Gönderen Konu: [Çözüldü] Yırtılma Sorunu  (Okunma sayısı 5980 defa)
« : 17 Nisan 2017, 02:22:27 »
Merhabalar.
Bir laptopa Mint 18.1 Mate kurulumu yaptık ancak iki adet sorun var.
Öncelikle tarayıcıda scroll yaparken ve yerel diskten video izlerken yırtılma sorunu mevcut.
İkinci olarak; laptopu kapağı kapatıp bekleme moduna aldıktan sonra açınca masaüstü öğeleri ve görev çubuğu simgeleri siyah hale geliyorlar. Bu sorun sadece bir defa oldu ancak yırtılma hep mevcut.
Çıktılar:
System:    Host: ThinkPad-R500 Kernel: 4.8.0-46-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: MATE 1.16.1 (Gtk 3.18.9-1ubuntu3.2)
Machine:   System: LENOVO (portable) product: 2716AL1 v: ThinkPad R500
           Mobo: LENOVO model: 2716AL1
           Bios: LENOVO v: 7YET78WW (3.08 ) date: 09/16/2009
CPU:       Dual core Intel Core2 Duo T6670 (-MCP-) cache: 2048 KB
           flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 8778
           clock speeds: max: 2201 MHz 1: 1600 MHz 2: 1200 MHz
Graphics:  Card: Intel Mobile 4 Series Integrated Graphics Controller
           Resolution: 1280x800@60.03hz
           GLX Renderer: Mesa DRI Mobile Intel GM45 Express
           GLX Version: 2.1 Mesa 17.0.3 - padoka PPA Direct Rendering: Yes
Audio:     Card Intel 82801I (ICH9 Family) HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.8.0-46-generic
Network:   Card-1: Intel PRO/Wireless 5100 AGN [Shiloh] Network Connection
           driver: iwlwifi bus-ID: 03:00.0
           Card-2: Broadcom NetLink BCM5787M Gigabit Ethernet PCI Express
           driver: tg3 v: 3.137 bus-ID: 04:00.0
           IF: ens5 state: down mac: <filter>
Drives:    HDD Total Size: 160.0GB (4.9% used)
           ID-1: /dev/sda model: HITACHI_HTS54501 size: 160.0GB
Partition: ID-1: / size: 37G used: 7.2G (21%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 110G used: 271M (1%) fs: ext4 dev: /dev/sda5
Sensors:   System Temperatures: cpu: 47.0C mobo: 45.0C
           Fan Speeds (in rpm): cpu: 1936
Info:      Processes: 227 Uptime: 17 min Memory: 739.2/1894.0MB
inxi -SGx
OpenGL renderer string: Mesa DRI Mobile Intel® GM45 Express Chipset
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
Screen 0: minimum 8 x 8, current 1280 x 800, maximum 32767 x 32767
LVDS1 connected 1280x800+0+0 (normal left inverted right x axis y axis) 331mm x 207mm
   1280x800      60.03*+  50.06
   1024x768      60.00
   800x600       60.32    56.25
   640x480       59.94
   640x400       60.00
DP2 disconnected (normal left inverted right x axis y axis)
ii  nvidia-prime-applet                         1.0.6                                      all          An applet for NVIDIA Prime
« Son Düzenleme: 17 Nisan 2017, 18:28:31 Gönderen: Leopard »
Ynt: Yırtılma Sorunu
« Yanıtla #1 : 17 Nisan 2017, 10:30:55 »
Intel GPU yırtılma sorunu için şu denenebilir. https://forum.linuxmint.net.tr/index.php?topic=6601.msg41517#msg41517
Diğer sorun için aşağıdaki şekilde MATE xrandr eklentisini pasifleştirmek denenebilir, bu şekilde sorun çözülmezse yeni bir konu açılması daha uygun olur.
Önce şağıdaki komutla dconf düzenleme için gerekli paketleri kurunuz.
sudo apt-get install dconf-editor dconf-cli
Ardından aşağıdaki komutla eklentiyi pasifleştirebilirsiniz.
dconf write /org/mate/settings-daemon/plugins/xrandr/active false
« Son Düzenleme: 17 Nisan 2017, 10:40:08 Gönderen: Butterfly »
« Yanıtla #2 : 17 Nisan 2017, 12:29:09 »
[member=8]Butterfly[/member]
Maalesef sorun aynen devam etmekte
 Identifier "Intel Graphics"
 Driver "Intel"
 Option "AccelMethod" "sna"
 Option "TearFree" "true"
Aldığım çıktı doğru ancak hala yırtılmalar var
Burada bahsedilene göre , flickering için altta çözüm verilmiş ancak nasıl uygulanacağı hakkında fikrim yok , acaba bakabilir misiniz?
https://wiki.archlinux.org/index.php/intel_graphics#Screen_flickering
Diğer sorun bir daha tekrarlarsa o çözümü uygulayacağız,teşekkürler .Sadece bir kere oldu.
« Yanıtla #3 : 17 Nisan 2017, 13:35:52 »
Titreme sorunu bekleme kipi sonrası mı oluşuyor?
« Yanıtla #4 : 17 Nisan 2017, 17:00:45 »
Hocam sanırım sorunu buldum ama sizden doğrulama bekliyorum.
Sanırım ekran 50 Hz ama 60 hz çalışıyor şu anda.
Bunu düzeltirsek sanırım yırtılma çözülecek , siz ne düşünüyorsunuz?
   1024x768      60.00
   800x600       60.32    56.25
   640x480       59.94
   640x400       60.00
Zira bu makinanın Windows'ta da aynı sorunu varmış ; Intel Hd Graphics Tool ile manuel hz ayarlayınca düzeliyormuş. Direkt sahibinden aldığım bilgi.
Titremenin alakası yoktu hocam;acaba power saving özelliği flickerı düzelttiği gibi buna da etki eder mi diye düşünmüştüm. Yani varsayımsal bir 'ya tutarsa' denemesi olacaktı.
Kusura bakmayın. :(
« Son Düzenleme: 17 Nisan 2017, 17:02:27 Gönderen: Leopard »
« Yanıtla #5 : 17 Nisan 2017, 17:12:25 »
Aşağıdaki komutu çalıştırınca ne oluyor?
xrandr -s 1280x800 -r 50
Bununla sorun çözülürse başlangıç uygulamalarına eklerseniz, oturum açılınca otomatik etkinleşir.
« Yanıtla #6 : 17 Nisan 2017, 18:28:13 »
Çözüldü hocam , teşekkürler.  :)
« Yanıtla #7 : 21 Nisan 2017, 09:31:09 »
Hocam bu eksikliği nasıl fark ettiniz ve bu çıktının anlamını paylaşabilirmisiniz lütfen.
Ynt: [Çözüldü] Yırtılma Sorunu
« Yanıtla #8 : 21 Nisan 2017, 11:04:25 »
Sorunun tazeleme hızı ile alakalı olduğunu [member=3240]Leopard[/member] farketti.
xrandr komutu için -s değişkeni çözünürlüğü, -r değişkeni tazeleme hızını belirliyor.
