19.0
       logical name: enp0s25
       version: 03
       serial: 00:1a:4b:8a:43:f6
       capacity: 100Mbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=1.1-2 ip=192.168.1.139 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:27 memory:e4600000-e461ffff memory:e4620000-e4620fff ioport:4020(size=32)
  *-network
       description: Network controller
       product: BCM4311 802.11a/b/g
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:10:00.0
       version: 02
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=b43-pci-bridge latency=0
       resources: irq:17 memory:e4000000-e4003fff
enp0s25   no wireless extensions.
b43                   417792  0
bcma                   53248  1 b43
snd_hda_codec_analog    16384  1
snd_hda_codec_generic    77824  1 snd_hda_codec_analog
snd_hda_intel          36864  3
mac80211              737280  1 b43
snd_hda_codec         135168  4 snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_codec_analog
snd_hda_core           73728  5 snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_hda_codec_analog
snd_pcm               106496  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
cfg80211              565248  2 b43,mac80211
ssb_hcd                16384  0
snd                    81920  17 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_hda_codec_analog
tpm_infineon           20480  0
hp_accel               28672  0
lis3lv02d              20480  1 hp_accel
input_polldev          16384  1 lis3lv02d
squashfs               49152  1
overlay                49152  1
usb_storage            69632  2 uas
i915                 1208320  3
drm_kms_helper        139264  1 i915
psmouse               126976  0
ahci                   36864  0
drm                   360448  5 i915,drm_kms_helper
e1000e                237568  0
ssb                    65536  2 b43,ssb_hcd
ptp                    20480  1 e1000e
pps_core               20480  1 ptp
wmi                    20480  1 hp_wmi
video                  40960  1 i915
ANLAYAN BIR YARDIMCI OLURSA SEVINIRIM BIRDE FLASHA KURDUM BEN LINUX U DILINI DEGISTIRIYORUM HER DEFASINDA ACILIP KAPANINCA BASA DONUYOR DILI INGILIZCE OLUYOR NASIL OLACAK BEN BIR TURLU ANLAMADIM BU PROGRAMI
« Son Düzenleme: 11 Aralık 2016, 14:24:23 Gönderen: secretsens »
Ynt: hp compaq 6720s wifi girmiyor driver
« Yanıtla #1 : 11 Aralık 2016, 19:41:16 »
Yazdıklarınızı okumak gerçekten zorlayıcı, bağlantıdaki gibi düzeltirseniz yönlendirme yapalım. İmla ve Yazım Kuralları
