Gönderen Konu: [Çözüldü] Linux Mint Hotspot Yavaş Bağlantı Sorunu  (Okunma sayısı 2624 defa)
Çevrimdışı karayel90
  • İleti: 6
  • Dağıtım: Linux Mint 18.1 (4.9.4 Kernel)
  • Masaüstü Ortamı: Cinnamon 3.2.7
  • Grafik Kartı: İntel Hd Graphics
  • İşlemci: İ3 M370 2.40 GHz
Merhaba arkadaşlar
Linux mint üzerinden hotspot ağı oluşturuyorum bilgisayarda internet  hızı iyi yanlız hotspot ağından aldığım internet oldukça yavaş acaba sorun nedir yardımcı olursanız sevinirim
karayel@karayel-Vostro-1540 ~ $ inxi -SNx
System:    Host: karayel-Vostro-1540 Kernel: 4.4.0-59-generic i686 (32 bit gcc: 5.4.0)
Network:   Card-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter
           driver: bcma-pci-bridge bus-ID: 12:00.0
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 13:00.0
           Card-3: Ralink RT2870/RT3070 Wireless Adapter
           driver: rt2800usb v: 2.3.0 usb-ID: 002-004
karayel@karayel-Vostro-1540 ~ $ lspci -nnk | grep -iA2 net
12:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
Subsystem: Dell BCM4313 802.11bgn Wireless Network Adapter [1028:0012]
Kernel driver in use: bcma-pci-bridge
Kernel modules: bcma
13:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06)
Subsystem: Dell RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1028:0526]
Kernel driver in use: r8169
Kernel modules: r8169
karayel@karayel-Vostro-1540 ~ $ lsusb
Bus 002 Device 004: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 002 Device 003: ID 046d:c52e Logitech, Inc. MK260 Wireless Combo Receiver
Bus 001 Device 004: ID 0bda:58c1 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 0a5c:21bc Broadcom Corp. BCM2070 Bluetooth 2.1 + EDR
karayel@karayel-Vostro-1540 ~ $ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
karayel@karayel-Vostro-1540 ~ $ sudo lshw -C network
[sudo] password for karayel:
  *-network
       açıklama: Network controller
       ürün: BCM4313 802.11bgn Wireless Network Adapter
       üretici: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:12:00.0
       sürüm: 01
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: pm msi pciexpress bus_master cap_list
       yapılandırma: driver=bcma-pci-bridge latency=0
       kaynaklar: irq:17 bellek:fbe00000-fbe03fff
  *-network
       açıklama: Eternet interface
       physical id: 0
       bus info: pci@0000:13:00.0
       mantıksal ad: enp19s0
       sürüm: 06
       serial: 18:03:73:98:3b:b8
       boyut: 10Mbit/s
       kapasite: 1Gbit/s
       genişlik: 64 bits
       saat: 33MHz
       yapılandırma: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8168e-2.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       kaynaklar: irq:28 ioport:e000(boyut=256) bellek:d0b04000-d0b04fff bellek:d0b00000-d0b03fff
  *-network:0
       açıklama: Kablosuz arayüz
       physical id: 2
       bus info: usb@2:1.4
       mantıksal ad: wlx983f9f22836d
       serial: 98:3f:9f:22:83:6d
       yapılandırma: broadcast=yes driver=rt2800usb driverversion=4.4.0-59-generic firmware=0.29 ip=192.168.1.43 link=yes multicast=yes wireless=IEEE 802.11bgn
  *-network:1
       physical id: 3
       mantıksal ad: wlp18s0b1
       serial: 94:39:e5:d8:88:c5
       yapılandırma: broadcast=yes driver=brcmsmac driverversion=4.4.0-59-generic firmware=610.812 ip=10.42.0.1 link=yes multicast=yes wireless=IEEE 802.11bgn
karayel@karayel-Vostro-1540 ~ $ iwconfig | grep Power
enp19s0   no wireless extensions.
          Bit Rate=39 Mb/s   Tx-Power=20 dBm
          Power Management:on
wlp18s0b1  IEEE 802.11bgn  Mode:Master  Tx-Power=19 dBm
          Power Management:off
karayel@karayel-Vostro-1540 ~ $ lsmod
ipt_MASQUERADE         16384  1
nf_nat_masquerade_ipv4    16384  1 ipt_MASQUERADE
xt_conntrack           16384  1
ipt_REJECT             16384  2
xt_tcpudp              16384  4
nf_nat_h323            20480  0
nf_conntrack_h323      65536  1 nf_nat_h323
nf_nat_pptp            16384  0
nf_nat_proto_gre       16384  1 nf_nat_pptp
nf_conntrack_pptp      16384  1 nf_nat_pptp
nf_conntrack_proto_gre    16384  1 nf_conntrack_pptp
nf_nat_tftp            16384  0
nf_conntrack_tftp      16384  1 nf_nat_tftp
nf_nat_sip             20480  0
nf_conntrack_sip       24576  1 nf_nat_sip
nf_nat_irc             16384  0
nf_conntrack_irc       16384  1 nf_nat_irc
nf_conntrack_ftp       16384  1 nf_nat_ftp
iptable_nat            16384  1
nf_conntrack_ipv4      16384  2
nf_nat_ipv4            16384  1 iptable_nat
nf_nat                 24576  9 nf_nat_ftp,nf_nat_irc,nf_nat_sip,nf_nat_proto_gre,nf_nat_h323,nf_nat_ipv4,nf_nat_pptp,nf_nat_tftp,nf_nat_masquerade_ipv4
nf_conntrack           98304  18 nf_nat_ftp,nf_nat_irc,nf_nat_sip,nf_conntrack_proto_gre,nf_nat,nf_nat_h323,nf_nat_ipv4,nf_nat_pptp,nf_nat_tftp,xt_conntrack,nf_nat_masquerade_ipv4,nf_conntrack_ftp,nf_conntrack_irc,nf_conntrack_sip,nf_conntrack_h323,nf_conntrack_ipv4,nf_conntrack_pptp,nf_conntrack_tftp
ip_tables              20480  2 iptable_filter,iptable_nat
x_tables               24576  6 ip_tables,xt_tcpudp,ipt_MASQUERADE,xt_conntrack,iptable_filter,ipt_REJECT
rfcomm                 65536  2
drbg                   28672  1
ctr                    16384  2
ccm                    20480  2
arc4                   16384  4
rt2800usb              28672  0
brcmsmac              552960  0
rt2x00usb              20480  1 rt2800usb
cordic                 16384  1 brcmsmac
brcmutil               16384  1 brcmsmac
rt2800lib              90112  1 rt2800usb
rt2x00lib              49152  3 rt2x00usb,rt2800lib,rt2800usb
crc_ccitt              16384  1 rt2800lib
b43                   401408  0
uvcvideo               77824  0
mac80211              659456  5 b43,brcmsmac,rt2x00lib,rt2x00usb,rt2800lib
videobuf2_v4l2         28672  1 uvcvideo
videobuf2_core         36864  2 uvcvideo,videobuf2_v4l2
v4l2_common            16384  1 videobuf2_v4l2
videodev              155648  4 uvcvideo,v4l2_common,videobuf2_core,videobuf2_v4l2
btusb                  40960  0
snd_hda_codec_idt      53248  1
snd_hda_codec_generic    69632  1 snd_hda_codec_idt
snd_hda_intel          36864  3
snd_hda_codec         118784  4 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_codec_generic,snd_hda_intel
cfg80211              499712  4 b43,brcmsmac,mac80211,rt2x00lib
ssb                    57344  1 b43
snd_hda_core           61440  5 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
kvm_intel             167936  0
bluetooth             479232  29 bnep,btbcm,btrtl,btusb,rfcomm,btintel
kvm                   479232  1 kvm_intel
snd_pcm                94208  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
dell_wmi               16384  0
sparse_keymap          16384  1 dell_wmi
dell_laptop            24576  0
dcdbas                 16384  1 dell_laptop
snd                    69632  17 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_hda_codec_idt,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
dell_smm_hwmon         16384  0
mei_me                 28672  0
mei                    94208  1 mei_me
bcma                   49152  3 b43,brcmsmac
lpc_ich                20480  0
btrfs                1003520  0
xor                    28672  1 btrfs
hid                    98304  2 hid_generic,usbhid
i915                 1130496  8
drm_kms_helper        139264  1 i915
psmouse               118784  0
drm                   311296  5 i915,drm_kms_helper
intel_ips              20480  0
r8169                  77824  0
wmi                    20480  1 dell_wmi
video                  36864  3 i915,dell_wmi,dell_laptop
« Son Düzenleme: 17 Ocak 2017, 13:29:01 Gönderen: karayel90 »
Ynt: Linux Mint Hotspot Yavaş Bağlantı Sorunu
« Yanıtla #1 : 16 Ocak 2017, 12:26:39 »
Buradaki öneriyi dener misiniz?
  • İleti: 6
« Yanıtla #2 : 17 Ocak 2017, 13:28:44 »
Verdiğiniz yöntem sorunumu çözdü teşekkürler
