Gönderen Konu: Masaüstünde herhangi bir işlem sonrası oluşan donma ve yavaşlık sorunu  (Okunma sayısı 4257 defa)
Aşağıda özellikleri bulunan bilgisayarda ekranda herhangi bir işlem yaparken (dosya tıkla, döküman oluşturma, kopyalama ve yapıştırma vb) donma veya çok geç bir sürede işlem gerçekleşiyor. Sebebi ne olabilir?
inxi -SGx
System:    Host: fasonlm Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
Graphics:  Card: Intel Broadwell-U Integrated Graphics bus-ID: 00:02.0
           Resolution: 1366x768@60.02hz
           GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 5500 (Broadwell GT2)
00:02.0 VGA compatible controller: Intel Corporation Broadwell-U Integrated Graphics (rev 09)
eDP1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768      60.02*+  40.01
   1360x768      59.80    59.96
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'ii  nvidia-prime-applet                   1.0.6                                      all          An applet for NVIDIA Prime
Machine:   System: HP product: HP Notebook v: Type1ProductConfigId
           Mobo: HP model: 81EF v: 63.35 Bios: Insyde v: F.17 date: 09/01/2016
CPU:       Dual core Intel Core i3-5005U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 7981
           clock speeds: max: 2000 MHz 1: 1900 MHz 2: 1900 MHz 3: 1898 MHz
           4: 1900 MHz
Audio:     Card-1 Intel Wildcat Point-LP High Definition Audio Controller
           Card-2 Intel Broadwell-U Audio Controller
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 4000 bus-ID: 07:00.0
           IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be port: 3000 bus-ID: 0d:00.0
           IF: wlp13s0 state: down mac: <filter>
Drives:    HDD Total Size: 500.1GB (3.8% used)
           ID-1: /dev/sda model: ST500LT012 size: 500.1GB
Partition: ID-1: / size: 454G used: 14G (4%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 4.20GB used: 0.74GB (18%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 37.5C mobo: N/A
Info:      Processes: 213 Uptime: 5 days Memory: 2046.1/3863.5MB
Çevrimdışı zboraon
  • İleti: 130
Selamlar,
Kurduğunuz herhangi bir applet bu sorunu yapıyor olabilir mi? Birçok applet ve desklet cinnamon 3.2'ye uyum sağlayamadılar. Hiç applet konfigürasyonunu varsayılana değiştirmeyi denediniz mi?
Kendi çapında bir jeolog.
Hayır denemedik. Kurulum yeni yapıldı. Herhangi bir uygulama yüklemedik.
Aşağıdaki komutla Intel GPU dikey eşitlemeyi etkinleştirecek bir yapılandırma dosyası oluşturmayı deneyebilirsiniz.
sudo mkdir -p /etc/X11/xorg.conf.d/ && echo -e 'Section "Device"\n Identifier "Intel Graphics"\n Driver "Intel"\n Option "AccelMethod" "sna"\n Option "TearFree" "true"\nEndSection' | sudo tee /etc/X11/xorg.conf.d/20-intel.conf
Ayrıca 4. seviye güncellemeleri ve çekirdek güncellemesini yapınız.
Hocam 4. seviye güncellemede bir şey çıkmadı.
Diğer komutu uyguladım.
Değişen bir şey görülmedi.
Kullanıcı bilgisayarı ile firma dışına çıktığı için ancak geldiğinde kontrol edebiliyorum.
