Gönderen Konu: Ses kartı sorunu  (Okunma sayısı 3371 defa)
Çevrimdışı asarycan
  • İleti: 3
  • Dağıtım: linux mint 18.1 Serena Mate
Ses kartı sorunu
« : 19 Şubat 2017, 16:28:42 »
Mrb Arkadaşlar.  Forumda yeniyim. Guleek İ8S Mini PC'ye Linux Mint 18.1 Mate kurdum. Fakat ses kartını görmedi. Hdmi üzerinden sinema sistemine bağlamak istedim. oradanda Tv ye gidiyor. Fakat android 'te görüyor fakat linux mint görmedi.
# inxi -Ax
Audio:     Card Failed to Detect Sound Card! Sound: ALSA v: k4.4.0-53-generic
# inxi -Fx
System:    Host: guleek Kernel: 4.4.0-53-generic i686 (32 bit gcc: 5.4.0)
           Desktop: MATE 1.16.1 (Gtk 3.18.9-1ubuntu3.1)
Machine:   System: Insyde product: i8 serial: Type1 - 123456789
           Mobo: Type2 - Board Manufacturer model: Type2 - Board Product Name v: Type2 - Board Version serial: Type2 - Board Serial Number
           Bios: INSYDE v: M.B.DI8NHNGA01 date: 11/20/2015
CPU:       Quad core Intel Atom Z3735F (-MCP-) cache: 1024 KB
           flags: (lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10649
           clock speeds: max: 1832 MHz 1: 599 MHz 2: 1006 MHz 3: 1125 MHz
           4: 1832 MHz
Graphics:  Card: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
           Display Server: X.org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
           tty size: 80x24 Advanced Data: N/A for root
Network:   Card: Kontron ( Source / ICS Advent) DM9601 Fast Ethernet Adapter
           driver: dm9601 usb-ID: 001-006
           IF: enx00e04c534458 state: up speed: 100 Mbps duplex: full
           mac: 00:e0:4c:53:44:58
Drives:    HDD Total Size: 2000.4GB (73.9% used)
           ID-1: /dev/mmcblk0 model: N/A size: 31.0GB
           ID-2: /dev/mmcblk1 model: N/A size: 62.6GB
           ID-3: USB /dev/sda model: External_USB_3.0 size: 2000.4GB temp: 0C
Partition: ID-1: / size: 58G used: 5.1G (10%) fs: ext4 dev: /dev/mmcblk1p1
Sensors:   System Temperatures: cpu: 45.0C mobo: N/A
Info:      Processes: 218 Uptime: 1:46 Memory: 640.0/1913.1MB
guleek ahmet # inxi -SMAx
guleek ahmet # cat /proc/asound/card0/codec#* | grep Codec
cat: '/proc/asound/card0/codec#*': Böyle bir dosya ya da dizin yok
cat /proc/asound/modules
boş geliyor bu  komut
guleek ahmet # lsmod | grep snd
snd_soc_sst_baytrail_pcm    28672  0
snd_soc_sst_ipc        16384  1 snd_soc_sst_baytrail_pcm
snd_soc_sst_dsp        49152  1 snd_soc_sst_baytrail_pcm
snd_soc_sst_byt_rt5640_mach    16384  0
snd_intel_sst_acpi     16384  0
snd_intel_sst_core     69632  1 snd_intel_sst_acpi
snd_soc_rt5640         81920  1 snd_soc_sst_byt_rt5640_mach
snd_soc_sst_mfld_platform    69632  1 snd_intel_sst_core
snd_soc_rl6231         16384  1 snd_soc_rt5640
snd_soc_core          192512  4 snd_soc_rt5640,snd_soc_sst_baytrail_pcm,snd_soc_sst_byt_rt5640_mach,snd_soc_sst_mfld_platform
snd_compress           20480  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm                94208  5 snd_soc_rt5640,snd_soc_core,snd_soc_sst_baytrail_pcm,snd_soc_sst_mfld_platform,snd_pcm_dmaengine
dw_dmac_core           24576  2 dw_dmac,snd_soc_sst_dsp
snd                    69632  8 snd_soc_core,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_soc_sst_mfld_platform,snd_seq_device,snd_compress
snd_soc_sst_acpi       16384  0
guleek ahmet # aplay -l
aplay: device_list:268: ses kartı bulunamadı...
« Son Düzenleme: 19 Şubat 2017, 20:03:16 Gönderen: asarycan »
