Gönderen Konu: [Çözüldü] TouchPad Acer Aspire ES1-11M-C064  (Okunma sayısı 4135 defa)
Çevrimdışı Panta rhei
  • İleti: 54
  • Dağıtım: 19.3
  • Masaüstü Ortamı: Xfce
  • Grafik Kartı: Intel Atom Processor Z36xxx/Z37xxx Series Graphics
  • İşlemci: Dual core Intel Celeron N2840 (-MCP-)
« : 27 Mart 2017, 13:26:26 »
Bilgisayarım Acer Aspire ES1-11M-C064 ve touchpad çalışmıyor driver manager da driver yok
çıktılar şunlar
~ $ inxi -Fxz
System:    Host: cse Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.1 Serena
Machine:   System: Acer product: Aspire ES1-111M v: V1.16
           Mobo: Acer model: R2 v: Type2 - A01 Board Version
           Bios: Insyde v: V1.16 date: 10/20/2015
CPU:       Dual core Intel Celeron N2840 (-MCP-) cache: 1024 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8652
           clock speeds: max: 2582 MHz 1: 1112 MHz 2: 984 MHz
Graphics:  Card: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
           Resolution: 1366x768@60.06hz
           GLX Renderer: Mesa DRI Intel Bay Trail
Audio:     Card Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
Network:   Card-1: Broadcom BCM43142 802.11b/g/n driver: wl bus-ID: 02:00.0
           driver: r8169 v: 2.3LK-NAPI port: 1000 bus-ID: 03:00.0
           IF: enp3s0 state: down mac: <filter>
Drives:    HDD Total Size: NA (-) ID-1: /dev/mmcblk0 model: N/A size: 31.3GB
Partition: ID-1: / size: 27G used: 15G (58%) fs: ext4 dev: /dev/mmcblk0p1
           ID-2: swap-1 size: 2.03GB used: 0.05GB (2%) fs: swap dev: /dev/mmcblk0p5
Sensors:   System Temperatures: cpu: 42.0C mobo: N/A
Info:      Processes: 196 Uptime: 16 min Memory: 1059.4/1885.8MB
~ $ xinput list
⎡ Virtual core pointer                    id=2 [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              id=4 [slave  pointer  (2)]
⎜   ↳ HID 0581:0101                            id=10 [slave  pointer  (2)]
⎣ Virtual core keyboard                    id=3 [master keyboard (2)]
    ↳ Virtual core XTEST keyboard              id=5 [slave  keyboard (3)]
    ↳ Power Button                            id=6 [slave  keyboard (3)]
    ↳ Video Bus                                id=7 [slave  keyboard (3)]
    ↳ Power Button                            id=8 [slave  keyboard (3)]
    ↳ Sleep Button                            id=9 [slave  keyboard (3)]
    ↳ HD WebCam                                id=11 [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            id=12 [slave  keyboard (3)]
    ↳ Acer WMI hotkeys                        id=13 [slave  keyboard (3)]
~ $ sudo lshw
    description: Notebook
    product: Aspire ES1-111M (Aspire ES1-111M_0843_1_16)
    vendor: Acer
    version: V1.16
    serial: NXMRSEY0014411C0737600
    width: 64 bits
    capabilities: smbios-2.7 dmi-2.7 vsyscall32
    configuration: chassis=notebook family=BTM sku=Aspire ES1-111M_0843_1_16 uuid=DD44CC44-0B06-4626-BF34-5D16377866D3
  *-core
       description: Motherboard
       product: R2
       vendor: Acer
       physical id: 0
       version: Type2 - A01 Board Version
       serial: NBMRS110014411C0737600
       slot: Type2 - Board Chassis Location
     *-firmware
          description: BIOS
          vendor: Insyde Corp.
          physical id: 0
          version: V1.16
          date: 10/20/2015
          capacity: 4032KiB
          capabilities: pci upgrade shadowing cdboot bootselect edd int9keyboard int14serial int17printer int10video acpi usb zipboot biosbootspecification netboot
     *-cpu
          description: CPU
          product: Intel(R) Celeron(R) CPU  N2840  @ 2.16GHz
          vendor: Intel Corp.
          physical id: 4
          bus info: cpu@0
          version: Intel(R) Celeron(R) CPU  N2840  @ 2.16GHz
          slot: CPU 1
          capacity: 2582MHz
          width: 64 bits
          clock: 83MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer rdrand lahf_lm 3dnowprefetch epb tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms dtherm ida arat cpufreq
          configuration: cores=2 enabledcores=2 threads=1
        *-cache:0
             description: L1 cache
             physical id: 7
             slot: Unknown
             capacity: 32KiB
             capabilities: synchronous internal write-back instruction
             configuration: level=1
        *-cache:1
             description: L2 cache
             physical id: 8
             slot: Unknown
             capacity: 1MiB
             capabilities: synchronous internal write-back unified
             configuration: level=2
     *-cache
          physical id: 6
          slot: Unknown
          capacity: 24KiB
          capabilities: synchronous internal write-back data
     *-memory
          description: System Memory
          physical id: e
          slot: System board or motherboard
        *-bank
             description: SODIMM DDR3 Synchronous 1333 MHz (0,8 ns)
             product: 76.A302G.C4D0B
             vendor: 12
             physical id: 0
             serial: 15146782
             slot: DIMM0
             width: 64 bits
             clock: 1333MHz (0.8ns)
     *-pci
          description: Host bridge
          product: Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 0e
          width: 32 bits
          clock: 33MHz
          configuration: driver=iosf_mbi_pci
          resources: irq:0
        *-display
             description: VGA compatible controller
             product: Atom Processor Z36xxx/Z37xxx Series Graphics & Display
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pm msi vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:89 memory:90000000-903fffff memory:80000000-8fffffff ioport:2050(size=8)
        *-generic:0
             description: SD Host controller
             product: Atom Processor Z36xxx/Z37xxx Series SDIO Controller
             physical id: 12
             bus info: pci@0000:00:12.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             configuration: driver=sdhci-pci latency=0
             resources: irq:18 memory:90921000-90921fff memory:90920000-90920fff
        *-usb:0
             description: USB controller
             product: Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 0e
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:87 memory:90900000-9090ffff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 4.4.0-53-generic xhci-hcd
                physical id: 0
                bus info: usb@3
                logical name: usb3
                version: 4.04
                capabilities: usb-3.00
                configuration: driver=hub slots=1 speed=5000Mbit/s
           *-usbhost:1
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 4.04
                capabilities: usb-2.00
                configuration: driver=hub slots=6 speed=480Mbit/s
              *-usb:0
                   description: USB hub
                   product: USB2.0 Hub
                   vendor: Genesys Logic, Inc.
                   physical id: 2
                   bus info: usb@2:2
                   version: 85.37
                   configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
                 *-usb
                      description: Mouse
                      vendor: Racal Data Group
                      physical id: 2
                      bus info: usb@2:2.2
                      version: 0.01
                      capabilities: usb-1.10
                      configuration: driver=usbhid maxpower=100mA speed=1Mbit/s
              *-usb:1
                   description: Video
                   product: HD WebCam
                   vendor: SunplusIT INC.
                   physical id: 4
                   bus info: usb@2:4
                   version: 22.04
                   configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
        *-generic:1
             product: Atom Processor E3800 Series eMMC 4.5 Controller
             physical id: 17
             bus info: pci@0000:00:17.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             resources: irq:23 memory:9091e000-9091efff memory:9091d000-9091dfff
        *-generic:2
             description: Encryption controller
             product: Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine
             physical id: 1a
             bus info: pci@0000:00:1a.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_txe latency=0
             resources: irq:90 memory:90800000-908fffff memory:90700000-907fffff
        *-multimedia
             description: Audio device
             product: Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: 0e
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_hda_intel latency=0
             resources: irq:91 memory:90910000-90913fff
        *-pci:0
             description: PCI bridge
             product: Atom Processor E3800 Series PCI Express Root Port 1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:16 ioport:3000(size=4096)
        *-pci:1
             product: Atom Processor E3800 Series PCI Express Root Port 2
             physical id: 1c.1
             bus info: pci@0000:00:1c.1
             version: 0e
             width: 32 bits
             clock: 33MHz
             resources: irq:17 ioport:4000(size=4096) memory:90600000-906fffff
           *-network
                product: BCM43142 802.11b/g/n
                vendor: Broadcom Corporation
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: wlp2s0
                version: 01
                serial: 3c:77:e6:f9:bf:6b
                width: 64 bits
                clock: 33MHz
                configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=10.103.145.126 latency=0 multicast=yes wireless=IEEE 802.11abg
                resources: irq:17 memory:90600000-90607fff
        *-pci:2
             product: Atom Processor E3800 Series PCI Express Root Port 3
             physical id: 1c.2
             bus info: pci@0000:00:1c.2
             version: 0e
             width: 32 bits
             clock: 33MHz
             resources: irq:18 ioport:1000(size=4096) memory:90500000-905fffff ioport:90400000(size=1048576)
           *-network
                physical id: 0
                bus info: pci@0000:03:00.0
                logical name: enp3s0
                version: 0c
                serial: c4:54:44:f2:2e:d3
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-2_0.0.1 02/06/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
                resources: irq:88 ioport:1000(size=256) memory:90500000-90500fff memory:90400000-90403fff
        *-usb:1
             product: Atom Processor Z36xxx/Z37xxx Series USB EHCI
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci-pci latency=0
             resources: irq:23 memory:90918000-909183ff
           *-usbhost
                product: EHCI Host Controller
                vendor: Linux 4.4.0-53-generic ehci_hcd
                physical id: 1
                bus info: usb[member=3516]1[/member]
                logical name: usb1
                version: 4.04
                configuration: driver=hub slots=8 speed=480Mbit/s
              *-usb
                   vendor: Intel Corp.
                   physical id: 1
                   bus info: usb[member=3516]1[/member]:1
                   version: 0.14
                   configuration: driver=hub slots=4 speed=480Mbit/s
        *-isa
             description: ISA bridge
             product: Atom Processor Z36xxx/Z37xxx Series Power Control Unit
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
             configuration: driver=lpc_ich latency=0
             resources: irq:0
        *-serial UNCLAIMED
             description: SMBus
             product: Atom Processor E3800 Series SMBus Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pm cap_list
             configuration: latency=0
             resources: memory:90919000-9091901f ioport:2000(size=32)
« Son Düzenleme: 30 Mart 2017, 16:04:39 Gönderen: Panta rhei »
In GNU/Linux We turst
Ynt: TouchPad Acer Aspire ES1-11M-C064
« Yanıtla #1 : 27 Mart 2017, 17:10:30 »
Buradaki grub dosyası ile ilgili düzenlemeyi uygulamayı deneyiniz. Linux Mint 18.x'de gedit yerine xed yazacaksınız
  • İleti: 54
  • Dağıtım: 19.3
« Yanıtla #2 : 28 Mart 2017, 04:47:56 »
Bios tan touchpad ayarını advanced ten basic yaptım ve şu an touchpadı kullanabiliyorum,başka herhangi bir şey yapmama gerek kalmadı,,Biostan  touchpad ayarını basic 'e çevirmek yeterli.Teşekkürler
« Yanıtla #3 : 28 Mart 2017, 09:58:08 »
[member=3332]Panta rhei[/member] , geri dönüş için teşekkür ederiz. Konu başlığı etiketlerseniz, konuyu kilitleyebiliriz.
[okay] Çözülen başlıkların etiketlenmesi hakkında.[/okay]
  • İleti: 54
  • Dağıtım: 19.3
« Yanıtla #4 : 29 Mart 2017, 23:49:54 »
hocam son 2 konuda bir sorun yaşıyorum neyse açtığım başlıklardaki sorunu çözüyorum fakat başlığa geri dönünce sağ üstte değiştir butano yok bunu bu konuda ve bios içinde olmuştu şu anda sağ üste değiştir yapıp çözüldüye çeviremiyorum
