Gönderen Konu: LinuxMint 18 KDE Kablolu İnternet Bağlı Gösteriyor Ama Net Yok ( Intel I218-V )  (Okunma sayısı 2890 defa)
Çevrimdışı agabeg
  • İleti: 5
  • Dağıtım: Linux Mint KDE 18.1
System:    Host: agabeg Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
          Desktop: KDE Plasma 5.6.5 (Qt 5.5.1) Distro: Linux Mint 18 Sarah
Network:   Card: Intel Ethernet Connection (2) I218-V
          driver: e1000e v: 3.2.6-k port: f080 bus-ID: 00:19.0
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2)
I218-V [8086:15a1] (rev 05)
       DeviceName:  Onboard LAN
       Subsystem: Micro-Star International Co., Ltd. [MSI] Ethernet Connecti
on (2) I218-V [1462:7817]
       Kernel driver in use: e1000e
       Kernel modules: e1000e
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 003 Device 004: ID 0781:5567 SanDisk Corp. Cruzer Blade
Bus 003 Device 003: ID 0000:0538
Bus 003 Device 005: ID 04a9:2676 Canon, Inc. CAPT Device
Bus 003 Device 002: ID 0c45:760b Microdia
Usage:  rfkill [options] command
Options:
       --version       show version (0.5-1ubuntu3 (Ubuntu))
Commands:
       help
       event
       list [IDENTIFIER]
       block IDENTIFIER
       unblock IDENTIFIER
where IDENTIFIER is the index no. of an rfkill switch or one of:
       <idx> all wifi wlan bluetooth uwb ultrawideband wimax wwan gps fm nfc
*-network
      product: Ethernet Connection (2) I218-V
      vendor: Intel Corporation
      physical id: 19
      bus info: pci@0000:00:19.0
      logical name: eno1
      version: 05
      serial: d8:cb:8a:3d:d3:a1
      capacity: 1Gbit/s
      width: 32 bits
      clock: 33MHz
      capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10b
t-fd 100bt 100bt-fd 1000bt-fd autonegotiation
      configuration: autonegotiation=on broadcast=yes driver=e1000e driverve
rsion=3.2.6-k duplex=full firmware=0.1-4 latency=0 link=yes multicast=yes por
t=twisted pair speed=1Gbit/s
      resources: irq:31 memory:f7d00000-f7d1ffff memory:f7d3c000-f7d3cfff io
port:f080(size=32)
eno1      no wireless extensions.
kvm_intel             172032  0
kvm                   536576  1 kvm_intel
aesni_intel           167936  0
snd_hda_codec_realtek    81920  1
usblp                  20480  0
snd_hda_intel          36864  5
snd_hda_codec         135168  4 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_
hda_codec_generic,snd_hda_intel
snd_hda_core           73728  5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_
hda_codec_generic,snd_hda_codec,snd_hda_intel
snd_pcm               106496  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_inte
l,snd_hda_core
cryptd                 20480  2 aesni_intel,ablk_helper
mei_me                 36864  0
snd                    81920  21 snd_hda_codec_realtek,snd_hwdep,snd_timer,sn
d_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_co
dec,snd_hda_intel,snd_seq_device
mei                    98304  1 mei_me
acpi_pad               20480  0
tpm_infineon           20480  0
nf_log_ipv6            16384  6
xt_hl                  16384  22
nf_conntrack_ipv6      20480  6
nf_defrag_ipv6         36864  1 nf_conntrack_ipv6
ip6t_REJECT            16384  3
nf_log_ipv4            16384  6
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  12
xt_limit               16384  15
xt_tcpudp              16384  18
nf_conntrack_ipv4      16384  6
xt_conntrack           16384  12
ipt_REJECT             16384  3
ip6_tables             28672  1 ip6table_filter
nf_nat                 24576  1 nf_nat_ftp
nf_conntrack_ftp       20480  1 nf_nat_ftp
nf_conntrack          106496  8 nf_nat_ftp,nf_conntrack_netbios_ns,nf_nat,xt_
conntrack,nf_conntrack_broadcast,nf_conntrack_ftp,nf_conntrack_ipv4,nf_conntr
ack_ipv6
ip_tables              28672  1 iptable_filter
x_tables               36864  13 ip6table_filter,xt_hl,ip_tables,xt_tcpudp,xt
_limit,xt_conntrack,xt_LOG,iptable_filter,ip6t_rt,ipt_REJECT,ip6_tables,xt_ad
drtype,ip6t_REJECT
usb_storage            69632  1 uas
mxm_wmi                16384  0
psmouse               126976  0
i915                 1208320  8
drm_kms_helper        139264  1 i915
ahci                   36864  1
drm                   360448  9 i915,drm_kms_helper
e1000e                237568  0
ptp                    20480  1 e1000e
pps_core               20480  1 ptp
wmi                    20480  1 mxm_wmi
video                  40960  1 i915
Aynı anda Windows'da kullanıyorum aynı kablolu net çalışıyor. Ama Linux'a geçtiğimde bağlı gözüküyor alttaki simgede ama nete hiç bir şekilde girmiyor.
Düzenleme: Kod etiketi eklendi. Lütfen çıktıları kod etiketi içerisinde paylaşınız.
Bkz:İletilerde code Etiketi Kullanımı
karakartala
« Son Düzenleme: 26 Ocak 2017, 19:37:58 Gönderen: Genizcil_N »
https://downloadmirror.intel.com/15817/eng/e1000e-3.3.4.tar.gz
yukarıdaki bağlantıdan sürücüyü indirin,  arşivi klasöre çıkartın kurulum için sırasıyla
make install
rmmod e1000e
modprobe e1000e
update-initramfs -u
Çevrimdışı agabeg
  • İleti: 5
Olmadi ya daha dogrusu indirdiğim programı kurmadı..neden olabilirki. uç birimde kurmaya çalıştım bi türlü kuramadaı yani dosyayı bulamadı..
 ilginiz için şimdiden teşekkürler..
Uçbirimi çıkardığınız dizin içinde açmalısınız, içinde pci.updates isimli dosyanın da bulunduğu dizin içinde sağ tıklayıp içerik menüsünden terminal/uçbirim aç gibi bir seçenek yardımıyla uçbirimi dizin içinde açabilirsiniz. Ardından [member=1]Danny[/member]'nin verdiği komutları sırasıyla uçbirimde çalıştırmayı deneyiniz.
Çevrimdışı agabeg
  • İleti: 5
kusura bakmayin linux yeni kullanmaya başladım.. dediğiniz gibi e1000e dosyasında uçbirimi açtım sonra
sudo apt-get install e1000e
yazdım olamdı.. her türlü denedim ama başarılı olamadım.. başka çaresi olabilirim acaba..
Sizle böyle bir komut paylaşılmadığı için çalışmamıştır, depoda e1000e adında bir paket olmadığı için kurulum olmaz, zaten böyle bir paket de yok. Siz indirdiğiniz kaynak dosyadan [member=1]Danny[/member] 'nin paylaştığı komutlarla derleyerek kurulum yapacaksınız.
