Gönderen Konu: Yazılımsal görsel işleme kipinde çalışıyor.  (Okunma sayısı 3100 defa)
Çevrimdışı Brando
  • İleti: 11
  • Dağıtım: Linux Mint 18.1 serena 64-bit
  • Grafik Kartı: AMD R9 380 4gb
  • İşlemci: İ5-6400
« : 07 Mayıs 2017, 00:02:09 »
https://i.hizliresim.com/m3WOdV.png
bilgisayar açılınca bu yazı geliyor bir sıkıntı varmı acaba
System:    Host: Brando Kernel: 4.4.0-77-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3)
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Tonga PRO [Radeon R9 285/380]
           bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Gallium 0.4 on AMD TONGA (DRM 3.1.0 / 4.4.0-77-generic, LLVM 4.0.0)
           GLX Version: 3.0 Mesa 17.0.4 - padoka PPA Direct Rendering: Ye
OpenGL renderer string: Gallium 0.4 on AMD TONGA (DRM 3.1.0 / 4.4.0-77-generic, LLVM 4.0.0)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Tonga PRO [Radeon R9 285/380] (rev f1)
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
HDMI-A-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 477mm x 268mm
   1920x1080     60.00*+  74.99    50.00    59.94
   1920x1080i    60.00    50.00    59.94
   1600x1200     60.00
   1680x1050     59.88
   1400x1050     59.95
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x960      60.00
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1440x576      50.00
   1024x768      75.08    70.07    60.00
   1440x480      60.00    59.94
   832x624       74.55
   720x576       50.00
   720x576i      50.00
   720x480       60.00    59.94
   720x480i      60.00    59.94
   640x480       75.00    72.81    66.67    60.00    59.94
   720x400       70.08
   720x240       60.12    60.05
DVI-D-0 disconnected (normal left inverted right x axis y axis)
Machine:   System: Gigabyte product: N/A
           Mobo: Gigabyte model: B150M-D3H-CF v: x.x
           Bios: American Megatrends v: F5 date: 11/02/2015
CPU:       Quad core Intel Core i5-6400 (-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 21696
           clock speeds: max: 3300 MHz 1: 799 MHz 2: 799 MHz 3: 799 MHz
           4: 799 MHz
           bus-ID: 01:00.0
           GLX Version: 3.0 Mesa 17.0.4 - padoka PPA Direct Rendering: Yes
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Tonga HDMI Audio [Radeon R9 285/380]
           Card-2 Intel Sunrise Point-H HD Audio
           driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.4.0-77-generic
Network:   Card: Intel Ethernet Connection (2) I219-V
           driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
           IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 2120.4GB (0.8% used)
           ID-1: /dev/sda model: KINGSTON_SHFS37A size: 120.0GB
           ID-2: /dev/sdb model: ST2000DM001 size: 2000.4GB
Partition: ID-1: / size: 103G used: 7.6G (8%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.52GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 60.0
Info:      Processes: 220 Uptime: 20 min Memory: 1824.8/7920.4MB
birde bilgisayar açılırken açılmasını istediğim programlar var bunları nerden ayarlayabilirim.
« Son Düzenleme: 07 Mayıs 2017, 10:37:06 Gönderen: Brando »
Ynt: Yazılımsal görsel işleme kipinde çalışıyor.
« Yanıtla #1 : 07 Mayıs 2017, 21:43:44 »
Lütfen kaynağı aynı olabilecek sorunlar için birbirinden farklı konular açmayalım.
Buradaki konuda paylaştığınız çıktıda sistem yazılımsal işleme ile çalışıyor, yani sistem donanımsal hızlandırma ile çalışmıyor. Böyle durumlarda Cinnamon 2D kipinde çalışır, bunun sebebi 3D işleme ile ilgili bir sorun olmasıdır.
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 4.0, 256 bits)
Bir şeyler yapmış olmalısınız ki bu konudaki çıktılarda durum değişmiş ve sistem ATI GPU ile işlenmeye başlanmış.
Böyle durumlarda siizn ne yaptığınız hakkında daha çok bilgiye ihtiyaç duyurulur, açtığınız konularda yaptığınız işlemler ile ilgili daha  fazla bilgi paylaşmalısınız.
[warning] Konu Açarken Dikkat Edilmesi Gerekenler[/warning]
Eğer otomatik oturum açma etkinse buradaki düzenlemeyi yapmayı deneyiniz.
