Gönderen Konu: Steam Oyunları Çalıştırırken Tepki Vermemesi  (Okunma sayısı 8730 defa)
Çevrimdışı okkir
  • İleti: 17
  • Dağıtım: Linux Mint 18.2
  • Grafik Kartı: Intel - Amd
  • İşlemci: Intel Core I5 M-480
« : 01 Mayıs 2017, 18:32:30 »
Oyunu steamden yükleyip girmeye çalıştığımda pencere açılıyor ve 2 saniye sonra tepkisiz kalıp kapanıyor. Sürücüleri de sorunsuz yükledim acaba sorun ne olabilir ?
System:    Host: okkir-HP-Pavilion-g6-Notebook-PC Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3)
Machine:   System: Hewlett-Packard (portable) product: HP Pavilion g6 Notebook PC v: 059B100000204610000010100
           Mobo: Hewlett-Packard model: 1669 v: 08.39
           Bios: Insyde v: F.66 date: 01/24/2013
CPU:       Dual core Intel Core i5 M 480 (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10642
           clock speeds: max: 2667 MHz 1: 1333 MHz 2: 1333 MHz 3: 1733 MHz
           4: 1333 MHz
Graphics:  Card-1: Intel Core Processor Integrated Graphics Controller
           Card-2: Advanced Micro Devices [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series]
           bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: ati,radeon,intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@59.64hz
           GLX Renderer: Mesa DRI Intel Ironlake Mobile
           GLX Version: 2.1 Mesa 17.0.4 - padoka PPA Direct Rendering: Yes
Audio:     Card Intel 5 Series/3400 Series High Definition Audio
Network:   Card-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter
           driver: wl bus-ID: 02:00.0
           IF: wlo1 state: up mac: <filter>
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 03:00.0
           IF: eno1 state: down mac: <filter>
Drives:    HDD Total Size: 320.1GB (21.3% used)
           ID-1: /dev/sda model: SAMSUNG_HM321HI size: 320.1GB
Partition: ID-1: / size: 290G used: 60G (22%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.08GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 60.0C mobo: N/A gpu: 60.0
Info:      Processes: 205 Uptime: 3:58 Memory: 1129.8/3751.3MB
Ynt: Steam Oyunları Çalıştırırken Tepki Vermemesi
« Yanıtla #1 : 01 Mayıs 2017, 18:40:30 »
Bunu denediniz mi?
Çevrimdışı okkir
  • İleti: 17
« Yanıtla #2 : 01 Mayıs 2017, 19:12:36 »
Denedim ama bu seferde siyah ekranda kaldı
« Yanıtla #3 : 01 Mayıs 2017, 19:35:38 »
DRI_PRIME=1 glxinfo | grep "render"
Bu komutda dönen çarkları görünüyor mu?
DRI_PRIME=1 glxgears
« Yanıtla #4 : 01 Mayıs 2017, 19:54:04 »
Öncelikle açacağınız oyunların başlatma seçeneğine
DRI_PRIME=1 %command% komutunu ekleyin.
Sorunu tam olarak saptamak için , Steam'den çıkın.
Terminale
steam yazarak Steam'i açın. Ardından kütüphanenizden çalışmayan oyuna gelin , oyna tuşuna basın. Ne hatası varsa terminalde görünecektir.
O çıktıyı buraya atın.
Çevrimdışı okkir
  • İleti: 17
« Yanıtla #5 : 01 Mayıs 2017, 20:52:46 »
Evet çarklar görünüyor
OpenGL renderer string: Gallium 0.4 on AMD CAICOS (DRM 2.43.0 / 4.4.0-53-generic, LLVM 4.0.0)
Running Steam on linuxmint 18.1 64-bit
Installing breakpad exception handler for appid(steam)/version(1493162727)
Gtk-Message: Failed to load module "atk-bridge"
(steam:22494): Gtk-WARNING **: Tema aygıtı module_path "adwaita" içinde bulunamadı,
** (steam:22494): WARNING **: Unknown device type 14
** (steam:22494): WARNING **: Could not create object for /org/freedesktop/NetworkManager/Devices/2: unknown object type
** (steam:22494): WARNING **: Ignoring invalid property 'secondaries'
** (steam:22494): WARNING **: Ignoring invalid property 'route-data'
** (steam:22494): WARNING **: Ignoring invalid property 'address-data'
** (steam:22494): WARNING **: Ignoring invalid property 'autoconnect-priority'
Generating new string page texture 2: 48x256, total string texture memory is 49,15 KB
Generating new string page texture 3: 256x256, total string texture memory is 311,30 KB
(steam:22494): GLib-GObject-WARNING **: /build/glib2.0-RnwmWL/glib2.0-2.48.2/./gobject/gsignal.c:2517: signal 'child-added' is invalid for instance '0x57671090' of type 'GtkMenu'
roaming config store loaded successfully - 1645 bytes.
migrating temporary roaming config store
Error: texture file 'graphics/avatarborderingame' does not exist or is invalid
Failed to init SteamVR because it isn't installed
Errors in servers/internetgamespage.res:
error loading file 'servers/internetgamespage.res', no such file
../vgui_surfacelib/FontManager.cpp (455) : Assertion Failed: font != vgui::INVALID_FONT
Assert( Assertion Failed: font != vgui::INVALID_FONT ):../vgui_surfacelib/FontManager.cpp:455
assert_20170501205436_19.dmp[22555]: Uploading dump (out-of-process)
/tmp/dumps/assert_20170501205436_19.dmp
ExecCommandLine: ""/home/okkir/.local/share/Steam/ubuntu12_32/steam" "
System startup time: 5,78 seconds
Generating new string page texture 73: 128x256, total string texture memory is 442,37 KB
Generating new string page texture 74: 128x256, total string texture memory is 131,07 KB
Generating new string page texture 75: 64x256, total string texture memory is 507,90 KB
Generating new string page texture 76: 8x256, total string texture memory is 516,10 KB
Generating new string page texture 77: 32x256, total string texture memory is 548,86 KB
[0501/205438.657310:ERROR:TextEncodingRegistry.cpp(140)] alias ISO-8859-8-I maps to ISO-8859-8-I already, but someone is trying to make it map to ISO-8859-8
assert_20170501205436_19.dmp[22555]: Finished uploading minidump (out-of-process): success = yes
assert_20170501205436_19.dmp[22555]: response: CrashID=bp-942aa26c-cce7-4797-9782-a827c2170501
assert_20170501205436_19.dmp[22555]: file ''/tmp/dumps/assert_20170501205436_19.dmp'', upload yes: ''CrashID=bp-942aa26c-cce7-4797-9782-a827c2170501''
Generating new string page texture 118: 128x256, total string texture memory is 679,94 KB
Generating new string page texture 126: 128x256, total string texture memory is 811,01 KB
Generating new string page texture 158: 2048x256, total string texture memory is 2,91 MB
Generating new string page texture 160: 256x256, total string texture memory is 3,17 MB
Generating new string page texture 161: 1024x256, total string texture memory is 4,22 MB
Generating new string page texture 163: 384x256, total string texture memory is 4,61 MB
Generating new string page texture 164: 24x256, total string texture memory is 4,64 MB
Generating new string page texture 165: 16x256, total string texture memory is 4,65 MB
Generating new string page texture 166: 256x256, total string texture memory is 4,92 MB
Game update: AppID 368230 "Kingdom: Classic", ProcID 22883, IP 0.0.0.0:0
ERROR: ld.so: object '/home/okkir/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
>>> Adding process 22883 for game ID 368230
>>> Adding process 22884 for game ID 368230
ERROR: ld.so: object '/home/okkir/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Found path: /home/okkir/.local/share/Steam/steamapps/common/Kingdom/Kingdom.x86
Mono path[0] = '/home/okkir/.local/share/Steam/steamapps/common/Kingdom/Kingdom_Data/Managed'
Mono path[1] = '/home/okkir/.local/share/Steam/steamapps/common/Kingdom/Kingdom_Data/Mono'
Mono config path = '/home/okkir/.local/share/Steam/steamapps/common/Kingdom/Kingdom_Data/Mono/etc'
displaymanager : xrandr version warning. 1.5
client has 7 screens
displaymanager screen (0)(LVDS1): 1366 x 768
Using libudev for joystick management
Importing game controller configs
>>> Adding process 22885 for game ID 368230
>>> Adding process 22926 for game ID 368230
Installing breakpad exception handler for appid(gameoverlayui)/version(20170425224519)
Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)
assert_20170501205647_5.dmp[22946]: Uploading dump (out-of-process)
/tmp/dumps/assert_20170501205647_5.dmp
assert_20170501205647_5.dmp[22946]: Finished uploading minidump (out-of-process): success = yes
assert_20170501205647_5.dmp[22946]: response: Discarded=1
assert_20170501205647_5.dmp[22946]: file ''/tmp/dumps/assert_20170501205647_5.dmp'', upload yes: ''Discarded=1''
Setting breakpad minidump AppID = 769
Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198110962390 [API loaded no]
[0501/205932.150083:ERROR:web_plugin_impl.cc(38)] Widevine registration is not supported after context initialization
Game removed: AppID 368230 "Kingdom: Classic", ProcID 22885
No cached sticky mapping in ActivateActionSet.Refresh rate: 60
« Son Düzenleme: 01 Mayıs 2017, 21:03:03 Gönderen: okkir »
« Yanıtla #6 : 02 Mayıs 2017, 03:18:21 »
Sadece Kingdom:Classic adlı oyunu mu açmıyor yoksa bütün oyunlar mı böyle?
http://steamcommunity.com/app/368230/discussions/1/351660338696212955/
Burada bahsedildiği kadarıyla oyun sorunlu görünüyor.
Çevrimdışı okkir
  • İleti: 17
« Yanıtla #7 : 02 Mayıs 2017, 19:24:08 »
Sürücüleri kontrol etmek için düşük boyutlu bu oyunu indirip denemek istemiştim. Farklı bir oyun indirip sonucunu buraya yazarım.
Çevrimdışı okkir
  • İleti: 17
« Yanıtla #8 : 07 Mayıs 2017, 15:42:34 »
Başka ufak boyutlu oyun olan Terrariayı kurdum ama bu seferde oyun aşırı derecede kasmaya başladı.
« Yanıtla #9 : 07 Mayıs 2017, 21:11:37 »
Oyunu aşağıdaki şekilde açmayı dener misiniz?
env DRI_PRIME=1 steam steam://rungameid/oyunun_id_kodu
« Yanıtla #10 : 07 Mayıs 2017, 21:30:20 »
[member=3521]okkir[/member]
Çalıştıracağınız oyunun başlatma seçeneklerine bunu eklemezseniz Intel HD ile çalışır. Sisteminizde çift kart var.
Çevrimdışı okkir
  • İleti: 17
« Yanıtla #11 : 10 Mayıs 2017, 22:46:13 »
Bunu denedikten sonra oyun stabil çalışmaya başladı teşekkür ederim. Her oyuna bu kodu yapıştırmamız gerekiyor değil mi ?
« Yanıtla #12 : 10 Mayıs 2017, 23:00:50 »
Evet, sizde iki gpu olduğu için (Intel ve AMD) oyunların AMD ile çalışması için her oyunun başlatma seçeneğine (Steam kütüphanesi-oyuna sağ tık özellikler-başlatma seçenekleri) bunu koymanız gerekli.
Çevrimdışı okkir
  • İleti: 17
« Yanıtla #13 : 12 Mayıs 2017, 21:15:55 »
O kodla oyunu çalıştırdığım zaman sorun düzeldi ama bu seferde hata verme olasılığı ortaya çıktı. Oyundayken sesi açmaya çalışırken bile masaüstüne dönüp kapanıyor ama Intel ile çalıştırdığım zaman  böyle bir şey olmuyor.
« Yanıtla #14 : 13 Mayıs 2017, 00:01:38 »
Oyunu bu şekilde uçbirimden çalıştırıp sorun oluncaya kadar uçbirimi kapatmayın. Oyun kapandığında uçbirimde oluşan çıktıları paylaşın.
