Gönderen Konu: [Çözüldü] Yanlışlıkla nvidia yerine intel gpu kurdum !  (Okunma sayısı 4893 defa)
Çevrimdışı juba99
  • İleti: 3
  • Dağıtım: linux mint
  • Masaüstü Ortamı: mate
  • Grafik Kartı: nvidia gt 9400
  • İşlemci: intel pentium e2140
sudo mkdir -p /etc/X11/xorg.conf.d/ && echo -e 'Section "Device"\n Identifier "Intel Graphics"\n Driver "Intel"\n Option "AccelMethod" "sna"\n Option "TearFree" "true"\nEndSection' | sudo tee /etc/X11/xorg.conf.d/20-intel.conf^C
Bu kodu yanlışlıkla kullandım ve bilgisayar açılırken garip şeyler çıkıyor naısl düzeltebilirim ve firefox tarayıcıda video izleyemiyorum normal video oynatıcıdada ekranda yırtılma oluyor izlerken kasıyor windowsta böyle yapmazdı şimdiden teşekkürler
System:    Host: tice Kernel: 4.4.0-66-generic i686 (32 bit gcc: 5.4.0)
           Desktop: MATE 1.16.1 (Gtk 3.18.9-1ubuntu3.2)
Graphics:  Card: NVIDIA G96 [GeForce 9400 GT] bus-ID: 02:00.0
           Display Server: X.Org 1.18.4 drivers: nvidia (unloaded: fbdev,vesa,nouveau,intel)
           Resolution: 1440x900@59.89hz
           GLX Renderer: GeForce 9400 GT/PCIe/SSE2
           GLX Version: 3.3.0 NVIDIA 340.102 Direct Rendering: Yes
OpenGL renderer string: GeForce 9400 GT/PCIe/SSE2
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info,
    GL_NV_ES1_1_compatibility, GL_NV_blend_square, GL_NV_conditional_render,
02:00.0 VGA compatible controller: NVIDIA Corporation G96 [GeForce 9400 GT] (rev a1)
tice49@t
Screen 0: minimum 8 x 8, current 1440 x 900, maximum 8192 x 8192
DVI-I-0 disconnected primary (normal left inverted right x axis y axis)
DVI-I-1 connected 1440x900+0+0 (normal left inverted right x axis y axis) 370mm x 232mm
   1440x900      59.89*+  74.98
   1280x1024     75.02    60.02
   1280x960      60.00
   1152x864      75.00
   800x600       75.00    60.32    56.25
   640x480       75.00    59.94
TV-0 disconnected (normal left inverted right x axis y axis)
DVI-I-2 disconnected (normal left inverted right x axis y axis)
DVI-I-3 disconnected (normal left inverted right x axis y axis)
i  nvidia-340                                 340.102-0ubuntu0.16.04.1                   i386         NVIDIA binary driver - version 340.102
ii  nvidia-opencl-icd-340                      340.102-0ubuntu0.16.04.1                   i386         NVIDIA OpenCL ICD
ii  nvidia-prime                               0.8.2linuxmint1                            i386         Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                        1.0.6                                      all          An applet for NVIDIA Prime
ii  nvidia-settings                            361.42-0ubuntu1                            i386         Tool for configuring the NVIDIA graphics driver
« Son Düzenleme: 31 Mart 2017, 04:23:40 Gönderen: juba99 »
Ynt: Yanlışlıkla nvidia yerine intel gpu kurdum !
« Yanıtla #1 : 24 Mart 2017, 09:18:08 »
Bu komut Intel GPU^'yu kurmaz, sadece Intel GPU sürücüsü için bir yapılandırma dosyası oluşturur. Oluşturulan yapılandırma dosyasını aşağıdaki komutla silebilirsiniz.
sudo rm -f /etc/X11/xorg.conf.d/20-intel.conf
Sisteminizde sadece Nvidia GPU olduğu için aşağıdaki komutla xorg.conf yapılandırma dosyası oluşturup sistemi yeniden başlatın.
sudo nvidia-xconfig
Ayrıca, Nvidia Ayar Yöneticisi (Nvidia Settings) => OpenGL Ayarları (OpenGL Settings) => Sync to Vblank seçeneğini işaretleyiniz, bu seçenek dikey eşitlemeyi etkinleştirerek yırtılma sorununu çözer.
Çevrimdışı juba99
  • İleti: 3
« Yanıtla #2 : 24 Mart 2017, 23:40:56 »
etkin zaten ama hala yırtılma var ve 2. kodu yazdığımda aşağıdaki hata çıkıyor
ve açılırken hala bişeyler yazıyor linux mint 18.1 yazıyor altında bişey doluyor bi süre sonra altında [20.669872] snd_hda_intel 0000:80:01.0: CORB reset timeout#1 CORBRP = 0 yazısı çıkıyor sonrasında yazı turuncu oluyor ve ekranda
 linux mint 18.1 serena tice tty1
tice login : _ şeklinde yazılar çıkıyor bekleyince açılıyor ama bunları nasıl kaldırabilirim
Package xorg-server was not found in the pkg-config search path.
Perhaps you should add the directory containing `xorg-server.pc'
to the PKG_CONFIG_PATH environment variable
No package 'xorg-server' found
New X configuration file written to '/etc/X11/xorg.conf
« Son Düzenleme: 25 Mart 2017, 00:03:01 Gönderen: juba99 »
« Yanıtla #3 : 27 Mart 2017, 12:11:02 »
Lütfen mesajlarımızda yazım kurallarını gözardı etmeyelim. İmla ve Yazım Kuralları
nvidia-xconfig komutunun çıktısında bir sorun yok, xorg.conf dosyasının oluşturulduğu anlatılıyor.
Forumda aynı başlık altında birden fazla husus hakkında konuşmuyoruz, açılışda TTY ekranını gizlemek için bağlantı incelenebilir. https://forum.linuxmint.net.tr/index.php?topic=7047.msg44031#msg44031
Sorun çözülmezse bununla ilgili yeni konu açarsınız, bu konuda yırtılma sorunu hakkında konuşalım.
Eğer Cinnamon masaüstünü kullanıyorsanız, aşağıdaki öneri de uygulanabilir.
https://forum.linuxmint.net.tr/index.php?topic=250.0
Çevrimdışı juba99
  • İleti: 3
« Yanıtla #4 : 27 Mart 2017, 23:47:16 »
Yırtılma sorunu çözüldü.Aşağıdaki kodu uçbirimde çalıştırınca geçiçi olarak çözülüyor.
nvidia-settings --assign currentmetamode="nvidia-auto-select +0+0 { forcecompositionpipeline = on }"
Kalıcı olması için aşağıdaki kodu /etc/X11/xorg.conf dosyasının screen kısmına ekliyoruz.
    Option         "metamodes" "nvidia-auto-select +0+0 { forcecompositionpipeline = on }"
Tabi nvidia kullananlar için geçerli ve linux mint mate kullanıyorum.
« Yanıtla #5 : 28 Mart 2017, 11:26:49 »
Geri dönüş için teşekkür ederiz. Konu başlığını etiketlerseniz konuyu kilitleyebiliriz.
