Gönderen Konu: [Çözüldü] CS GO VE DİĞER OYUNLARDA DÜŞÜK FPS LÜTFEN YARDIMCI OLUN  (Okunma sayısı 4450 defa)
Çevrimdışı batuhanbal
  • İleti: 13
  • Herşey bir Hilal uğruna ...
  • Dağıtım: Lİnux Mint Serena
System:    Host: Casper Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: MATE 1.16.1 (Gtk 3.18.9-1ubuntu3.2)
           Card-2: NVIDIA GF108M [GeForce GT 540M] bus-ID: 01:00.0
           Resolution: 1366x768@60.01hz
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 540M] (rev a1)
LVDS1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768      60.01*+
   1360x768      59.80    59.96
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
x'
ii  bumblebee                                                   3.2.1-97~xenialppa1                        amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                                            3.2.1-97~xenialppa1                        amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-304                                                  304.135-0ubuntu0.16.04.1                   amd64        NVIDIA legacy binary driver - version 304.135
rc  nvidia-375                                                  375.39-0ubuntu0.16.04.1                    amd64        NVIDIA binary driver - version 375.39
ii  nvidia-current                                              304.135-0ubuntu0.16.04.1                   amd64        Transitional package for nvidia-current
ii  nvidia-settings                                             378.13-0ubuntu0~gpu16.10.2                 amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                                      20150328-3~xenialppa2                      amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                                           20150328-3~xenialppa2                      amd64        Shared libraries for primus
ii  primus-libs:i386                                            20150328-3~xenialppa2                      i386         Shared libraries for primus
ii  primus-libs-ia32:i386                                       20150328-3~xenialppa2                      i386         Shared libraries for primus (32-bit)
ii  virtualgl                                                   2.4.1-1~xenialppa1                         amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                                        2.4.1-1~xenialppa1                         amd64        Library files for virtualgl
CS GO DA 800X600 ÇÖZÜNÜRLÜKTE ÇOKLU CPU KULLANIMI DIŞINDA BÜTÜN GRAFİK AYARLARI KAPALI OLMASINA RAĞMEN ALDIĞIM FPS 50 OYUN İÇİNDE, ÖNCE FORUMDA BELİRTİLDİĞİ ÜZERE BUMBLEBEE'Yİ KURDUM NVİDİA KARTIMI GÜNCELLEDİM STEAM ÜZERİNDE CS GO BAŞLATICI KOD BÖLÜMÜNE
LD_PRELOAD="libpthread.so.0 libGL.so.1" __GL_THREADED_OPTIMIZATIONS=1 optirun %command% BU KODU EKLEDİM BUMBLEBEE OYUN AÇILIRKEN AKTİF BİLDİRİMİ SAĞ ÜSTTE GÖZÜKÜYOR BUNUN DIŞINDA BUGÜN EKRAN KARTIMIN VE İŞLEMCİMİN TERMAL MACUNUNU DA DEĞİŞTİRDİM FANI TEMİZLEDİM AMA FPS ÇOK DÜŞÜK OYUNU İLK İNDİRDİĞİMDE GRAFİK AYARLARINI  EN SON DEĞERLERE YAKIN HALDE GÖRMÜŞTÜM RAHAT KALDIRMASINI BEKLERKEN ÇOK DÜŞÜK GRAFİKLERDE BİLE FPS ÇOK KÖTÜ 4 GB DDR3 RAMİM VAR İNTEL İ5 BU ÖZELLİKLERDE BU FPS NORMALMİ ANLAMADIM LÜTFEN YARDIMCI OLUN ŞİMDİDEN TEŞEKKÜRLER
« Son Düzenleme: 08 Nisan 2017, 17:19:20 Gönderen: batuhanbal »
Ynt: CS GO VE DİĞER OYUNLARDA DÜŞÜK FPS LÜTFEN YARDIMCI OLUN
« Yanıtla #1 : 08 Nisan 2017, 00:26:05 »
 primusrun komutu ile çalıştırmayı denediniz mi?
  • İleti: 13
« Yanıtla #2 : 08 Nisan 2017, 01:10:50 »
Nasıl yapabileceğimi bilmiyorum yeniyim kusura bakmayın
primusrun komutu ile giriş yaptım herhangi birşey değişmedi +graph komutu ile açtığım cs go penceresinde en düşük çözünürlükte fps 45  , en yüksek çözünürlükte ise neredeyse aynı 40 fps görüyorum bunun dışında o pencerede sv ve var değerleri sürekli kırmızı başka oyuncularda oralar 0 a çok yakınken bende çok yüksek
« Son Düzenleme: 08 Nisan 2017, 12:31:55 Gönderen: batuhanbal »
« Yanıtla #3 : 08 Nisan 2017, 15:17:36 »
Bir arkadaşta daha buna benzer bir sorun olmuştu ; Bumblebee ' yi kaldırıp Nvidia Prime kullanınca performans düzelmişti.
Eğer isterseniz onu deneyebilirsiniz. Forumda konuları mevcut , Nvidia bölümünde.
  • İleti: 13
« Yanıtla #4 : 08 Nisan 2017, 17:19:06 »
nvidia prime işe yaradı teşekkürler
