Gönderen Konu: Nvidia - İntel ekran kartı bumblebee kurulumdan sonra hata.  (Okunma sayısı 7700 defa)
Çevrimdışı TYeniyayla
  • İleti: 19
    • tyeniyayla
  • Grafik Kartı: Nvidia GTX960M - İntel HD Graphics 530
  • İşlemci: İntel i7 6700HQ
Bumblebee kurarken hiç bir hata almadım ama şu çarkların dönmesi gereken kodta bende hata veriyor. Şunu da söylemem gerek sistemim harici harddiske kurulu.
[info]optirun -vvv glxgears [/info]
[24631.817210] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[24631.817607] [INFO]Configured driver: nvidia
[24631.817693] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.socket was incorrect.
[24631.817712] [DEBUG]Socket closed.
[24631.817734] [ERROR]Could not connect to bumblebee daemon - is it running?
[info]cat /etc/bumblebee/bumblebee.conf[/info]
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-370
PMMethod=auto
LibraryPath=/usr/lib/nvidia-370:/usr/lib32/nvidia-370
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-370/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
[info]cat /etc/bumblebee/xorg.conf.nvidia[/info]
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
tunahan--p
[info]cat /etc/X11/xorg.conf[/info]
[info]dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl'[/info]
ii  bumblebee                                   3.2.1-96~xenialppa1                        amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                            3.2.1-96~xenialppa1                        amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-370                                  370.28-0ubuntu0~gpu16.04.3                 amd64        NVIDIA binary driver - version 370.28
ii  nvidia-prime-applet                         1.0.6                                      all          An applet for NVIDIA Prime
ii  nvidia-settings                             378.13-0ubuntu0~gpu16.10.2                 amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20150328-3~xenialppa1                      amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20150328-3~xenialppa1                      amd64        Shared libraries for primus
ii  primus-libs:i386                            20150328-3~xenialppa1                      i386         Shared libraries for primus
ii  primus-libs-ia32:i386                       20150328-3~xenialppa1                      i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.4.1-1~xenialppa1                         amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.4.1-1~xenialppa1                         amd64        Library files for virtualgl
[info]lspci | egrep 'VGA|3D|Display'[/info]
00:02.0 VGA compatible controller: Intel Corporation Skylake Integrated Graphics (rev 06)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 960M] (rev a2)
[info]optirun glxgears[/info]
[25007.083776] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.socket was incorrect.
[25007.083820] [ERROR]Could not connect to bumblebee daemon - is it running?
[info]inxi -SGx[/info]
System:    Host: tunahan--pc Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.6 (Gtk 3.18.9-1ubuntu3.1)
Graphics:  Card-1: Intel Skylake Integrated Graphics bus-ID: 00:02.0
           Card-2: NVIDIA GM107M [GeForce GTX 960M] bus-ID: 01:00.0
           Display Server: X.org 1.18.4 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau
           tty size: 80x24 Advanced Data: N/A for root
[info]glxinfo | grep render[/info]
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 530 (Skylake GT2)
[info]xrandr[/info]
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 381mm x 214mm
   1920x1080     60.00*+  59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1600x900      60.00
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1368x768      60.00
   1360x768      59.80    59.96
   1152x864      60.00
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   640x360       60.00
[info]systemctl status nvidia-persistenced.service[/info]
● nvidia-persistenced.service - NVIDIA Persistence Daemon
   Loaded: loaded (/lib/systemd/system/nvidia-persistenced.service; static; vendor preset: enabled)
   Active: failed (Result: exit-code) since Cum 2017-03-10 06:17:33 +03; 7h ago
  Process: 898 ExecStart=/usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose (code=exited, sta
Mar 10 06:17:33 tunahan--pc systemd[1]: Starting NVIDIA Persistence Daemon...
Mar 10 06:17:33 tunahan--pc systemd[1]: nvidia-persistenced.service: Control process exited, code=exited status=203
Mar 10 06:17:33 tunahan--pc systemd[1]: Failed to start NVIDIA Persistence Daemon.
Mar 10 06:17:33 tunahan--pc systemd[1]: nvidia-persistenced.service: Unit entered failed state.
Mar 10 06:17:33 tunahan--pc systemd[1]: nvidia-persistenced.service: Failed with result 'exit-code'.
Eğer açılışta çıkan hatayı görmek isterseniz şu videoyu izleyin (orada gördüğüm kodu da (systemctl status nvidia-persistenced.service) en sona ekledim.):
[youtube]https://youtu.be/24EgHAOT6Ko[/youtube]
« Son Düzenleme: 11 Mart 2017, 19:09:56 Gönderen: TYeniyayla »
Ynt: Nvidia - İntel ekran kartı bumblebee kurulumdan sonra hata.
« Yanıtla #1 : 10 Mart 2017, 15:20:17 »
tunahan--p
/etc/bumblebee/xorg.conf.nvidia dosyasının enaltında gerçekten kırmızı ile işaretli kısım var mı, eğer varsa siliniz ve sistemi yeniden başlatınız.
Ayrıca aşağıdaki komutun çıktısına bakalım.
systemctl status -l bumblebeed
  • İleti: 19
    • tyeniyayla
« Yanıtla #2 : 10 Mart 2017, 20:42:59 »
Dediğiniz kısım yok. sudo nano /etc/bumblebee/xorg.conf.nvidia          ile girdim ama böyle bir ibare yok o dosyada.
[info]systemctl status -l bumblebeed[/info]
● bumblebeed.service - Bumblebee C Daemon
   Loaded: loaded (/lib/systemd/system/bumblebeed.service; enabled; vendor prese
   Active: inactive (dead)
« Yanıtla #3 : 10 Mart 2017, 22:53:32 »
Aşağıdaki komutu uçbirimde çalıştırdıktan sonra,
sudo systemctl restart bumblebeed
aşağıdaki komutu çalıştırmayı dener misiniz?
Bir de aşağıdaki komutun çıktısına bakalım.
cat /proc/cmdline
« Son Düzenleme: 10 Mart 2017, 22:55:15 Gönderen: Butterfly »
  • İleti: 19
    • tyeniyayla
« Yanıtla #4 : 11 Mart 2017, 16:22:46 »
[info]"optirun -vvv glxgears"    çalıştı çarkları gördüm[/info]
[29960.975480] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[29960.975883] [INFO]Configured driver: nvidia
[29960.976245] [DEBUG]optirun version 3.2.1 starting...
[29960.976271] [DEBUG]Active configuration:
[29960.976277] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[29960.976283] [DEBUG] X display: :8
[29960.976288] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-370:/usr/lib32/nvidia-370
[29960.976294] [DEBUG] Socket path: /var/run/bumblebee.socket
[29960.976299] [DEBUG] Accel/display bridge: auto
[29960.976305] [DEBUG] VGL Compression: proxy
[29960.976309] [DEBUG] VGLrun extra options:
[29960.976315] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[29960.976471] [DEBUG]Using auto-detected bridge virtualgl
[29962.468450] [INFO]Response: Yes. X is active.
[29962.468462] [INFO]Running application using virtualgl.
[29962.468536] [DEBUG]Process vglrun started, PID 17382.
8435 frames in 5.0 seconds = 1686.864 FPS
9626 frames in 5.0 seconds = 1925.195 FPS
9591 frames in 5.0 seconds = 1918.186 FPS
9598 frames in 5.0 seconds = 1919.473 FPS
[VGL] ERROR: in readback--
[29985.035388] [DEBUG]SIGCHILD received, but wait failed with No child processes
[29985.035413] [DEBUG]Socket closed.
[29985.035427] [DEBUG]Killing all remaining processes.
[info]cat /proc/cmdline[/info]
BOOT_IMAGE=/vmlinuz-4.4.0-53-generic root=UUID=43be1448-0607-4dc5-a336-ddc5e611031f rw nogpumanager 3 vt.handoff=7
« Yanıtla #5 : 11 Mart 2017, 18:29:42 »
Bumblebee servisini başlatınca sorun kalmamaış gibi, aşağıdaki komutla Bumblebee servisinin başlangıçta otomatik çalıştırılmasını deneyebilirsiniz.
sudo systemctl enable bumblebeed.service
  • İleti: 19
    • tyeniyayla
« Yanıtla #6 : 11 Mart 2017, 18:55:58 »
Teşekkür ederim o zaman konuyu çözüldü olarak işaretleyebilirim.
Önce sistemi yeniden başlatıp kontrol edin, eğer sistem yeniden başladığında Bumblebee sorunsuz çalışıyorsa konuyu kilitleyelim.
  • İleti: 19
    • tyeniyayla
« Yanıtla #8 : 11 Mart 2017, 19:11:57 »
Haklısınız. Şimdi yeniden başlatmayı denedim. Sistem hala düzgün olarak açılmıyor yani logodan sonra siyah ekranda bekliyor ve 1dk içinde sonra fan hızı rahatsız edecek seviyede artıyor.
« Son Düzenleme: 11 Mart 2017, 19:14:53 Gönderen: TYeniyayla »
« Yanıtla #9 : 11 Mart 2017, 19:15:12 »
İşin kolayına kaçalım, aşağıdaki komutla /etc/rc.local dosyasını açalım.
sudo xed /etc/rc.local
Açılan dosyada "exit 0" satırının bir üst satırına aşağıdaki satırı ekleyip dosyayı kaydedin.
Böylece sorunu çözen komut başlangıçta çalıştırılarak, sorunun etrafınan dolaşmaya yardımcı olacaktır. Dosyanın son satırları aşağıdaki gibi olacak.
exit 0
Düzenleme sonrası sistemi yeniden başlatıp durumu kontrol ediniz.
« Son Düzenleme: 11 Mart 2017, 19:16:13 Gönderen: Butterfly »
  • İleti: 19
    • tyeniyayla
« Yanıtla #10 : 11 Mart 2017, 19:55:21 »
Hâlâ daha masaüstünü açamadım. Tty ekranına girdiğimde ise kullanıcı adını yazarken takılıyor ve fan hızı artıyor
MI 5s Plus cihazımdan Tapatalk kullanılarak gönderildi
« Yanıtla #11 : 11 Mart 2017, 20:54:55 »
Şimdiye kadar sistemi nasıl açıyordunuz? Bu konu ile ilgili sorun ne durumda? Eğer Bumblebee ile ilgili sorun çözüldüyse konuyu kilitleyelim, diğer sorun için yeni bir konu açmalısınız.
  • İleti: 19
    • tyeniyayla
« Yanıtla #12 : 11 Mart 2017, 20:57:34 »
Her zaman tty ekranına düşüp orada startx yazarak açıyordum ama şimdi açamıyorum tty ekranında kalıyor ve yazı yazamıyorum. Son attığınız kodu da bilgisayarı açamadığım için deneyemedim.
« Yanıtla #13 : 11 Mart 2017, 21:07:08 »
Bunula ilgili aşağıdaki komutun çıktısını da içerecek biçimde yeni bir konu açmanız daha uygun.
  • İleti: 19
    • tyeniyayla
« Yanıtla #14 : 11 Mart 2017, 21:08:58 »
O zaman bu konu burada dursun. Bu sorunu çözdükten sonra sizin 1-2 yorum önce yazdığınız kodu dener sonuçları yazdıktan sonra bu konuyu da kilitleriz.
