Gönderen Konu: Nvidia GTX 940M Web Tarayıcılarında Yırtılma Sorunu  (Okunma sayısı 4352 defa)
Çevrimdışı baddeveloper
  • İleti: 4
  • Grafik Kartı: Nvidia Gtx 940M
  • İşlemci: Intel 6200U
Chrome-Stable veya Firefox tarayıcılarında farketmeksizin yırtılmalar oluyor.Aynı şekilde video izlerkende yırtılmalar oluyor.Konuyu açmadan önce daha önceden açılan konulara baktım ama tam anlamadım ne yapmam gerektiğini.
inxi -SGx
System:    Host: bhbaddeveloper Kernel: 4.4.0-78-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3)
Graphics:  Card-1: Intel Sky Lake Integrated Graphics bus-ID: 00:02.0
           Card-2: NVIDIA GM108M [GeForce 940MX] bus-ID: 03:00.0
           Display Server: X.Org 1.18.4 driver: nvidia
           Resolution: 1920x1080@60.01hz, 1920x1080@60.00hz
           GLX Renderer: GeForce 940MX/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 381.22 Direct Rendering: Yes
OpenGL renderer string: GeForce 940MX/PCIe/SSE2
    GL_KHR_robustness, GL_KTX_buffer_region, GL_NVX_conditional_render,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB,
    GL_NV_conditional_render, GL_NV_copy_buffer, GL_NV_copy_image,
    GL_OES_fbo_render_mipmap, GL_OES_geometry_point_siz
00:02.0 VGA compatible controller: Intel Corporation Sky Lake Integrated Graphics (rev 07)
03:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev a2)
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 16384 x 16384
eDP-1-1 connected 1920x1080+0+0 344mm x 194mm
   1920x1080     60.01*+  59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       60.00
   960x540       59.99
   840x525       60.01    59.88
   800x512       60.17
   700x525       59.98
   640x512       60.02
   720x450       59.89
   640x480       60.00    59.94
   680x384       59.80    59.96
   576x432       60.06
   512x384       60.00
   400x300       60.32    56.34
   320x240       60.05
HDMI-1-1 connected primary 1920x1080+1920+0 477mm x 268mm
   1920x1080     60.00*+  50.00    59.94    59.99
   1920x1080i    60.00    50.00    59.94
   1600x1200     60.00
   1680x1050     59.88
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x960      60.00
   1366x768      59.79
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.08    70.07    60.00
   832x624       74.55
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    72.81    66.67    60.00    59.94
   720x400       70.08
DP-1-1 disconnected
HDMI-1-2 disconnected
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "intel"
    Identifier "intel"
    Driver "modesetting"
    BusID "PCI:0@0:2:0"
    Option "AccelMethod" "None"
Section "Screen"
    Identifier "intel"
    Device "intel"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:3@0:0:0"
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
rc  nvidia-375                                  375.39-0ubuntu0.16.04.1                      amd64        NVIDIA binary driver - version 375.39
ii  nvidia-381                                  381.22-0ubuntu0~gpu16.04.2                   amd64        NVIDIA binary driver - version 381.22
rc  nvidia-opencl-icd-375                       375.39-0ubuntu0.16.04.1                      amd64        NVIDIA OpenCL ICD
ii  nvidia-opencl-icd-381                       381.22-0ubuntu0~gpu16.04.2                   amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                0.8.2linuxmint1                              amd64        Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                         1.0.6                                        all          An applet for NVIDIA Prime
ii  nvidia-settings                             361.42-0ubuntu1                              amd64        Tool for configuring the NVIDIA graphics driver
« Son Düzenleme: 22 Mayıs 2017, 16:52:16 Gönderen: baddeveloper »
Ynt: Nvidia GTX 940M Web Tarayıcılarında Yırtılma Sorunu
« Yanıtla #1 : 22 Mayıs 2017, 17:03:16 »
Şu mesajdaki nedenden dolayı yırtılma oluyor. https://forum.linuxmint.net.tr/index.php?topic=250.msg45754#msg45754
Intel GPU'ya geçiş yapıp sonucu gözlemleyin.
  • İleti: 4
« Yanıtla #2 : 22 Mayıs 2017, 20:54:04 »
Açıkçası çok bir fark göremedim. Aynı sorun hala devam ediyor. Intel grafik işlemcide.
  • İleti: 4
« Yanıtla #4 : 25 Mayıs 2017, 16:43:21 »
Attığınız linkteki denenleri yaptım,ancak Nvidia ekran kartına geçiş yaptığımda bilgisayar açıldıktan sonra güvenli modda mı ne başlatıyor.Intel ekran kartını kullanırkende çok fazla yırtılma oluyor. Tarayıcı veya masaüstü kullanımda.
inxi -SGx
           Display Server: X.Org 1.18.4 driver: intel
           GLX Renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
rect rendering: Yes
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 520 (Skylake GT2)
03:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev ff)
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
eDP1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1600x1024     60.17
   1400x1050     59.98
   1600x900      60.00
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1368x768      60.00
   1152x864      60.00
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   640x360       60.00
HDMI1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 477mm x 268mm
   1600x1200     60.00
   1680x1050     59.88
   1440x900      59.90
   1280x960      60.00
   1366x768      59.79
   1152x864      75.00
   832x624       74.55
   720x576       50.00
   720x480       60.00    59.94
   720x400       70.08
ii  bumblebee                                   3.2.1-98~xenialppa1                          amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                            3.2.1-98~xenialppa1                          amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-settings                             381.22-0ubuntu0~gpu16.04.1                   amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20150328-3~xenialppa2                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20150328-3~xenialppa2                        amd64        Shared libraries for primus
ii  primus-libs:i386                            20150328-3~xenialppa2                        i386         Shared libraries for primus
ii  primus-libs-ia32:i386                       20150328-3~xenialppa2                        i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.4.1-1~xenialppa1                           amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.4.1-1~xenialppa1                           amd64        Library files for virtualgl
ii  virtualgl-libs:i386                         2.4.1-1~xenialppa1                           i386         Library files for virtualgl
ii  virtualgl-libs-ia32:i386                    2.4.1-1~xenialppa1                           i386         Library files for virtualgl (32-bit)
« Yanıtla #5 : 25 Mayıs 2017, 20:39:30 »
Bumblebee kurduğunuzda Nvidia Aygıt sürücüsü ile GPU'lar arasında geçiş yapmamalısınız. Bu sebeple aşağıdaki komutla nvidia-prime paketini kaldırınız.
Cinnamon masaüstü için aşağıdaki öneri de denenebilir.
https://forum.linuxmint.net.tr/index.php?topic=250.0
  • İleti: 4
« Yanıtla #6 : 25 Mayıs 2017, 21:56:07 »
Hocam hala fallback modunda açılıyor. Dediğinizi yapmama rağmen. Şuan fallback modundayım. Ekran çok gidip geliyor.
