Gönderen Konu: Packard Bell Touchpad Sorunu  (Okunma sayısı 9197 defa)
Çevrimdışı tolstoy
  • İleti: 38
  • Dağıtım: Linux Mint 17.2 Rafaela
  • Masaüstü Ortamı: Kde
  • Grafik Kartı: Nvidia GEFORCE GT 240M CUDA 1GB
  • İşlemci: İntel Core 2 Due Processor T9600
« : 13 Şubat 2017, 16:47:22 »
İyi günler.
Packard Bell TV44 HC  makine'ye 18.1 Cinnamon -Serena ,Touchpad 'in çalışmama sorunu mevcut .Benzer konuları inceledim.Bir neticeye ulaşamadım.  Yardımlarınızı rica ediyorum.
Teşekkür ederim.
inxi -Fx
System:    Host: cengiz-EasyNote-TV44HC Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
Machine:   System: Packard Bell product: EasyNote TV44HC v: V2.21 serial: NXC24EY002250024481601
           Mobo: Packard Bell model: VG50_HC_CR v: Type2 - Board Version serial: NBM6B11001249311B21601
           Bios: Insyde v: V2.21 date: 12/16/2013
CPU:       Dual core Intel Core i5-3230M (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10376
           clock speeds: max: 3200 MHz 1: 1286 MHz 2: 1251 MHz 3: 1298 MHz
           4: 1227 MHz
           Card-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
           bus-ID: 01:00.0
           Display Server: X.org 1.18.4 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau
           tty size: 80x24 Advanced Data: N/A for root
Network:   Card-1: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe
           driver: tg3 v: 3.137 bus-ID: 02:00.0
           IF: enp2s0f0 state: up speed: 1000 Mbps duplex: full
           mac: 20:89:84:4e:63:8a
           Card-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter
           driver: bcma-pci-bridge bus-ID: 03:00.0
           IF: wlp3s0b1 state: up mac: 9c:2a:70:32:bb:cf
Drives:    HDD Total Size: 500.1GB (2.8% used)
           ID-1: /dev/sda model: ST500LT012 size: 500.1GB temp: 36C
Partition: ID-1: / size: 451G used: 5.8G (2%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.48GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 49.0C mobo: N/A
Info:      Processes: 189 Uptime: 34 min Memory: 1049.5/7875.8MB
« Son Düzenleme: 13 Şubat 2017, 16:53:40 Gönderen: tolstoy »
Ynt: Packard Bell Touchpad Sorunu
« Yanıtla #1 : 13 Şubat 2017, 16:55:46 »
sudo apt-get install xserver-xorg-input-synaptics
Bu komutu girip deneyin.
Ayrıca Bumblebee kurmadıysanız,kurmanızı tavsiye ederim.Touchpad ile alakalı değil tabiki.Ekran kartı ve ısınma için.
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #2 : 13 Şubat 2017, 17:26:11 »
Bu ileti'yi vermekte
xserver-xorg-input-synaptics zaten en yeni sürümde (1.8.2-1ubuntu3).
Aşağıdaki paket otomatik olarak kurulmuş ve artık bu pakete gerek duyulmuyor:
  nvidia-current
Bu paketi kaldırmak için 'sudo apt autoremove' komutunu kullanın.
0 paket yükseltilecek, 0 yeni paket kurulacak, 0 paket kaldırılacak ve 31 paket yükseltilmeyecek.
 Bumblebee  sisteme  kurulumu yaptım.
« Son Düzenleme: 13 Şubat 2017, 17:28:11 Gönderen: tolstoy »
« Yanıtla #3 : 13 Şubat 2017, 17:35:45 »
Buradaki öneriyi deneyebilirsiniz. Linux Mint 18 için gedit yerine xed yazmalısınız.
« Yanıtla #4 : 13 Şubat 2017, 17:39:45 »
Tamamdır.
Şimdi öncelikle biosunuza bir bakın,orada touchpad ile ilgili advanced touchpad vs. şeklinde bir ayar var ise onu kapatın.Bazen böyle sorunlar oluyor.
Eğer olmazsa sistem ayarları kısmından fare ve dokunmatik panel bölümünden dokunmatik paneli devre dışı bırakıp yeniden açmayı deneyin.
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #5 : 13 Şubat 2017, 18:13:34 »
Sistemi yeniden başlatmayı uyguladığımda sistem kilitlendi .Sistem  başlattığım da
Cinnamon sadece çöktü. Şu an Fallback kipinde çalışıyorsunuz.
Cinnamonu yeniden başlatmak istiyormusunuz ?
Evet  Hayır
seçenekleri vermekte.Sanki çökme olmuş gibi.
Fare ve dokunmatik paneli paneli devre dışı bırakıp tekrar açtım.Değişen oluşmadı.
Bios' ta advanced touchpad  olan yeri göremedim.
« Yanıtla #6 : 13 Şubat 2017, 18:22:01 »
Evet  Hayır
O konu hakkında bilgim yok [member=8]Butterfly[/member]
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #7 : 13 Şubat 2017, 20:37:54 »
İntel ve Nvıdıa driverları kurulumundan sonra hata kalktı. Touchpad driver'ından olan bir sorunmudur?
Bir diğeride marka olarak touchpad verdiğimiz komutlarla sistem üzerinde sağlıklı olup olmadığını anlayabilme imkanımız var mıdır?
« Yanıtla #8 : 13 Şubat 2017, 22:45:04 »
xinput -listçıktısına bakabilir miyiz?
Güncelleme Yöneticisi => Görünüm menüsü => "Linux çekirdekleri" aracı yardımıyla 4.8 serisi bir çekirdek kurduğunuzda sorun düzeliyor mu?
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #9 : 14 Şubat 2017, 12:20:50 »
Merhaba
xinput -list
⎡ Virtual core pointer                    id=2 [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              id=4 [slave  pointer  (2)]
⎜   ↳ SIGMACHIP Usb Mouse                      id=11 [slave  pointer  (2)]
⎣ Virtual core keyboard                    id=3 [master keyboard (2)]
    ↳ Virtual core XTEST keyboard              id=5 [slave  keyboard (3)]
    ↳ Power Button                            id=6 [slave  keyboard (3)]
    ↳ Video Bus                                id=7 [slave  keyboard (3)]
    ↳ Power Button                            id=8 [slave  keyboard (3)]
    ↳ Sleep Button                            id=9 [slave  keyboard (3)]
    ↳ Video Bus                                id=10 [slave  keyboard (3)]
    ↳ HD WebCam                                id=12 [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            id=13 [slave  keyboard (3)]
    ↳ Acer WMI hotkeys
Kernel Çekirdeği 4.8.0-28 olarak değiştirdim.Linux -firmware kernel driver güncellemeden yükledim değişin olmadı.
« Yanıtla #10 : 17 Şubat 2017, 18:47:38 »
resminin bulunduğu F(F5,F6 gibi) tuşuna basınca bir şey değişiyor mu?
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #11 : 17 Şubat 2017, 21:08:35 »
Hayırlı akşamlar
Maalesef, Muhtemelen son düşündüğüm kısım belki bir olasılık  touchpat 'te sıkıntı olabileceği yönünde.Normal mause ile devam edeceğim.
İlgi ve desteğinize teşekkürederim.
« Yanıtla #12 : 21 Şubat 2017, 11:53:29 »
Bunu uyguladınız mı? Yaptığınız geri dönüşlerde size sunulan önerileri uygulayıp uygulamadığınız hakkında da bilgi paylaşmanız önemli.
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #13 : 21 Şubat 2017, 19:43:35 »
İyi akşamlar
sudo xed /etc/default/grub
sudo update-grub
Grub yapılandırma dosyası oluşturuluyor ...
Bulunan linux kalıbı: /boot/vmlinuz-4.8.0-28-generic
Bulunan initrd kalıbı: /boot/initrd.img-4.8.0-28-generic
Bulunan linux kalıbı: /boot/vmlinuz-4.4.0-53-generic
Bulunan initrd kalıbı: /boot/initrd.img-4.4.0-53-generic
bitti
Touchpad bulunan kartta sıkıntı mevcut  yanılmıyorsam.Diğer sistemi tekrar kurdum.Ordada aynı sorun oldu .
Çevrimdışı tolstoy
  • İleti: 38
« Yanıtla #14 : 28 Şubat 2017, 18:40:07 »
İyi günler
Touchpad sıkıntısın gidermiş bulunuyorum.Biraz teknik bakıma ihtiyaç oldu. Üst panelin komple değişimiyle hallettik.Sonucu burda sizlerle paylaşmak istedim.
xinput -list
⎜   ↳ ETPS/2 Elantech Touchpad                id=14 [slave  pointer  (2)]
    ↳ Acer WMI hotkeys
İlginize,bilgi ve desteğinize Sonsuz teşekküederim.
Saygılarımla
