Gönderen Konu: Linux Mint 18.1 Ses Yok  (Okunma sayısı 7340 defa)
Çevrimdışı SogukSu
  • İleti: 19
  • Dağıtım: Ubuntu 14.04.03
  • Masaüstü Ortamı: Unity
« : 01 Şubat 2017, 11:48:17 »
Merhaba arkadaşlar
daha öncesinde Elementary Os Loki ve Ubungu Gnome 16.04.01 kullanırken ses vardı, Linux Mint 18.1 kurdum ses yok.
inxi -SMAx
System:    Host: roommate-notebook Kernel: 4.4.0-59-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.1 Serena
Machine:   System: HP product: HP Notebook v: Type1ProductConfigId
           Mobo: HP model: 81EE v: 62.29 Bios: Insyde v: F.17 date: 09/08/2016
Audio:     Card Intel Device 9d71 driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.4.0-59-generic
cat /proc/asound/card0/codec#* | grep Codec
cat: '/proc/asound/card0/codec#*': No such file or directory
cat /proc/asound/modules
Herhangi bir çıktı yok
lsmod | grep snd
snd_hda_intel          40960  0
snd_hda_codec         135168  1 snd_hda_intel
snd_hda_core           73728  2 snd_hda_codec,snd_hda_intel
snd_pcm               106496  3 snd_hda_codec,snd_hda_intel,snd_hda_core
snd                    81920  8 snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device
aplay -l
play WARN getopt: option `l' not recognized
play:      SoX v14.4.1
play FAIL sox: invalid option
Usage summary: [gopts] [[fopts] infile]... [fopts] [effect [effopt]]...
SPECIAL FILENAMES (infile, outfile):
-                        Pipe/redirect input/output (stdin/stdout); may need -t
-d, --default-device     Use the default audio device (where available)
-n, --null               Use the `null' file handler; e.g. with synth effect
-p, --sox-pipe           Alias for `-t sox -'
SPECIAL FILENAMES (infile only):
"|program [options] ..." Pipe input from external program (where supported)
http://server/file       Use the given URL as input file (where supported)
GLOBAL OPTIONS (gopts) (can be specified at any point before the first effect):
--buffer BYTES           Set the size of all processing buffers (default 8192)
--clobber                Don't prompt to overwrite output file (default)
--combine concatenate    Concatenate all input files (default for sox, rec)
--combine sequence       Sequence all input files (default for play)
-D, --no-dither          Don't dither automatically
--effects-file FILENAME  File containing effects and options
-G, --guard              Use temporary files to guard against clipping
-h, --help               Display version number and usage information
--help-effect NAME       Show usage of effect NAME, or NAME=all for all
--help-format NAME       Show info on format NAME, or NAME=all for all
--i, --info              Behave as soxi(1)
--input-buffer BYTES     Override the input buffer size (default: as --buffer)
--no-clobber             Prompt to overwrite output file
-m, --combine mix        Mix multiple input files (instead of concatenating)
--combine mix-power      Mix to equal power (instead of concatenating)
-M, --combine merge      Merge multiple input files (instead of concatenating)
--magic                  Use `magic' file-type detection
--multi-threaded         Enable parallel effects channels processing
--norm                   Guard (see --guard) & normalise
--play-rate-arg ARG      Default `rate' argument for auto-resample with `play'
--plot gnuplot|octave    Generate script to plot response of filter effect
-q, --no-show-progress   Run in quiet mode; opposite of -S
--replay-gain track|album|off  Default: off (sox, rec), track (play)
-R                       Use default random numbers (same on each run of SoX)
-S, --show-progress      Display progress while processing audio data
--single-threaded        Disable parallel effects channels processing
--temp DIRECTORY         Specify the directory to use for temporary files
-T, --combine multiply   Multiply samples of corresponding channels from all
--version                Display version number of SoX and exit
-V[LEVEL]                Increment or set verbosity level (default 2); levels:
                           1: failure messages
                           2: warnings
                           3: details of processing
                           4-6: increasing levels of debug messages
FORMAT OPTIONS (fopts):
Input file format options need only be supplied for files that are headerless.
Output files will have the same format as the input file where possible and not
overriden by any of various means including providing output format options.
-v|--volume FACTOR       Input file volume adjustment factor (real number)
--ignore-length          Ignore input file length given in header; read to EOF
-t|--type FILETYPE       File type of audio
-e|--encoding ENCODING   Set encoding (ENCODING may be one of signed-integer,
                         unsigned-integer, floating-point, mu-law, a-law,
                         ima-adpcm, ms-adpcm, gsm-full-rate)
-b|--bits BITS           Encoded sample size in bits
-N|--reverse-nibbles     Encoded nibble-order
-X|--reverse-bits        Encoded bit-order
--endian little|big|swap Encoded byte-order; swap means opposite to default
-L/-B/-x                 Short options for the above
-c|--channels CHANNELS   Number of channels of audio data; e.g. 2 = stereo
-r|--rate RATE           Sample rate of audio
-C|--compression FACTOR  Compression factor for output format
--add-comment TEXT       Append output file comment
--comment TEXT           Specify comment text for the output file
--comment-file FILENAME  File containing comment text for the output file
--no-glob                Don't `glob' wildcard match the following filename
AUDIO FILE FORMATS: 8svx aif aifc aiff aiffc al amb amr-nb amr-wb anb au avr awb caf cdda cdr cvs cvsd cvu dat dvms f32 f4 f64 f8 fap flac fssd gsm gsrt hcom htk ima ircam la lpc lpc10 lu mat mat4 mat5 maud nist ogg paf prc pvf raw s1 s16 s2 s24 s3 s32 s4 s8 sb sd2 sds sf sl sln smp snd sndfile sndr sndt sou sox sph sw txw u1 u16 u2 u24 u3 u32 u4 u8 ub ul uw vms voc vorbis vox w64 wav wavpcm wv wve xa xi
PLAYLIST FORMATS: m3u pls
AUDIO DEVICE DRIVERS: alsa
EFFECTS: allpass band bandpass bandreject bass bend biquad chorus channels compand contrast dcshift deemph delay dither divide+ downsample earwax echo echos equalizer fade fir firfit+ flanger gain highpass hilbert input# ladspa loudness lowpass mcompand mixer* noiseprof noisered norm oops output# overdrive pad phaser pitch rate remix repeat reverb reverse riaa silence sinc spectrogram speed splice stat stats stretch swap synth tempo treble tremolo trim upsample vad vol
  * Deprecated effect    + Experimental effect    # LibSoX-only effect
EFFECT OPTIONS (effopts): effect dependent; see --help-effect
Nedir sorunum ve nasıl çözebiliriz?
CPU:       Dual core Intel Core i5-7200U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10847
           clock speeds: max: 2601 MHz 1: 1100 MHz 2: 2000 MHz 3: 600 MHz
           4: 400 MHz
Graphics:  Card-1: Intel Device 5916 bus-ID: 00:02.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330]
           bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: ati,radeon,intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           GLX Renderer: Mesa DRI Intel Kabylake GT2
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 4000 bus-ID: 02:00.0
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be port: 3000 bus-ID: 03:00.0
           IF: wlo1 state: up mac: <filter>
Drives:    HDD Total Size: 1000.2GB (1.5% used)
           ID-1: /dev/sda model: TOSHIBA_MQ01ABD1 size: 1000.2GB
Partition: ID-1: / size: 909G used: 6.5G (1%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 8.50GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: N/A
Info:      Processes: 222 Uptime: 57 min Memory: 1523.7/7900.5MB
« Son Düzenleme: 01 Şubat 2017, 12:35:49 Gönderen: SogukSu »
Ynt: Linux Mint 18.1 Ses Yok
« Yanıtla #1 : 01 Şubat 2017, 12:18:14 »
Aşağıdaki komutun çıktısını da paylaşırsanız, çekirdek güncellemesini de içeren bir öneri sunmaya çalışalım.
Çevrimdışı SogukSu
  • İleti: 19
« Yanıtla #2 : 01 Şubat 2017, 12:36:25 »
Yukarı ekledim hocam, teşekkürler, iyi çalışmalar.
« Yanıtla #3 : 01 Şubat 2017, 13:01:15 »
Sisteminizi aşağıdaki şekilde güncelleyip yeniden başlatmayı dener misiniz?
Ardından, Güncelleme Yöneticisi => Görünüm menüsü => "Linux çekirdekleri" aracı yardımıyla 4.8.x serisi çekirdeğin son sürümünü kurunuz.
Çevrimdışı SogukSu
  • İleti: 19
« Yanıtla #4 : 01 Şubat 2017, 14:24:30 »
Maalesef sorun düzelmedi hocam.
« Yanıtla #5 : 01 Şubat 2017, 21:17:57 »
Çevrimdışı SogukSu
  • İleti: 19
« Yanıtla #6 : 01 Şubat 2017, 21:48:00 »
Bağlantıdaki öneriyi dener misiniz?
https://forum.linuxmint.net.tr/index.php?topic=7443.msg46125#msg46125
Yaptım, sitemide de resetledim ama yine de düzelmedi. Aynı problemi yaşayan başka bi kullanıcıda buldum: https://forums.linuxmint.com/viewtopic.php?f=49&t=238764#p1273354 pc modellerimizde aynı.
« Yanıtla #7 : 02 Şubat 2017, 15:30:09 »
Bağlantıda çalışan DVD/USB ile ses alabildiğini ama bazı güncellemeler ile ses sorunu oluştuğundan bahsedilmiş. Sizde de böyle mi?
Ayrıca 4.8.x çekirdekle beraber linux-firmware paketinin daha güncel sürümünü aşağıdaki komutlarla elle kurmak önerilmiş.
wget -c --no-check-certificate mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.162_all.deb
sudo dpkg -i linux-firmware_1.162_all.deb
« Son Düzenleme: 02 Şubat 2017, 15:38:06 Gönderen: Butterfly »
